Code 32 ABS light
Hi there I am not sure where this question should go. I have an ABS light on my 2001 IS300. I shorted the DLC3 connector appropriately to pull the code and it gave me a Code 32. I have tried to look through the manuals but cannot see a Code 32. Well, I should say the ABS light flashes 3 times and then 2 times, which I interpret as code 32 accroding to the manual. Any one know what what is causing it? The first time I pulled the code it had a code 32 and code 41. After resetting, the code 41 went away, the code 32 stayed.
Thanks!
IS300 - Built 2JZ-GTE w VVTi (Arias Pistons/Pauter rods), Ferrea valve train, ARP loaded, V160, Supra rear end, Custom AEM, Custom VW intake manifold 4.5" Accufab TB, full rewire - PITA!
'97 Nissan Maxima Built VQ35DE swap, GT40R, ID 1000cc injectors, Custom AEM
'02 BMW M3 - being boosted
