Dezod AEM V2 Wasted Spark to COP - Page 3 - Lexus IS Forum
post #31 of 126 (permalink) Old 11-18-2013, 09:08 AM Thread Starter
Supporting Vendor
Dezod Motorsports's Avatar
Quoted: 21 Post(s)
Dezod Motorsports is offline
post #32 of 126 (permalink) Old 11-25-2013, 12:05 AM
Originally Posted by Dezod Motorsports View Post
Have your tried it Donnie?
No I have not, I have been busy with work and assembling 2 race cars and redoing mine from the frame up. My winter looks busy but I will try to find time for it!
Im your local smarta$$
leonard_is300 is offline
post #33 of 126 (permalink) Old 04-03-2014, 05:38 PM
Maybe I can get some help here:
So, I just did the swap from TT coils to LQ9.
I followed the instructions given by Dezod.
-Wired 3 new wires to AEM box for coil 4, 7, 8
-Changed coils in coil wizard to LQ9
-Changed the coil output to 1-8A as well as phasing
I have good grounds, 12V to the coils.
Now the car is cranking, it fires but the order seems bad. I have backfires and clearly there is something wrong.
What am I doing wrong??
Max 1.6 is offline
post #34 of 126 (permalink) Old 04-03-2014, 08:59 PM
Quoted: 42 Post(s)
What is your coil phasing?
Can you screen shot that screen?
Why coil 7 and 8? we are talking 2jz here, correct? It should be coils 1-6, not 1-8, or was that a typo?
mitsuguy is offline
post #35 of 126 (permalink) Old 04-03-2014, 09:02 PM
Coil phasing is:
Coil 1 - Ph 0
Coil 2 - Ph 16
Coil 3 - Ph 8
Coil 4 - Ph 20
Coil 5 - Ph 4
Coil 6 - Ph 12
Right now I changed my phasing cause it was off, then I have no fire at all except 1 major backfire at the end of cranking (5 sec)
I use coil 7 and 8 because 5-6 already taken in V2 kit from dezod
Max 1.6 is offline
post #36 of 126 (permalink) Old 04-03-2014, 09:17 PM
Quoted: 42 Post(s)
Alright, so that is correct, so long as it is wired correctly then... What is your ignition sync number at??? Wizards > ignition sync wizard, then click advanced options
mitsuguy is offline
post #37 of 126 (permalink) Old 04-03-2014, 09:19 PM
ignition sync : 3 teeth
pickup delay : 130
Max 1.6 is offline
post #38 of 126 (permalink) Old 04-03-2014, 09:21 PM
Quoted: 42 Post(s)
Wait, quick observation... Coil 1, 2 and 3 are no longer 1, 2 and 3...
They are technically coils 2, 4 and 6 now unless you rewired the whole entire thing...
mitsuguy is offline
post #39 of 126 (permalink) Old 04-03-2014, 09:25 PM
Quoted: 42 Post(s)
Also, 2.523 is the default, though it can be moved one way or the other, as necessary... Thats one of those set and forget and I don't remember how far off 3 would actually be... I think it would still start though...
mitsuguy is offline
post #40 of 126 (permalink) Old 04-03-2014, 09:25 PM
What I did exactly:
Pulled the igniter, then cut the 3 ecu signals. Wired them into coil 1, 2 and 3
After I wired 3 new wires to the AEM box for coil 4, 5 and 6
Max 1.6 is offline
post #41 of 126 (permalink) Old 04-03-2014, 09:28 PM
Quoted: 42 Post(s)
Did you cut the right side of the igniter wires?
mitsuguy is offline
post #42 of 126 (permalink) Old 04-03-2014, 09:30 PM
Yes, I verified that I have connection between new coils and AEM box for the 6 channels.
Max 1.6 is offline
post #43 of 126 (permalink) Old 04-03-2014, 09:37 PM
Quoted: 42 Post(s)
Try the default setting of 2.523 and see if it makes any difference, if not, kinda stumped... changing mine was very straight forward, though I ran a whole harness back to the AEM instead of tying in to the factory stuff...
mitsuguy is offline
post #44 of 126 (permalink) Old 04-04-2014, 09:16 AM
Problem solved, it was really a question of phasing.
My phasing is now:
Coil 1 - Ph 12
Coil 2 - Ph 4
Coil 3 - Ph 20
Coil 4 - Ph 8
Coil 5 - Ph 16
Coil 6 - Ph 0
Each coil is wired at the same cylinder number. Car is now idling just like it was before.
Max 1.6 is offline
post #45 of 126 (permalink) Old 04-04-2014, 10:03 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
My phasing is now:
Coil 1 - Ph 12
Coil 2 - Ph 4
Coil 3 - Ph 20
Coil 4 - Ph 8
Coil 5 - Ph 16
Coil 6 - Ph 0
Glad to hear you have it figured out. Ensure you have the coil wizard set right and proper coil dwell too
