What MAF do you high hp bOost guys use - Lexus IS Forum
 3Likes
post #1 of 24 (permalink) Old 03-17-2017, 09:45 AM Thread Starter
I am finishing up buying my last few parts for my build and I was wondering what MAF sensor are other 500+ boosted guys using?
02lexi is offline
post #2 of 24 (permalink) Old 03-17-2017, 10:32 AM
Quoted: 61 Post(s)
Most standalone ECU's are best used with a MAP sensor. More accurate readings can be obtained and less restriction than if a MAF sensor were used. There are many other benefits to using MAP over MAF.
my instagram
garrettej8 is offline
post #3 of 24 (permalink) Old 03-17-2017, 10:44 AM Thread Starter
Thank you!!
02lexi is offline
post #4 of 24 (permalink) Old 03-17-2017, 12:13 PM
Virgin Magnet
somguy2u's Avatar
Quoted: 44 Post(s)
i use a stock maf and a map. depending on your goals you will need a map sensor for sure but keeping the stock maf is the question. I wanted CEL free operation using stock sensors so i need the stock maf in the stock location
TUI
Motorsports
Own the dream
LC SSI 006
SWTEA Talon
somguy2u is offline
post #5 of 24 (permalink) Old 03-17-2017, 04:14 PM Thread Starter
So you used both stock MAF and switched to a MAP?
02lexi is offline
post #6 of 24 (permalink) Old 03-17-2017, 04:15 PM
Patriot
Quoted: 20 Post(s)
Is the MAF still required if you're keeping the stock or Aristo throttle body?
-Adam
bigkahuna2187 is offline
post #7 of 24 (permalink) Old 03-17-2017, 04:18 PM Thread Starter
Yep. You have to run one or the other. The problem is that MAF can only read so much air. So when you add a turbo it can't accurately read how much air is going into the engine.
02lexi is offline
post #8 of 24 (permalink) Old 03-17-2017, 04:37 PM
Patriot
Quoted: 20 Post(s)
I understand that, I run both MAP and MAF myself (just to use the IAT thermocouple for my AEM EMS) but was curious if the MAF was required in order to properly run the DBW throttle bodies.
-Adam
post #9 of 24 (permalink) Old 03-17-2017, 04:41 PM
Cherisher
blkdout's Avatar
Quoted: 584 Post(s)
I believe the MAF helps control the fuel gauge, the auto trans and DBW.
I run both on my turbo car but probably don't need it anymore
-Hiral
blkdout is offline
post #10 of 24 (permalink) Old 03-17-2017, 05:54 PM
Quoted: 61 Post(s)
Is that right? My fuel gauge is off by about 1/4 or so, ask me how I know
my instagram
post #11 of 24 (permalink) Old 03-17-2017, 06:03 PM
Cherisher
blkdout's Avatar
Quoted: 584 Post(s)
haha mine used to be off by 1/4 but now it's more like 1/2 tank. I think the float got bumped with the new pump. I fill up at E and it puts 7-8 gallons in.
The stock ECU only reads the float incrementally. The 1/4 drops on most turbo cars are simply because the MAF isn't there or working with the ECU to fill in the gaps with the float reading and/or the O2 sensors are gone as well. The smooth operation of the fuel gauge I believe is a combined calculation of the MAF and O2 readings.
somguy2u likes this.
-Hiral
blkdout is offline
post #12 of 24 (permalink) Old 03-17-2017, 06:08 PM
Quoted: 61 Post(s)
Makes sense. I figured the stock ECU was missing some sort of sensor info since it's tough to keep it happy after a swap.
my instagram
post #13 of 24 (permalink) Old 03-17-2017, 07:09 PM
Cherisher
blkdout's Avatar
Quoted: 584 Post(s)
Yup. Basically, you keep the MAF for proper CEL operation and/or creature comforts so to speak.
When boosted, the MAF no longer helps control the engine. That's where the MAP takes over.
-Hiral
blkdout is offline
post #14 of 24 (permalink) Old 03-17-2017, 09:42 PM
Virgin Magnet
somguy2u's Avatar
Quoted: 44 Post(s)
yes, maf defines what the o2 sensors should see, fuel gauge reads, vvti functions, and throttle operates. it's kind of a big deal in the IS, also important that you try and keep stock location and stock diameter piping for CEL free operation.
with a standalone, the MAP controls injection and ignition, but the maf is necessary for EVERYTHING else... that's why not many people can completely go standalone, how it's all ridiculously tied together.
blkdout likes this.
TUI
Motorsports
Own the dream
LC SSI 006
SWTEA Talon
somguy2u is offline
post #15 of 24 (permalink) Old 03-17-2017, 09:45 PM
Virgin Magnet
somguy2u's Avatar
Quoted: 44 Post(s)
it's better than the other way! trust me.. i ran out of gas with 1/4 of a tank left - the float got stock on something and wouldn't ever drop below - such a pain.
TUI
Motorsports
Own the dream
LC SSI 006
SWTEA Talon
somguy2u is offline
