Roll Center Adjusters IS300 - Lexus IS Forum
post #1 of 16 (permalink) Old 05-01-2011, 09:50 PM Thread Starter
How can I obtain this for my dropped car?!
"that boy asad" is offline
post #2 of 16 (permalink) Old 05-01-2011, 10:59 PM
Fig
THE MAKER
Fig's Avatar
Quoted: 20 Post(s)
Fig is offline
post #3 of 16 (permalink) Old 05-01-2011, 11:53 PM Thread Starter
I'm sorry, i should have been more clear... i really just need the RCA - my car is slammed on tein coilover and i have terrible bump steer!!!
post #4 of 16 (permalink) Old 05-02-2011, 11:52 AM
Fig
THE MAKER
Fig's Avatar
Quoted: 20 Post(s)
Oh, I have them, just not on the site. PM me for price.
Fig
Fig is offline
post #5 of 16 (permalink) Old 05-03-2011, 10:21 AM Thread Starter
Fig
you sir, have a pm!
post #6 of 16 (permalink) Old 05-03-2011, 04:44 PM
TeCKis300's Avatar
Hey Fig, shoot me a price as well. I need to sharpen up my turn in and front end roll resistance on my slammed nose heavy car.
Car sold to a good new home!
TeCKis300 is offline
post #7 of 16 (permalink) Old 05-12-2011, 12:16 AM Thread Starter
Would you be able to post some pics of it also?
post #8 of 16 (permalink) Old 05-12-2011, 10:21 PM
Fig
THE MAKER
Fig's Avatar
Quoted: 20 Post(s)
this is what the first ones looked like, now they are either bare aluminum or black anodized. PIctured with mounted LS400 calipers.
Fig is offline
post #9 of 16 (permalink) Old 05-15-2011, 03:03 AM
Here is the black anodized one Mike mentioned above. this is a MUST have if your car is lowered more than an inch. Better to have coilovers as you will have to raise your car up 17-20mm after install.
carboy219 is offline
post #10 of 16 (permalink) Old 06-18-2011, 09:11 AM
why do you have to raise the car up after the install?
Jerm__ is offline
post #11 of 16 (permalink) Old 06-18-2011, 09:55 AM
The spacers lower the front by a hair (half inch or so).
Team Image Dynamics/Zapco/Second Skin/Werewolf
IASCA/MECA SQ judge and competitor
winslow is offline
post #12 of 16 (permalink) Old 12-06-2015, 07:27 AM
Quoted: 20 Post(s)
Taking back a very old thread from the dead but wanted more clarification on this part.
Question 1, is there any reason why Is300 only have the front RCA avaible? Rear doesn't experienced the same kind of problem with lowered suspension? (Asking because I had all 4 on my Previous Mr2.... I know suspension is not made the same way that's why I'm asking)
Question 2, seeing that this thread is from 2011 and Fig's mentionned they were not listed on the site.... now they seem to have it Am I correct on that?
Question 3, what's the difference between the Fig's one that are 17mm and the Megan Racing that are 30mm..... Once again My previous Mr2 had something like 31-32mm (1 1/4'') front and 13mm rear (1/2'')..... With Original Tom's made in Japan RCA
Previous cars:
2005-2006: 1997 Paseo SOLD
2006-2010: 1991 Mr2 LHD T-Top SOLD
Winter 2006:1990 Camry Beater SOLD
2007-2009: 1997 Paseo 1.3 Turbo SOLD
2009-2010: 2005 Echo RS Daily Drive SOLD
2010-2012: 2007 Tacoma X-Runner SOLD
2010:2015: 1994 Mr2 1994 Hardtop LHD 3sge Beams Turbo SOLD
2012-2013: 1998 Tercel SOLD
2013-2015: 2010 Corolla S SOLD
2015-??: 2001 Lexus Is300
mr2mkii is offline
post #13 of 16 (permalink) Old 02-23-2016, 10:01 AM
Fig
THE MAKER
Fig's Avatar
Quoted: 20 Post(s)
Here you go.
1. the rear is multi-link, so there is no single point of intersection to add a spacer. Furthermore the sum of the links controls rear steering and the overall toe curve is severe from the factory making it steer steeply when lowered. Or rear LCA and toe link combo defeat the rear bumpsteer and create stability when the car is loaded in a corner.
2.3. We have our universal dowel version on the site and the 17mm height is derived from the minimum requirement to clear LS400 calipers.
In reality, since you have a double wishbone up front the changes to roll center can be more controlled by linkage length than a spacer. Our geometry correction products like bushings and our rear link setup will balance out the overall bumpsteer to stabilize traction more than a simple spacer. You will get more grip from swapping out the #2 bushing that by changing the camber curve. The MR2 is strut based up front so the only camber gain you get is from the arc of the lower arm. On a double wishbone you typically get a lot more camber gain as the upper and lower arms are different arc lengths, making the top pull in on compression.
Mike
Fig is offline
post #14 of 16 (permalink) Old 02-02-2017, 11:35 PM
Quoted: 29 Post(s)
In a previous post you stated that the RCAs were good for people who are lowered 1.5-2". I'm currently lowered about 1.5" on Koni struts and H&R springs.
The steering is dropped 1.3" which should be perfect for people lowered 1.5-2" Other than that ride height is unchanged
I have bump steer and occasionally hit my inner fender wall, I was suggested your RCAs but I am confused as to what size to get. You offer 17mm and 34mm.
Do I choose the 34mm spacer to balance out the ~38mm drop on my car or is the 17mm sufficient? Thanks
khrisz is offline
post #15 of 16 (permalink) Old 02-03-2017, 11:38 AM
Fig
THE MAKER
Fig's Avatar
Quoted: 20 Post(s)
The RCA will not fix any interference you are seeing now. but it will help bumpsteer. What shocks and springs are you running? Keep in mind that the RCA will lower the car further. We make drop out tie rod ends to help fix this without a drop.
Fig is offline
