How to check the transmission fluid level? - Lexus IS Forum
  • 1 Post By Knightshade
post #1 of 9 (permalink) Old 06-29-2011, 12:15 PM Thread Starter
Any one know how to check the transmission fluid level? I try to find answer, but no luck.
2006 IS250 AWD Silver/Black
chenmoon is offline
post #2 of 9 (permalink) Old 06-29-2011, 12:40 PM
Quoted: 71 Post(s)
there is an entry point alongside the drain plug under the transmission casing that allows the level to be checked, but it is not intended to be a driver check item.
post #3 of 9 (permalink) Old 06-29-2011, 12:44 PM
the second gen IS automatic is a sealed transmission. There's no dipstick and it does not require any routine servicing.
If you ever had a repair or something that caused a loss of fluid you would restore to the proper level using this procedure (which is basically to fill until some comes out of the overflow plug hole):
garrickbislip likes this.
Knightshade is offline
post #4 of 9 (permalink) Old 06-29-2011, 02:33 PM Thread Starter
You mean we never need to change the Tranny fluid, even is at 123,000Km?
Also, how to get the procedure manual?
Thanks.
chenmoon is offline
post #5 of 9 (permalink) Old 06-29-2011, 06:01 PM
Thanks.
Not only do you not need to, it's physically impossible to change more than 10-15% or so of it at any time.
It's a sealed transmission with lifetime fluid.
I attached the page with how to refill (using the overflow method) in my earlier post, just click on the attached picture and it has all the steps/diagram/info there.
The same info also shows you how little fluid you can remove even if you drop the pan entirely (only about 1.5L out of a system that holds like 9)... hence why you can't change the fluid...there's no way to remove even a quarter of it (short of taking the entire thing apart...and even then you'll only get about 1/3 (removing the valve body) or a bit under half (removing the torque converter)
post #6 of 9 (permalink) Old 07-06-2011, 05:29 AM
Interesting, I did not know about the sealed trans. One less fluid to have to change !
diablo1714 is offline
post #7 of 9 (permalink) Old 07-06-2011, 05:44 PM
Bummer! I feel jipped! I was at the dealer and I was charged $180 to replace my ATF. The Service Advisor made it seem really important, and I fell for it! I called trying to cancel it, unfortunately, the service has been done on my IS250.
warrior1212 is offline
post #8 of 9 (permalink) Old 07-06-2011, 06:40 PM
Heh... well, congrats, you just got about 10% of your fluid changed!
(which about how much pulling the drain plug will get ya)
Assuming you're in the US though I'd probably go back to him with the owners manual in hand and ask why he just billed you for a service the manual explicitly states is never required and shouldn't be done.
post #9 of 9 (permalink) Old 07-08-2011, 10:59 AM
I will write a letter to both the dealer and Lexus. Hopefully I get something out of it, like a free oil change at the very least.
They fixed the cranking noise when I start my engine for free (covered under warranty), and then got pressured for the transmission oil change.
  Lexus IS Forum > Owner's Forums > IS250 Owner's Forum
