Super Clearance ** JUN-TW IS250/350 BBK Kits** - Lexus IS Forum
post #1 of 1 (permalink) Old 11-23-2011, 02:19 PM Thread Starter
Supporting Vendor
L-tunedparts.com's Avatar
Hey guys
We have a very good special --- ONLY 1 IN STOCK --- deal for you guys
For your IS250/350 06-09 (Make sure to verify if your wheels are BBK Clearance)
First up is the 6pst 355x32 mm rotors BBK KIT
Retails at well over $3100.00
For this one set only
SOLD (+30.00 flat rate shipping lower 48 states)
** PLEASE CALL JOSE AT 310-522-2384 TO PLACE AN ORDER **
Here are the specs on this kit
Introducing the all new JUN-TW 6-piston big brake kit. The calipers and rotors consist of high grade ultra light weight 6061-T6 Aircraft aluminum. The calipers are highly resistant against extreme temperatures and virtually indestructable design. The matching rotors are two-piece construction, ultra light weight cross-drilled vented. Our Big Brake Kits also includes the JUN-TW high performance brake pads (friction no/0.70u), and steel brake lines
The individual parts material construction is as follows
1 ) Brake caliper T6061 Aircraft aluminum
2 ) Brake rotor FC25 material element and the degree of hardness is between 170-190 degrees
3 ) Brake pads High friction coefficient material element at 0.43u~0.7u
4 ) Bracket adapter 2617 aluminum and strengthen of the processing
5 ) Rotor center bell T6061 Aircraft aluminum
6 ) Brake line High pressure metals pipeline
Next up is the 4pst 330x30 mm rotors BBK KIT
[/B]
SOLD(+30.00 flat rate shipping lower 48 states)
Introducing the all new JUN-TW 4-piston big brake kit. The calipers and rotors consist of high grade ultra light weight 6061-T6 Aircraft aluminum. The calipers are highly resistant against extreme temperatures and virtually indestructable design. The matching rotors are two-piece construction, ultra light weight cross-drilled vented. Our Big Brake Kits also includes the JUN-TW high performance brake pads (friction no/0.70u), and steel brake lines
Regards,
Jose Arana
Internet Parts.
1-800-908-6968 ext. 2384
310-522.2380
The Ultimate Lexus Store
Reach me on AIM M-Fri 7a-5p at screen name LtunedParts
Carson Toyota/Lexus/All JDM parts
"Original my.IS Vendor since 2006"
L-tunedparts.com is offline
  Lexus IS Forum > Supporting Vendors > L-TunedParts.com
