VDIM Disabilization - Lexus IS Forum
post #1 of 22 (permalink) Old 10-23-2009, 09:32 PM Thread Starter
VDIM Disabilization
Hey I found this on a website. Never heard of it before:
Some people may already know this, so it may be useless to them...
IS350/IS250 VDIM Cheat Code
The vehicle dynamics integrated management (VDIM) system automatically prevents excess wheel spin and fishtailing. If you deactivate the system by pushing the dash button, the system automatically comes back on after exceeding 30 mph. The overly protective Toyota designers probably did this to reduce our insuance rates, but it's just no fun. If Toyota wants to really compete with BMW, then it needs to allow drivers to make more decisions and assume the risks of driving.
If you wish to temporarily disable the VDIM completely, Toyota programmed a work-around. This "cheat code" will disable the VDIM until the car is truned off.
1. Start the car with the parking brake on.
2. Keeping the parking brake on, push (or tap) the foot brake twice
3. Keeping the foot brake down, push (or tap) the parking brake twice
4. Repeat untill the sliding car warning light appears on the dash
Normally, only two cycles (foot - parking - foot - parking) are required. With practice, you can disable the VDIM in under 4 seconds.
IS350 IS250 VDIM Cheat Code - Disable traction control - burnout, peelout, donut, smoke tires
T.Chung_05h is offline
post #2 of 22 (permalink) Old 10-23-2009, 10:35 PM
Or you can just hold the TRAC button on the dash down for a few seconds. That works pretty well too on 07+ models
(the trick you posted is only required on 2006 models, and has been known for years)
Knightshade is offline
post #3 of 22 (permalink) Old 10-23-2009, 10:48 PM Thread Starter
oh..... nice man. Did not know that. too bad there isnt something we could do that would let us shift higher hahaha
Hey Knightshade, do you know if shift-times w/ tiptronic is faster than the paddles?
post #4 of 22 (permalink) Old 10-24-2009, 09:41 AM
The best shifts (from a dead stop, at wide-open-throttle) will be if you leave the car in D, and leave the ECT button in normal mode.
The paddles and the stick don't actually shift the car, they only select the highest gear the car is allowed to use. The transmission always shifts automatically on its own based on what the computer tells it to do, even if the paddles can fool you into thinking you're doing something about it.
If you'd like proof there's no direct shifting go ahead and start from a dead stop in S mode with 4 on the dash. Now switch the multi-display to showing you the -actual- gear you're in... it'll be 1. It'll shift on its own through 2, 3, and 4 as the ECU dictates, only stopping at 4 because that's the highest-allowed-gear you selected.
For that matter, start the same way, with S-4, and displaying real gear in use... now very slowly push the gas... at 10 mph, hit the downshift on the stick or paddle... the S indicator will switch to 3, but the car won't shift at all, because at 10 mph you weren't in 4th anyway, you were likely in 1 or 2, which is below the max allowed gear of 3 anyway.
post #5 of 22 (permalink) Old 10-24-2009, 11:29 AM
So anyone know how trackable this is? I'm still trying to figure out how much of the dash/disable cheat will void your warranty when you go in with transmission problems. Does the ECU log changes to the stability system like these?
MYIS18 is offline
post #6 of 22 (permalink) Old 10-24-2009, 04:17 PM
Turning off the VSC/TRAC with the dash button, on 07+ models, is explicitly explained in the owners manual- it absolutely should have 0 impact on warranty claims regardless of being logged or not since the owners manual instructs you in how to do it.
post #7 of 22 (permalink) Old 10-24-2009, 04:43 PM
Makes sense what about this cheat for 06's?
MYIS18 is offline
post #8 of 22 (permalink) Old 10-24-2009, 06:05 PM
Why would it be any different? Why would Lexus enable this mode if it weren't meant to be used by the owner?
-Chris
[ '94 Supra TT :: BPU, 17psi | '06 IS350 base :: S-techs, F-sport sways, 5AD 19" S5F's in gunmetal ]
four o two is offline
post #9 of 22 (permalink) Old 10-24-2009, 10:27 PM Thread Starter
Sorry to go off topic, but what im getting from many posts is that just driving the car in D, and turning the traction control off, is the fastest way to go. From peoples experience, what is the most ideal launch RPM? does holding the brake and gas compromise my driveline or transmission? I read in the car manual, to not hold the brake and gas at the same time?
post #10 of 22 (permalink) Old 01-10-2010, 06:21 AM
lexus did this to keep the insurance companies happy
06 IS350 - C/TR202
vinconist is offline
post #11 of 22 (permalink) Old 02-18-2010, 05:39 PM
so....whats the benefit of shutting off the VDIM? sorry, im a newb.
giantdefy is offline
post #12 of 22 (permalink) Old 02-18-2010, 06:09 PM
Sporty driving.
Power slides.
Donuts.
Drifting!
cdeslandes is offline
post #13 of 22 (permalink) Old 02-18-2010, 06:12 PM
and this doesn't shut down VDIM, just two parts of it (VSC and TRAC)
post #14 of 22 (permalink) Old 02-19-2010, 04:18 PM
will it help launch the car faster?
post #15 of 22 (permalink) Old 02-19-2010, 05:23 PM
If you know how to launch with minimum tire spin, perhaps.
