b
Go Back   my.IS - Lexus IS Forum > Lexus IS > Roadside Assistance
» Log in
Not a member yet?
Register Now!
» Wheel & Tire Center
Sponsors
Sponsors
Old 02-01-2006, 11:44 PM   #1 (permalink)
moonlight has been a helpful user
replacing front map dome light
ok so i just figured it out - was having the same problem as many on here. maybe i can describe it to other newbies. my is300 has the sun roof. there are 3 main components:
component 1. "guts" of moon roof wiring and buttons which includes the tilt, open/close sunroof and front map dome light on/off button. This core piece is recessed in ceiling and screwed into the roof. It also houses the actual light bulb.
component 2. Plastic (grey in my case) cap or cover (between pops off from component "1".
component 3. Clear plastic lense. DO NOT TRY TO POP OFF CLEAR LENSE - IT IS PERMANANTLY BOLTED TO THE THE PLASTIC COVER (ITEM 2).
Do not pull TOO hard on the entire thing or you may damage the "1". But you do have to put some effort into snapping "2" off from "1". There are 2 little claws on the side near the rear that need to get unclipped.
Here is a final picture after I finally got it off:
<br>
<br>
the bulb read: "LIFE 12V10W-C" on the metal part.
hope this saves someone the frustation i was facing!
moonlight is offline Reply With Quote
Old 02-01-2006, 11:49 PM   #2 (permalink)
AZNHYPNOTIQ is an elite community memberAZNHYPNOTIQ is an elite community memberAZNHYPNOTIQ is an elite community memberAZNHYPNOTIQ is an elite community memberAZNHYPNOTIQ is an elite community memberAZNHYPNOTIQ is an elite community memberAZNHYPNOTIQ is an elite community memberAZNHYPNOTIQ is an elite community memberAZNHYPNOTIQ is an elite community memberAZNHYPNOTIQ is an elite community memberAZNHYPNOTIQ is an elite community member
haha I'm sure this might be helpful to others. Great contrubuter to the .net community! Welcome, and great first thread!
2002 GGP IS300 5spd
~~>Underconstruction<~~
Max Tq @ 98hp and Max Hp @ 199hp
AZNHYPNOTIQ is offline Reply With Quote
Old 02-05-2006, 09:06 AM   #3 (permalink)
MaxOctane is an unknown at this point
where are these two plastic claws? Everytime I try to pull it off it looks like I'm trying to take out the entire component 1 and component 2. Should I be pulling from the front, or the back? Did you use a flathead screwdriver? Any help here will be appreciated. Thanks.
MaxOctane is offline Reply With Quote
Old 02-05-2006, 12:44 PM   #4 (permalink)
2005 ToyDrive Participant
James_F is an upstanding community memberJames_F is an upstanding community memberJames_F is an upstanding community memberJames_F is an upstanding community memberJames_F is an upstanding community memberJames_F is an upstanding community memberJames_F is an upstanding community memberJames_F is an upstanding community memberJames_F is an upstanding community member
From the picture, it looks like you would want to pull from the side nearest the sunroof.
James_F is offline Reply With Quote
Old 02-05-2006, 07:39 PM   #5 (permalink)
the two claws are on the side facing the back, you can kinda see the features on "1" on that pic. try pushing on the center of one of the buttons (or a couple buttons) while you pull down on the plastic cover. this should separate the two. but dont break your buttons.
02 IS300
Old 02-08-2006, 03:07 PM   #6 (permalink)
Seven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community memberSeven0Three is an elite community member
great post, thanks for sharing! and welcome! +rep
[NLC--MA #004][Find me @ ISFanatics][Walk Hard]
Vouch List: Hiroshima, redline814, mixtapeguru, asukadc, SexusinmyLexus, Sparky, IntensaBlu, TDLI, Velocity02, BLK_IS350, Phil, IS_Monster, 02LexIS300, Chado, LexIS307, ToyotaPete, jakes_is, ayoitsstevo, 03_IS, 04_IS, acumenhokie, FutureISdriver, and everyone else I missed.
can't forget about enjoico
Seven0Three is offline Reply With Quote
Old 02-09-2006, 02:35 PM   #7 (permalink)
Chopperman
Truthunter's Avatar
my.IS Supporter
Truthunter is an elite community memberTruthunter is an elite community memberTruthunter is an elite community memberTruthunter is an elite community memberTruthunter is an elite community memberTruthunter is an elite community memberTruthunter is an elite community memberTruthunter is an elite community memberTruthunter is an elite community memberTruthunter is an elite community memberTruthunter is an elite community member
Great info +REP.
Someone may want to move this to inside and out and possibly in the DIY section?
'04 AR M/T LSD
Borla, Eibach, FIGS, White Superstar LED Gauge Cluster
Truthunter is offline Reply With Quote
Old 02-09-2006, 06:05 PM   #8 (permalink)
Tachyon is very well likedTachyon is very well likedTachyon is very well likedTachyon is very well liked
I actually replaced the bulb in mine. but it seems like there is a loose wire, sometimes it turns on and sometimes it doesnt. I took out 2 screws and the whole panel. but couldnt get the socket off.
anyone know how to take apart the socket in the back?
Tachyon is offline Reply With Quote
Old 02-10-2006, 12:20 AM   #9 (permalink)
storm is an elite community memberstorm is an elite community memberstorm is an elite community memberstorm is an elite community memberstorm is an elite community memberstorm is an elite community memberstorm is an elite community memberstorm is an elite community memberstorm is an elite community memberstorm is an elite community memberstorm is an elite community member
+rep for you. I was lazy and let the dealer to mine (it was under warranty, so why not). But this info is great.
storm is offline Reply With Quote
Old 03-26-2006, 12:49 PM   #10 (permalink)
ray127 is an elite community memberray127 is an elite community memberray127 is an elite community memberray127 is an elite community memberray127 is an elite community memberray127 is an elite community memberray127 is an elite community memberray127 is an elite community memberray127 is an elite community memberray127 is an elite community memberray127 is an elite community member
Pics are not showing up. Can you reload the pics. I'm trying to replace the map light bulb but am afraid i'll rip the whole thing down, or bust the screw that holds it up. Thanks
ray127 is offline Reply With Quote
Old 01-06-2007, 11:38 PM   #11 (permalink)
tbone is an unknown at this point
replacing sunroof / moonroof map light
I realize this is a year old post. Can you tell me how to pul back up the pictures so I can visualize better the correct way to do this procedure ? I have tried all different ways from pulling the whole section 1 out of the overhead, prying with a putty knife along all cracks in section 2 with no success. All I get is an occasional crack or pop, at which time I quit and do more searching
tbone is offline Reply With Quote
Old 01-07-2007, 12:19 AM   #12 (permalink)
Geezer
bartkat's Avatar
my.IS Supporter 2006 ToyDrive Participant Poker Tournament Player
bartkat is an elite community memberbartkat is an elite community memberbartkat is an elite community memberbartkat is an elite community memberbartkat is an elite community memberbartkat is an elite community memberbartkat is an elite community memberbartkat is an elite community memberbartkat is an elite community memberbartkat is an elite community memberbartkat is an elite community member
Look here:
Changing the map light
bartkat is offline Reply With Quote
Old 10-30-2007, 10:48 PM   #13 (permalink)
tyau is an elite community membertyau is an elite community membertyau is an elite community membertyau is an elite community membertyau is an elite community membertyau is an elite community membertyau is an elite community membertyau is an elite community membertyau is an elite community membertyau is an elite community membertyau is an elite community member
Here is my input
I've updated with pictures to another thread
How to change the map light bulb . . . ?
Hope this helps.
Tommy
tyau is offline Reply With Quote
Old 10-31-2007, 08:03 PM   #14 (permalink)
drock02 is an unknown at this point
I just did this about a week ago. What you have to keep in mind is the cover you are removing is pliable where the plastic house (1) is a hard plastic. This should help you "peel" off the outer cover.
drock02 is offline Reply With Quote
Old 08-01-2009, 02:59 PM   #15 (permalink)
turbotrauma is an elite community memberturbotrauma is an elite community memberturbotrauma is an elite community memberturbotrauma is an elite community memberturbotrauma is an elite community memberturbotrauma is an elite community memberturbotrauma is an elite community memberturbotrauma is an elite community memberturbotrauma is an elite community memberturbotrauma is an elite community memberturbotrauma is an elite community member
Just popped open my 02 IS300 interior bulb housting yesterday, WOW WHAT A PAIN IN THE ASS! I used a small flat head screwdriver to CAREFULLY pry the housing down, then pulled forward to help release the two tabs. It wasn't easy.
I found a few "working" bulbs at the local auto parts store, but I'm now convinced they are all trash. For those of you replacing your IS300 dome light, make sure you go to Toyota for the OEM bulb! The bulbs at AutoZone, Advanced Auto, etc are generic and are not made for a *primary interior light*. The generic bulbs are not made to be super bright.
Just ordered one today from Toyota for $5. Going LED was tempting, maybe next time.
2002 GGP IS300
turbotrauma is offline Reply With Quote
You may not post new threads
You may not post replies
vB code is On
