Dezod AEM EMS V2 FAQ, Service & Tech Thread - Page 7 - Lexus IS Forum
post #91 of 193 (permalink) Old 03-16-2012, 02:36 PM Thread Starter
Supporting Vendor
Dezod Motorsports's Avatar
Quoted: 21 Post(s)
Originally Posted by leonard_is300 View Post
Ok cool, Id love to have 2 maps one for e85 and one for 93 pump but AEM has yet to release a flex fuel sensor. I am also looking into selling my TurboSmart MBC for the AEM Tru Boost setup.
Toggle switch FTW! One less sensor to buy and worry about failing.
Dezod Motorsports is offline
post #92 of 193 (permalink) Old 03-16-2012, 06:07 PM
Where would be a good placed to get my AEM EMS2 checked?
mines gone faulty and the ignition doesnt fire when trying to start the car.
loacted in AUS, is it worth it to get it repaired or just go for a new EMS
Emrifusion is offline
post #93 of 193 (permalink) Old 03-19-2012, 07:58 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
That is your call. I would start by contacting AEM directly.
post #94 of 193 (permalink) Old 03-21-2012, 06:21 PM
Alright as I said before I would take a screen shot of the AEMTuner and the Toyota Techstream to the temp sensor issue. If both the AEM and stock ECU are using the same sensor I am guess the temps should be close..........WRONG they are pretty far apart. But while just cruising at 70mph for 10 minutes or so my engine temp never went past 180 which is fine.
The problem that could happen here is that the AEM see's one temp and the OEM ECU see's a scewed temp and might not kick the fans on.
Im your local smarta$$
leonard_is300 is offline
post #95 of 193 (permalink) Old 03-22-2012, 07:35 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
Something with these new AEM V2 boxes causes a skew to the factory ECU that never occurred prior on early V2 boxes NOR V1 boxes. This is why we have made changes to the mods, and offered a solution for those whom have the boxes to send it back in for the fix OR run an AEM ECT where the tap into the factory signal is removed and all will be ok.
post #96 of 193 (permalink) Old 03-22-2012, 11:28 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
Now that I have a little more time on my hands, I will further elaborate on this.
There are effectively two solutions to solving this issue.
1) Remove the tap into the engine coolant temp sensor reading on our harness and run a supplemental ECT sensor strictly for the AEM EMS to read. This requires no down time and about $35 in cost.
2) Send us back your AEM EMS box (only) and we will open it up, modify it, reseal it and send it back to you. This requires a few days of down time, but that's it.
Either of these methods will relieve the factory ECU seeing more resistance than it should causing the large temperature differential.
post #97 of 193 (permalink) Old 04-14-2012, 07:22 PM
Originally Posted by nemesis007 View Post
what do u want to know?
Originally Posted by Dezod Motorsports View Post
Ditto. ?????
well this thread for the V2.i have the V1.im staying auto.will i have to keep my MAF installed?thanks in advance.
98 VVTi SC300,Wet 100 Shot of NOS,Front LS400 BBK Calipers painted gold,Goodridge stainless steel braided brake lines,Blacken Emblems,Polished Intake,Tanabe Springs,8k Hid's 6k fogs,Tranny cooler w/fan,EXE Konvex Front 19x8.5,Rear 19x9.5.
14.1@96mph on NOS
NA-T-4" intake,Borg Warner 83-75,Stainless steel manifold,Tial 38mm WG,2 Blitz BOV,Aeromotive FPR,850cc,Twin in tank Walbro fuel pump,FFIM,AEM standalone,Aem Wideband,HKS Cam Gear,Blitz SBC i-D boost Controller(Need to Tune)
98$c300vvti is offline
post #98 of 193 (permalink) Old 04-16-2012, 08:06 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
Autos need to keep the MAF for calculated shift points.
post #99 of 193 (permalink) Old 04-16-2012, 10:02 PM
im doing my built myself.can you guide me as to where to put it.has it worked to trick the car that the MAF is in there?
also what idle issues will i have with the Dezod AEM EMS v1?
14.1@96mph on NOS
post #100 of 193 (permalink) Old 04-17-2012, 04:42 AM
tba
The MAF can go either in front of the throttle body or turbo. If you place the MAF pre-turbo, you should add an IAT sensor near the throttle body so the AEM gets an accurate air temp reading.
The stock ECU on an auto uses the MAF to know when to shift the trans. Without that proper reading, the trans will go into limp mode and shift at the lowest rpm possible. E-shift will also not function properly.
With a proper tune, there should be no idle issues. The stock ECU will still control idle airflow using the throttle body, the EMS only handles fuel and timing.
tba is offline
post #101 of 193 (permalink) Old 04-17-2012, 07:02 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
Let me also reiterate that with control over VVT, fuel and ignition timing, your idle should be close to factory.
post #102 of 193 (permalink) Old 04-17-2012, 08:39 AM
I haven't read into it, and after receiving my car back - the shop did not include any of my AEM paperwork/boxes.
Regarding a programmable two-step, is this immediately available on my AEM v2 and can I (relatively) easily program it for my non-stalled auto trans?
fiveohfour is offline
post #103 of 193 (permalink) Old 04-17-2012, 02:24 PM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
Can't do 2STEP on an auto, but yes it can be done on the box.
Instructions found here:
My Computer>C Drive>Program Files>AEM>Instructions
You can also DL AEM PRO software and it automatically installs "AEM PRO USER GUIDE V2.0" which is the bible for EMS.
post #104 of 193 (permalink) Old 04-17-2012, 08:51 PM
ok thanks for your help.i have a IAT sensor.so ill go with that route.i dont don't know if i mentioned it before.im going ffim with an aftermarket TB will the stock ECU still control idle?
14.1@96mph on NOS
post #105 of 193 (permalink) Old 04-17-2012, 08:56 PM
thanks for the info.it's been really hard for me to get good soild infomation on the vvti set-up when going boost.
i know that it will never be factory with all the changes i have done to the car.but i could live with close to factory.lol
14.1@96mph on NOS
