VVTI delete - Lexus IS Forum
post #1 of 7 (permalink) Old 02-21-2017, 10:09 AM Thread Starter
VVTI delete
Is there any way to get rid of the vvti? I am having some issues with it and kinda just want to get rid of it completely. I have an AEM infinity running the engine and fuel. Could I just get some new Brian Cower cams and drop them and retune the engine like a regular non-vvti engine or is there something that I'm missing here?
If you wish to keep reading I'll explain what's going on the with the vvti as of now. But my question is above if you wanna skip this part
When the engine is cold and I start it up with the vvti oil control valve plugged in it maxes out the timing of the vvti cam and runs like hell until she get warmed up. As the temp climbs in the engine the vvti comes starts to correct its self back to 0 degrees plus or minus a bit. When it first starts its reading around 45-50 degrees. Maybe I have something wrong in the VE section of the AEM in the idle settings. Not sure but kinda want a bigger cam anyways. Just want to get rid of it all together without buying a whole new motor. This car is a weekend warrior so we don't daily it.
CrashTest is offline
post #2 of 7 (permalink) Old 02-21-2017, 01:12 PM
c1L
Quoted: 49 Post(s)
I would have another tuner look at your settings before removing vvti. these days vvti is what you want. My old motor had the vvti removed with hks 264 cams and titan cam gears. Not sure what the previous owner did to make it work though.
ProEFI / V160 IS300 742rwhp Alpha Tuned
Spring Setup: 10:1 GTE Motor, V160, Proefi128, S369SXE...
My Build Thread
ig - cillyotta
RIP MIKEY #msperformance
c1L is offline
post #3 of 7 (permalink) Old 02-23-2017, 06:38 PM
Quoted: 61 Post(s)
So I was having this issue as well. Is your idle going up and down and having stalling issues on cold starts? I sent my tuner some startup logs and he adjusted the calibration so that VVC was disabled until the water temp reached 120F. I know the AEM tuner software pretty well so I could give you instructions on how to do it if you'd like. I can post my VVC table as well.
my instagram
garrettej8 is offline
post #4 of 7 (permalink) Old 02-23-2017, 09:31 PM
Quoted: 29 Post(s)
How's it run unplugged?
<--- Doesn't believe in stock vehicles
2002 IS300 VVTi GTE v161 Built single - TeCKis300's old car
1995 240sx - NASA PTD trim
Hardrvin is offline
post #5 of 7 (permalink) Old 02-27-2017, 10:59 AM Thread Starter
Yes this is exactly whats happening. Up and down and up and down until she will eventually die or until she gets warmed up. Let me know how to disable it until the water temp gets up there. Your help is much appreciated.
post #6 of 7 (permalink) Old 02-27-2017, 11:00 AM Thread Starter
Runs ok unplugged, hot or cold.
post #7 of 7 (permalink) Old 02-28-2017, 03:38 PM
Quoted: 61 Post(s)
If you go to the setup wizard, advanced options and select VVC you will see VVC Target Table and the option for temp is right in there. Here's mine:
This should help stabilize the idle on cold start (it's not perfect) but if it doesn't then it's probably going to need a fuel adjustment which you'll have to talk to your tuner about.
my instagram
