Dezod AEM EMS V2 FAQ, Service & Tech Thread - Page 3 - Lexus IS Forum
post #31 of 193 (permalink) Old 01-19-2012, 08:29 AM Thread Starter
Supporting Vendor
Dezod Motorsports's Avatar
Quoted: 21 Post(s)
Dezod Motorsports is offline
post #32 of 193 (permalink) Old 01-23-2012, 06:24 PM
Originally Posted by Dezod Motorsports View Post
EVAP Purge is still controlled by the factory ECU, FYI
Thanks Paul!
I did a little searching and they do leave it connected. As far as the hose that went to the airbox they either just let it vent to atmosphere or just plumbed it back into the turbo intake pipe. The hose going to the tank stays intact.
On to another topic. I was surfing the go faster section and I came across this thread:
easy MAF clamp for standalone users
Is this something that even Dezod AEM users will need to worry about?
2001 Lexus IS300- R154 w/LSD-2JZGTE VVTI-GT3788R (In the works!)
2012 Lexus CT200H F Sport
DC5ROY is offline
post #33 of 193 (permalink) Old 01-24-2012, 07:20 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
Originally Posted by DC5ROY View Post
Thanks Paul!
Well that depends on the end users setup. Every IS300 I have seen is so drastically different than the next, so I it would depend on the setup as a whole if it will play a major factor.
post #34 of 193 (permalink) Old 01-24-2012, 12:10 PM
I'm just concerned because I had never heard about this in the past. I understand that the MAF is there to control tranny shift points, IAT and other things, but I never knew it was still had the ability to start closing the TB and effect cam timing when the MAF was maxing out. I didn't even know it was still reading that info back to the stock ECU and even if it did who cares because the AEM is running the show. What are the high hp IS300 doing in these cases? I'm planning on running a good amount of boost and still retaining the factory TB. The MAF would still be retained for the IAT function.
I know I'm probably getting way ahead of myself considering I don't even have the car done or tuned, but I just want to get all my ducks in a row if you know what I mean.
Thanks
DC5ROY is offline
post #35 of 193 (permalink) Old 01-24-2012, 12:28 PM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
Well I guess you're referring to if the user is using the factory TB or not?
I'm just very interested in knowing if this is possibly something that I or others will be effected by.
I just freaked out because this was the first time I read about this.
I intend to keep the factory TB for now.
That also if the MAF is blow through vs pull through, stock TB and IM vs ?, standalone vs piggyback, MAF delete vs ?, Auto vs 5 Speed....
post #36 of 193 (permalink) Old 01-24-2012, 01:17 PM
Paul I actually edited my prior post if you want to take a look at it.
In regards to what you just wrote I would be using the stock TB, Your AEM system, Keeping the MAF in the I/C pipe after the intercooler (blow through), car was auto but did a R154 manual tranny swap and retained factory 2001 ECU. Hope this helps
DC5ROY is offline
post #37 of 193 (permalink) Old 01-24-2012, 01:28 PM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
I know I'm probably getting way ahead of myself considering I don't even have the car done or tuned, but I just want to get all my ducts in a row if you know what I mean.
Thanks
Newer AEM set ups use an IAT sensor not the MAF.
If VVT is controlled by the factory ECU it can alter power that way. Our newer AEMs have the option for you to choose.
As far if this will be a factor for you, I don't know 100%.
post #38 of 193 (permalink) Old 01-24-2012, 02:16 PM
Paul thanks for your support.
I'm actually going to be installing the V.1 AEM.
Like I said, I think I'm getting ahead of myself considering I haven't had first hand experience with this. If I ever do come across this issue I'll tackle it then. Hopefully with your great insight and expertise.
DC5ROY is offline
post #39 of 193 (permalink) Old 01-24-2012, 02:18 PM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
As always, I am here if you need me. Rock on until then!
post #40 of 193 (permalink) Old 01-25-2012, 05:30 AM
Originally Posted by tba View Post
Ran into a problem today testing my V2 EMS. It seems that the V2 reads the wrong sensor voltage for the coolant temp. With my V1, I see 0.66v and 172F in AEMpro (OBD2 reads 161F). With the V2, it reads 1.2v and 129F in AEM Tuner (OBD2 reads 122F). Oil temp reads 190F, and I have an HKS coolant temp gauge installed that shows 168F, so the V1 reading is correct.
The low coolant temp reading is causing the idle to hold around 1400-1500rpm since the stock ECU thinks the motor still needs to warm up and holds the throttle body open. The radiator fans also do not turn on since the ECU thinks the coolant temp is lower than it really is.
I checked the wiring on the V2 PnP harness, and the coolant temp wire is correct pin to pin.
Any ideas for things to check?
I am having the same problem with my ems, what did you do to resolve it?
Boosted 2003 IS300 Sportdesign
346WHP and 314WTQ on a mustang dyno, tbc...
cliffyh is offline
post #41 of 193 (permalink) Old 01-25-2012, 07:08 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
You could simply run an AEM ECT sensor. The tap into the factory ECU is undoubtedly causing this with select V2 EMSs.
post #42 of 193 (permalink) Old 01-31-2012, 06:44 PM
What would i have to change for a 2001 set up to use for a 2002?
Thanks
HKS triple plate. Is like the rattle call we all use to get the snakes to come out and play(i.e. vipers, cobras,Gt500's).
sleepyIS300 is offline
post #43 of 193 (permalink) Old 02-01-2012, 07:35 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
Thanks
Different harness. 02-05 have different ECU connectors than an 01.
post #44 of 193 (permalink) Old 02-08-2012, 08:20 AM
ok i'm confused. went out yesterday to hook up the v2 AEM and now it's getting no power. at first it was saying wrong FIN / GIN files. so I found out that with the v11 cal, you need the old USB drivers "LibUSB-Win32 Devices" still doesn't appear.
what i've done is:
hook up MAP sensor into C17,C18,C19.
hook up IAT sensor to C18, C25 (which was weird it didn't have a tap)
hook up wideband to C16
plug harness into ECU, back to car harness, leading to AEM
hook laptop USB to AEM
ECU -> connection preference for USB
hook charger up to battery so i know it's 100% charged battery (had problems on my nissan it not reading at weak battery)
went and checked some of the 5V wires and they are getting power.
still can't get it to connect with the ecu. any more suggestions?
<< confused.
edit: here's what i found for the USB
- How to Install USB Driver?
1. Connect to EMS and power on.
2. After Windows pops up "Found new hardware", choose to install driver from the following place:
[Default] C:\Program Files\AEM\AEMTuner\USB Drivers (Series 2)
For EMS firmware version 01v11 or below, if you want to connect, you should install the driver and swap the dll. You can find the instructions from "Old USB Drivers" folder under your AEMTuner installation folder. Once you have driver installed, go to "Control Panel" -> "Device Manager", there should be a "LibUSB-Win32 Devices" device.
For EMS firmware version 01v12, there is NO need to install USB driver. Windows will recognize EMS natively (as Human Interface Device under Device Manager).
problem is step 1. connecting to EMS
thank you for any help!
~cody
02 5 speed. Chargespeed, CP, Eagle, OBX, area 51, SRT, TRD, HKS, Volk, TokenSolutions, FIGS, BC, ARP, Fidanza, ACT, Tein, UR, ATI, AEM, Hawk, Megan, Greddy, Mishimoto, Teck, Clifford, Focal, Alpine, Pioneer, C-West, AAC, Cusco, Sustec, Tuned Parts, Toyomoto, Walbro...ect ect
UsaPride is offline
post #45 of 193 (permalink) Old 02-08-2012, 08:39 AM Thread Starter
Supporting Vendor
Quoted: 21 Post(s)
what i've done is:
<< confused.
~cody
Try uninstalling and re-installing the software.
