We have several colors and applications for our 3528 high-powered LED strip.
The great part about this product is the ease of use and installation! It is made to be used in just about any case where you need to add lighting.
- Can be cut down to any length and still be re-used.
- Real 3M self-adhesive backing makes installation a breeze.
- Super-Bright output, it only takes a couple inches of this strip to highlight an area of your ride.
We have this strip available in:
* Cool White
* Warm White
* Blue
* Red
* Green
* Amber (Orange)
* UV Purple
* Hot Pink
* RGB (Color-Changing)
We keep thousands of feet of strip in stock at all times so just let us know what you need!
The Exterior Version is 100% Waterproof and can be mounted on the outside of the car:
Flexible SMD Strips (Exterior)
The Interior Version is also available here:
Flexible SMD Strips (Interior)
We have pre-made 3' Sections (perfect for grills and trunks) available here:
ORACLE Flex Strip 3' Sections
The ColorSHIFT version can change colors and requires a controller:
ORACLE RGB LED Strip
RGB Color Changing Demo:
RGB Installed in 2010 Camaro:
The fun does not stop there, this is truly a universal product it can be used in your home as well!
Use it to make cool wall art:
It took less than 5 ft of this to make this busa shine!:
Installed in Grill:
Installed in Amp Rack and Speaker Box:
Bar Shadowboxes:
