My right turn signal blinker stays lit whenever its in use. Even if the turn signal stalk is set in the center position, it does not turn off at all. The Turn Signal Relay/Flasher still clicks whenever I use the signals left or right, but for some reason the right turn signal stays lit, not even flashing. The only way I get rid of it is when I use my hazards for a couple of seconds and it's able to turn off. Even weirder, when I turned off the car and remotely lock the doors, the right turn signal would stay lit.
I have a video included of exactly what the problem is.
https://youtu.be/bYBl9qsJMlo
