LS400 calipers install - Page 3 - Lexus IS Forum
post #31 of 107 (permalink) Old 03-02-2012, 08:51 AM
Originally Posted by ZhiuPei View Post
My caliper came with this electronic cable with a plug. Do i just take it out?
Any input ill really appreciated
Thats for the dumby light in the car on the LS400 so you can take that out.
Im your local smarta$$
leonard_is300 is offline
post #32 of 107 (permalink) Old 03-02-2012, 10:00 AM
awesome thanks
Stan
ZhiuPei is offline
post #33 of 107 (permalink) Old 03-02-2012, 10:42 AM
I went with this setup:
Front:
Supra TT Calipers
Hawk HPS Pads (Supra TT)
Powerslot Slotted Rotors (Supra TT)
Figs Supra TT Adapters
Rear:
Hawk HPS Pads (IS300)
Powerslot Slotted Rotors (IS300)
All:
Goodridge SS Brake Lines (IS300)
ATE Super Blue Fluid
All I had to do was cut the front dust shield to fit the larger caliper
2001 Lexus IS300 SBM Tanabe Concept G Catback Exhaust Toyomoto Exhaust Manifold SRT Short Ram Intake VISRacing OEM Carbon Fiber Hood Enkei PF01 18x8/9 +45 Tein SuperStreet Coilovers Oracle XE 6K CCFL Halo Kit
darksparkz is offline
post #34 of 107 (permalink) Old 03-02-2012, 11:55 AM
Jerm__ is offline
post #35 of 107 (permalink) Old 03-02-2012, 01:56 PM
DarkSparkz thats the setup I have now and I am going from that to the LS400 Caliper setup.
post #36 of 107 (permalink) Old 03-02-2012, 02:20 PM
^When I upgrade my calipers i think i'm going to go the TT route, although the LS400 calipers are much lighter they lack the aftermarket support in terms of pad and rotor choice
Jerm__ is offline
post #37 of 107 (permalink) Old 03-02-2012, 08:05 PM
Yeah the LS400 calipers lack support but if you know the right people you can have anything made.
post #38 of 107 (permalink) Old 03-04-2012, 08:16 PM
Quoted: 23 Post(s)
as far as pad selsction the LS400 has a decent selction, EBC and hawk both make their street level compounds(greenstuff & HPS) so for someone just looking for a better street setup that would rarely see the tracks LS400 and either of those pads should work okay.
as for rotor selection, while drilled/slotted/both rotors look cool it provides less contact area and eats pads quicker, also costs signifigantly more so blanks are really the way to go
broketuner is offline
post #39 of 107 (permalink) Old 03-04-2012, 08:27 PM
I only run blanke rotors, for the street I have actually noticed I have less performance with drilled and slotted. If these LS400 calipers do work out they I would like, well then I'll just go with a front BBK soon after. I have the TT caliper setup as of now and I like it but I would like to try this just for the hell of it.
post #40 of 107 (permalink) Old 03-06-2012, 10:23 AM
are the Figs RCA adapter required to make the LS400 calipers fit? I'm not running coilovers, just springs. So dropping the car anymore could pose a problem for me.
Why mod, when you can ride STOCK...at 11 psi
jahnIS300 is offline
post #41 of 107 (permalink) Old 03-06-2012, 11:18 AM
Quoted: 19 Post(s)
Yes, LS400 calipers will NOT fit without the RCA spacer.
Go TT if you don't want to deal with the spacer.
white_is is offline
post #42 of 107 (permalink) Old 03-06-2012, 01:17 PM
I don't think it matters what kind of suspension setup you have, you need the spacers. As far as I know they are on a slight back order but more will be in stock later this week.
I have my caliper overhaul kit so I will re build them and paint them and make them look pretty and post some pictures.
post #43 of 107 (permalink) Old 03-06-2012, 04:22 PM
I didn't mean that my suspension will determine I need the spacers or not, I just was concerned that I won't be able to adjust the height I would be too low, and way out of spec for alignment.
Looking forward to seeing your end result. Where did you get the rebuild kit from? I might need to look into those as well.
post #44 of 107 (permalink) Old 03-06-2012, 04:32 PM
I'm concerned about the TT adapters. What is the best way to line them up and press them in?
post #45 of 107 (permalink) Old 03-06-2012, 05:19 PM
Quoted: 19 Post(s)
I posted the part number for a rebuild kit straight from Lexus on the first page. If you pull the caliper apart make sure you don't lose the two small square cut o-rings between the two halves, you can't buy them from the dealer and they are not included in the rebuild kit.
Part Number is: 04479-50091
DIY: LS400 Caliper Install
white_is is offline
