Dezod AEM EMS V2 FAQ, Service & Tech Thread - Page 8 - Lexus IS Forum
post #106 of 193 (permalink) Old 04-18-2012, 07:03 AM Thread Starter
Supporting Vendor
Dezod Motorsports's Avatar
Quoted: 21 Post(s)
Originally Posted by 98$c300vvti View Post
ok thanks for your help.i have a IAT sensor.so ill go with that route.i dont don't know if i mentioned it before.im going ffim with an aftermarket TB will the stock ECU still control idle?
Depends on the IM you are running and IAC that goes with it. If the AEM can control it, you'll be OK.
Dezod Motorsports is offline
post #107 of 193 (permalink) Old 05-03-2012, 10:05 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
Just wanted to say thanks to all of you whom continue to order our units!
For those whom have them, please post up a little about your setup and some results.
post #108 of 193 (permalink) Old 05-30-2012, 08:07 PM
I was just wondering for those that got the AEM Temp sensor, which one you got, 1/4" or 3/8" and where everyone installed it? Pic is worth a 1000 words
I currently just got the car put back together, 367whp and 333wtq on a mustang dyno. have TT internals now, w58 supra tranny, aem V2 from dezod, hks intercooler and bov, Precision 46 wastegate, comp TBB 6767 billet turbo. this is running at 14lbs boost, controlled with aem boost controller, also have aem wideband and running 91 octane fuel. Hoping to get temp sensor installed and fix temp as soon as i find out what size and where people are installing. Hoping to get meth injection and maybe up boost towards end of season this year.
Boosted 2003 IS300 Sportdesign
346WHP and 314WTQ on a mustang dyno, tbc...
cliffyh is offline
post #109 of 193 (permalink) Old 06-01-2012, 01:11 PM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
Use this:
Dezod Motorsports. AEM Coolant Temperature Sensor Kit
Mount in radiator.
post #110 of 193 (permalink) Old 06-04-2012, 06:03 AM
Is this compatible with stock Radiator?
Anyone got any pics of it mounted?
cliffyh is offline
post #111 of 193 (permalink) Old 06-04-2012, 07:35 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
Probably be quite difficult with a stock rad, but not impossible. I have no pics.
post #112 of 193 (permalink) Old 06-04-2012, 10:30 AM
LOL Yea so not that easy fix, just like i was thinking. Anyone have schematic for changes to the AEM. I am electronics tech trained to IPC-610 Surface mount soldering. Would make it easier for me to just mod the AEM. I dont really feel like sending the aem away when i just got the car back together and tuned.
cliffyh is offline
post #113 of 193 (permalink) Old 06-04-2012, 11:56 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
Not that simple. We can not provide a proprietary schematic and wiring info to you to do so on your own.
Should you want to take the matters into your own hands, you have voided your warranty with us and AEM.
Should you still chose to proceed, the simple modification would be remove the tap/splice into the factory coolant temp signal coming out of AEM C26. This signal would go directly to your chosen external ECT sensor. Let the factory remain untouched and the AEM will have it's own independent signal to read.
post #114 of 193 (permalink) Old 06-04-2012, 03:38 PM
How long is the warranty period? Anyone else install a separate sensor with factory rad??
cliffyh is offline
post #115 of 193 (permalink) Old 06-05-2012, 03:40 AM
tba
I just added a T fitting in the coolant line to the throttle body to install the AEM coolant sensor.
If you want a cleaner install, you can always use the second port next to the factory coolant temp sensor in the cylinder head. Not sure what thread it is though.
tba is offline
post #116 of 193 (permalink) Old 06-05-2012, 07:40 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
From AEM, I believe it's one year. From us on the harness side, it's 1 year free from manufacturer defects.
post #117 of 193 (permalink) Old 06-05-2012, 07:18 PM
Thanks for the reply, any chance you can get a quick pick of what you did so i have something to go by?
cliffyh is offline
post #118 of 193 (permalink) Old 07-31-2012, 11:15 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
New policy and procedure for IS300 AEM EMS technical support is as follows:
Information needed to get assistance from us.
1) Original order ID*
2) Name (must have)
3) Serial number on AEM box (must have)
4) You may be asked to submit a photo(s) of your box and/or harness***
Please have this information ready when calling so that we can assist you better.
*If you don't have this, we can look it up by your name
***If this is asked of you, you must submit the photos prior to receiving assistance.
post #119 of 193 (permalink) Old 09-18-2012, 07:46 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
Alert: potential poached and attempted impersonated AEM EMS for the IS300 have been detected on the market. Buyer be aware. Recall that we have been doing this since 2006. Buy from the source. The originators...Dezod Motorsports.
post #120 of 193 (permalink) Old 01-12-2013, 01:04 PM
install manual link isn't working for me
01' GTE/R154-Dead
94' FD
sgtmat is offline
