FIGS PROAngle Front Steering Angle Kit for Competition Drifting. - Lexus IS Forum
post #1 of 29 (permalink) Old 01-11-2014, 03:32 PM Thread Starter
Fig
THE MAKER
Fig's Avatar
Quoted: 20 Post(s)
I guess we should start a thread on our new kit that is now shipping.
PROAngle is the name we have coined for our top of the line competition steering angle kits. These kits feature a ground up design and incorporate various components at different price points to serve the evolving Lexus drift market.
2013 is the year PROAngle was developed. Starting with several tube prototypes the final "Competition Kits" evolved into an array of 200 components all serving specific and unique purposes to achieve the highest steering angle possible. Everything has been thought through from wheel clearance to strength support at full lock to serviceability and modularity, we wanted this kit to exceed anything else on the market in build quality and design regardless of platform.
PROAngle kits offer up to 70* degrees of steering angle with full steering rack travel.
Featured on the Team Japspeed Maxxis IS200 that Ryan Tuerck competed in the BDC RD 4 at Lydden Hill .
Our site category link FIGS PROAngle
Hundreds of hours of development and testing have produced the most advanced and complete steering angle kit available for the Lexus IS300 and derivative chassis (SXE10, X-Chassis, GXE10). An easy to set up, extremely strong and resilient kit that stands up to pro competition is finally embodied in our first public release. Over 200 components, many of them custom-designed, allow up to 70* degrees of steering angle and clearance adjustment. This kit is intended for pro/pro-am drivers in sanctioned competitions not for street use.
"The Competition Kit"
Our kit is a complete bolt-in kit for the entire front suspension. Only the factory spindle is reused. The kit utilizes factory chassis mounting points, making it legal in the Formula Drift Pro Class 2014 rulebook. You will need aftermarket or flared fenders with at least 2-2.5" of extra clearance.
Price: $2799
Preorder Special: $2199 shipped with default powdercoating. $700 min deposit due.Delivery of first kits Mid Dec 2013. Shipment upon payment of balance.
Competition Kit Features:
-Increased front track by 2-3" per side.
-Mobility to adjust control arms forward for increased caster and firewall clearance.
-Boxed upper control arm with 2 degrees of sliding static caster adjustment. 3 degrees of camber adjustment. Camber adjustment requires dismount. TIG and MIG mixed process welded.
-Mild steel plate lateral control arm with up to an 1" of track width adjustment. Caster arm mounts via 2 bolts. MIG welded by default. TIG welded version available for additional cost..
-Adjustable tubular fabricated, oversized caster arms for increased strength and tire clearance.
-High steer clevis-style knuckle to distribute shear load and provide 0 static Ackerman steering. Ackerman at full lock is 10 degrees different between leading and trailing wheels, the latter having less angle. TIG welded steel construction.
-Adjustable steering stop plates.
-Designed to work with factory brake caliper. Additional angle is possible with a low profile caliper.
-Designed for front sway bar elimination. Sway bar use is possible, but will decrease steering angle.
-Fabricated steering rack combo spacer and offset adapters with spherical bearings. These eliminate inner tie rod ends and make the entire steering connection a swaged 7/8" tube vs the 14mm connecting rod of most inner tie rod ends. High load wide spherical bearings can withstand 7730 lbs axial load rating.
-3/4" PTFE-lined spherical rod end used at inner and knuckle mounts, providing precise steering and serviceability.
-5/8" PTFE-lined spherical rod end used at steering connection to outer knuckle with bump steer adjustability.
-Massive 1" PTFE-lined spherical rod ends used in caster arm for rigid chassis mount.
-Extended braided steel brake lines included with kit for increased track and routing options.
-Finished in FIGS standard grey powdercoat. Ceramic coating option is available for greater impact resistance.
Setup Requirements for Maximum Angle
-Kit requires upgraded front triangle brace to support load on the Caster arm mounts. Brace should have increased plate thickness or stiffness on the connection between the 2 chassis supports and the #2 bushing mount.
-Wheels: ideally 17x8" or 18x8" with +30 to +20 offset.
-Tires width 225-245
-2.5" fender flares or widebody fenders.
-Springs rates of at least 14k front, 16k suggested. 2 ways adjustable shocks.
-Low profile BBK or caliper setup similar to our aluminum caliper kits.
Competition Spares
Drifting is a destructive, unrelenting motorsport. While our kits are designed with the highest strength in mind, sometimes tandem battles and off-track incidents lead to damage. Our kits are designed to be serviceable and each component is available separately. Contact FIGS for replacement spares.
Customization
Due to the modular knuckle design, we can create custom Ackerman angles on request. We advise trying the kit first as-is and then placing a request if you would like specific changes. We are here to make your kit the best it can be for You, the driver.
Warranty
Unfortunately, we cannot warranty any component failure due to collision or off-track incident. We will warranty parts due to craftsmanship defects under normal use for the period of one year. Rod ends are considered wear items and are not covered under any warranty unless defective on initial use. All claim approvals are at the sole discretion of FIGS to determine what will be covered and applies to original purchaser only.
* Requires precise wheel and tire specs, consult FIGS for suggestions. Max angle is a balance of steering rack travel, arm length and tire and wheel clearance. Due to these factors each vehicle will need slight tuning initially to optimize performance. Factory steering rack travel is 100% utilized and this max have long term effects on the rack. Currently, factory steering rack boots are removed with this kit.
For specific questions please read the product specification and then feel free to contact us.
Fig is offline
post #2 of 29 (permalink) Old 01-13-2014, 11:11 PM Thread Starter
Fig
THE MAKER
Fig's Avatar
Quoted: 20 Post(s)
first kit orders finally wrapped up and dropped off at coating.
Fig is offline
post #3 of 29 (permalink) Old 01-14-2014, 11:40 AM
fuhhh
04 GGP 5 SPD w/ LSD
Stance|Swift|Figs|Hotchkis|Ichiba|5zigen|SRT|Dezod
04 MSM Totaled Parts Thread // IG-slide4satan
Negleceted FC3S
dylyxcore is offline
post #4 of 29 (permalink) Old 01-18-2014, 04:59 PM Thread Starter
Fig
THE MAKER
Fig's Avatar
Quoted: 20 Post(s)
Some component pics. You can see how many custom parts this requires.
Fig is offline
post #5 of 29 (permalink) Old 01-20-2014, 06:20 AM
Are we going to be able to buy the kit without the upper arms? Or is this setup useless without all the pieces? Basically will I need to sell my cusco control arms to run your setup.?
juangado is offline
post #6 of 29 (permalink) Old 01-20-2014, 08:39 AM Thread Starter
Fig
THE MAKER
Fig's Avatar
Quoted: 20 Post(s)
Yes juangado the uppers are necessary because they are longer than stock by 1". This optimizes for a -4 degree camber setup. If you used the cusco arms I would expect you would be around-10
Fig is offline
post #7 of 29 (permalink) Old 01-20-2014, 08:59 AM
Fokai 1008
Quoted: 9 Post(s)
Must fight desire to buy this until car runs(both of them). I may have to buy this in individual parts so my lady doesnt murder me when she see's the bank statement LOL
ISR220 Build
http://my.is/forums/f219/isr220-neo-...2011-a-391109/
Adam P is offline
post #8 of 29 (permalink) Old 01-20-2014, 02:42 PM
great r&d work on this kit props to you
SXE10 Crew NY
2002 GGP 5 Speed 2JZ-GTE VVTI
AEM V2 Dezod PNP|Precision 6765|Tial 38mmWG|HKS SSQV V3|750HP Mishimoto FMIC|SRT 3"Exhaust|CXRacing downpipe
Forgestar F14|ISC Coilovers|VIS Carbon Hood|VIS GReddy Rep Front Lip|VIS Vertex Rep Side Skirts|VIS TRD Rep Rear
follow my build on instagram
IG: Andylex
My 2JZ-GTE VVTi build thread
Andylex is offline
post #9 of 29 (permalink) Old 01-21-2014, 12:36 AM Thread Starter
Fig
THE MAKER
Fig's Avatar
Quoted: 20 Post(s)
more pics. I am just realizing I forgot the last 4 bolts that connect to the spindle. But will add them.
Fig is offline
post #10 of 29 (permalink) Old 01-21-2014, 06:39 AM
Jerm__ is offline
post #11 of 29 (permalink) Old 02-10-2014, 08:06 PM
Quoted: 10 Post(s)
Ouch pocket burner for some steering
1992 Toyota Celica GT 5speed 3sgte swapped - SOLD
1992 Toyota Celica All-Trac - SOLD
1997 Civic EX Turbo 300whp 295tq - SOLD
2001 IS300 Auto - SOLD
2010 Subaru WRX Stage 3 328awhp - 387awtq - SOLD
2003 IS300 Pearl White 1jzgte VVTi - R154 - LSD - Tomei M8280 - 22psi - 418rwhp - 380rwtq
www.radfordracing.com
LexusSpeed01 is offline
post #12 of 29 (permalink) Old 02-11-2014, 10:12 PM Thread Starter
Fig
THE MAKER
Fig's Avatar
Quoted: 20 Post(s)
You an me both. Even at this price its still almost more trouble that it is worth to assemble, adjust and procure all of the components.
tbkallday likes this.
Fig is offline
post #13 of 29 (permalink) Old 02-25-2014, 04:28 AM
Bezik777's Avatar
Quoted: 36 Post(s)
Awesome work figs!!
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #14 of 29 (permalink) Old 02-25-2014, 09:05 AM
WOW awsome goodies
Do you think you could create some parts list with seperate prices?
For me example it would be interesting, since I already spent some money on susupension parts and wouldn't need a whole kit any more.
Click Link to... .
My Project II
RoadRash is offline
post #15 of 29 (permalink) Old 02-25-2014, 08:24 PM Thread Starter
Fig
THE MAKER
Fig's Avatar
Quoted: 20 Post(s)
Roadrash currently all parts are designed to work together but not with anything else. Each is necessary to make the other function in the right range.
Fig is offline
