My Horn Stopped Working.... - Lexus IS Forum
post #1 of 19 (permalink) Old 08-31-2008, 12:46 PM Thread Starter
Any suggestions on why??
i was picking up a friend and i was gonna do the 2 horn warning, to let him know i was there.
It honked once but then the 2nd one didn't go off.....now whenever i press it, it doesn't honk
I now carry my Airhorn in the car, lol
01 MSM E-Shift
Carson-tuned front & Rear bumper || Custom Altezza grille || RMM side skirts || UGO roof spoiler || TRD wing || K&N FIPK II || Titan Cam Gear || SAFC II || TBKO Headers || HKS Drager II || Stage 1 Valve body || B&M Tranny cooler || Rotora rotors || WORK Emotion CR-Kai || Tanabe sustec sways || SRT member braces || ARK Coilovers || Gloss black vinyl roof ||......
B_is300 is offline
post #2 of 19 (permalink) Old 08-31-2008, 07:20 PM
Quickest thing to check is the fuses, though if you blew one it might be a good idea to try and find out why before you just replace it. THey are only suppose to blow if something is wrong.
JustinC is offline
post #3 of 19 (permalink) Old 08-31-2008, 10:29 PM
Quoted: 20 Post(s)
Probably not the fuses, but check anyways first.
I'm on my 4th set of horns. When you actually remove them you will find water and debris inside one of the horns or both.
My guess is they crapped out.
With my horns I used to park in an under ground parking and used them every day (going around corners). So I wore them out fairly quickly.
Just remember when you have to put in new ones, the dealer wants big numbers, I have used the cheap hi/ lows from Canadian tire. They virtually sound the same at a considerable less cost than the dealer.
Digger08
digger08 is offline
post #4 of 19 (permalink) Old 08-31-2008, 10:49 PM
Quoted: 18 Post(s)
I did the horn mod and the horns worked fine.
When I went to reattach them mine stopped working. Disconnected them and cleaned em out and they started to work again. Kind of wack if u ask me.
Play around wit it and the connections.
Boost and Stuff- 2004 CW Turbo IS300 5MT LSD
354rwhp / 320lb ft @ 7.5PSI
Daily and Stuff- 2003 AR IS300 5AT LSD
rL-gT is offline
post #5 of 19 (permalink) Old 06-04-2010, 11:13 PM
lexusecutive's Avatar
RedlineGT, Digger, any suggestions?
its not the fuses, power is getting to the connector.....did a quick light probe test.
can you take them apart to clean them?
Canadian tire sells aftermarket ones? are they plug and play?
TEAM LEXUS IS300 GRAND AM RACECAR!: JRZ 3-way dampers | V160 6spd | BBS RG-R | MOTEC | Pi Research ECU
Daily Driver: '13 4Runner Trails edition
Fri/Sat/Sun car: Scion FR-S Whiteout, RAYS 57Xtreme
'01 IS300 on MOTON Clubsports & Vortech Supercharged - SOLD!
lexusecutive is offline
post #6 of 19 (permalink) Old 06-04-2010, 11:23 PM
Peter at next mod had hella horns instock last I check. Our stock horn does sound pretty whimpy. Can't have the Batmobile sounding off "meowwww's", right?
My pix whoring thread
Johnnysks is offline
post #7 of 19 (permalink) Old 06-05-2010, 11:29 AM
Quoted: 20 Post(s)
I just used the every day Fiamm horns from CTC (Hi & Low)
You will probably have to fiddle with the wires a little bit...but more or less just plug and play.
These have been working for me for many years now, and I forget what I did 5 years ago when I last changed them.
Digger08
digger08 is offline
post #8 of 19 (permalink) Old 06-06-2010, 04:38 PM
So the OE horns are a solid 100% more expensive then the Canadian tire horns. So I went to CT to see what they had.
FIAMM seems to be the horn supplier for CT and they had 3 grades:
1) Horn - low and high sold separately, $21 each
2) Highway horn (5 dB louder) - low and high sold separately, $29 each
3) El Grande, $37 for the pair of high and low
So I went the cheapo route and got the El Grande.
They install w/ ease and are loud. Does the job, but I can see how flimsy they are and will likely not last as long as OE. But lets see. The OE ones lasted 9 years and 208,000km.
Note: I did not face the red side out. They are black and hidden just like OE.
post #9 of 19 (permalink) Old 06-06-2010, 07:28 PM
Quoted: 20 Post(s)
Those are cheap. I must have gone the middle of the road, because mine are very close looking to OEM and sound exactly the same.
Beep Beep!
Digger08
digger08 is offline
post #10 of 19 (permalink) Old 06-06-2010, 07:45 PM
ya. these seemed cheap, but its only the red cover that seems ghetto. The other side looks like an OE horn (the side the faces out).
These sound like OE .....I would even say louder.
post #11 of 19 (permalink) Old 06-06-2010, 09:13 PM
you didn't by chance do the horn relocate did you?
HappySMP
2002 Stage II L-Tuned IS300 - My Build Thread
happysmp is offline
post #12 of 19 (permalink) Old 06-06-2010, 09:18 PM
Quoted: 18 Post(s)
Check the bolts that attach the horns to the rad support! They act as a ground for em!!
rL-gT is offline
post #13 of 19 (permalink) Old 06-06-2010, 09:35 PM
my point exactly!
HappySMP
happysmp is offline
post #14 of 19 (permalink) Old 06-07-2010, 06:24 AM
ya. when the supercharger was installed, the FMIC relocated the low-side horn.... also, when the horn was being removed, the metal of the rad support completely gave and tore off.
So I've relocated the horns to mount off the centre hood-latch bolts. So they're more central now.
Used the horns a few times coming in this morning!
post #15 of 19 (permalink) Old 06-07-2010, 08:29 AM
Quoted: 18 Post(s)
I did the same thing but also ran a wire from the horns back to their original location so they could be grounded.
rL-gT is offline
  Lexus IS Forum > Regional Forums / All Together Now > Canada
