tt pistons and tt oem hg= bad?? - my.IS - Lexus IS Forum
b
Register Home Forum Photos Active Topics / Realtime Insurance Garage iTrader User's Guide Mark Forums Read
» Log in
Not a member yet?
Register Now!
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Old 02-08-2010, 10:20 PM   #1 (permalink)
Patriot
tjmhillz is an elite community membertjmhillz is an elite community membertjmhillz is an elite community membertjmhillz is an elite community membertjmhillz is an elite community membertjmhillz is an elite community membertjmhillz is an elite community membertjmhillz is an elite community membertjmhillz is an elite community membertjmhillz is an elite community membertjmhillz is an elite community member
ive been doing some research and ive been surfing on supra forums. ive read running tt pistons and tt oem hg on a na ge is bad? ppl said it would lower your compression to under 8:5:1 and would ruin your quench. some ppl even said if you run tt pistons you should run na hg. ive never heard of that and would think the na hg wouldnt hold even with headstuds? what are your guys take about running tt pistons and oem tt hg or na hg? are their any of you guys running tt pistons and oem tt hg? how long has it been holding up. also are there any guys running tt pistons on na hg? thanks
**2001 MSM Turbo IS300**
NELOC LEADERSHIP
**Operation Iraqi Freedom Veteran**
tjmhillz is online now   Reply With Quote
Old 02-08-2010, 11:40 PM   #2 (permalink)
Virgin Magnet
somguy2u's Avatar
somguy2u is an elite community membersomguy2u is an elite community membersomguy2u is an elite community membersomguy2u is an elite community membersomguy2u is an elite community membersomguy2u is an elite community membersomguy2u is an elite community membersomguy2u is an elite community membersomguy2u is an elite community membersomguy2u is an elite community membersomguy2u is an elite community member
tt pistons and tt hg = the good
it's standard protocol as far as i'm concerned, the only other option in my eye is a 1mm HKS or greddy - but you gotta pay twice the amount for them
TUI
Motorsports
Own the dream
LC SSI 006
SWTEA Talon
somguy2u is offline   Reply With Quote
Old 02-09-2010, 06:58 AM   #3 (permalink)
stjarvis's Avatar
my.IS Supporter
stjarvis is an elite community memberstjarvis is an elite community memberstjarvis is an elite community memberstjarvis is an elite community memberstjarvis is an elite community memberstjarvis is an elite community memberstjarvis is an elite community memberstjarvis is an elite community memberstjarvis is an elite community memberstjarvis is an elite community memberstjarvis is an elite community member
I've heard you actually end up being around 8.3/1 can't say for sure though.
Currently I've got JE 8.5/1 pistons and a GTE head gasket, everything's been running fine for 3000+ miles, but no boost yet so I'm getting around 16mpg city.
In 5 years I will have the worlds fastest IS300... because everyone else will have parted out and bought an M3.
stjarvis is offline   Reply With Quote
Old 02-09-2010, 11:00 AM   #4 (permalink)
stirlingw is an elite community memberstirlingw is an elite community memberstirlingw is an elite community memberstirlingw is an elite community memberstirlingw is an elite community memberstirlingw is an elite community memberstirlingw is an elite community memberstirlingw is an elite community memberstirlingw is an elite community memberstirlingw is an elite community memberstirlingw is an elite community member
its good...do it. you have an IS not a supra
just make sure that you get the pistons installed correctly
+ 2JZ-GTE IS300 +
stirlingw is offline   Reply With Quote
Old 02-09-2010, 11:18 AM   #5 (permalink)
SteveM1320 is an elite community memberSteveM1320 is an elite community memberSteveM1320 is an elite community memberSteveM1320 is an elite community memberSteveM1320 is an elite community memberSteveM1320 is an elite community memberSteveM1320 is an elite community memberSteveM1320 is an elite community memberSteveM1320 is an elite community memberSteveM1320 is an elite community memberSteveM1320 is an elite community member
You are correct about the Compression Ratio dropping. However it isn't "bad" people do it all the time and make great power. Lower compression also is safer for pump gas and boost as well.
However. Yes. You Are Correct. About everything... Including the Quench. But i suppose in the real world it really isn't that important.
The stock GTE head gasket is ~1.2-1.3mm
The stock GE head has a "recessed combustion chamber" while the GTE head does not. "The entire combustion chamber on the NA head is recessed about .025" *
so the combination you've mentioned using a thicker 2mm hg, would result in a CR less than 8.5, probably closer to 8.0:1 (that's just a guess)
Using a Stock TT HG + TT Pistons + TT Rods + GE head = a CR of 8.3:1 **
DaveH (NA-T guru on SupraForums)
**GE head w/ TT shortblock & HG = 8.3:1 compression?
And finally. Before you say I'm wrong.
TonyTheTiger agrees with me ... and so do Boost Logic
SOLD:
2002 GGP IS300-T
SRT 2.75 | Haltech E6X | PFS Fuel Return & Blackbox | Marlin Crawler R154 | HKS: TI-Limited, GD Max Twin Plate, DLI | VOLK Gram Light 57PRO| JIC Magic Front strut brace | AAC Carbon Fiber Rad Plate
PFS tuned! 410whp - 375 ft-lbs 13psi
SteveM1320 is offline   Reply With Quote
Old 02-09-2010, 11:20 AM   #6 (permalink)
if your pistons are JE 8.5:1 for the 2JZGE then you have 8.5:1.
If they're for the GTE then you have 8.3:1
And its OKAY to do. Lots and lots of people do it.
Old 02-09-2010, 04:53 PM   #7 (permalink)
Patriot
i knew ppl was runnin this set up but just wanted to see if they did anythign extra like milling the head down to flow as if it was the gte.
NELOC LEADERSHIP
Old 02-09-2010, 05:13 PM   #8 (permalink)
Boostin in the 505
Tyler Cruz's Avatar
my.IS Supporter
Tyler Cruz is an elite community memberTyler Cruz is an elite community memberTyler Cruz is an elite community memberTyler Cruz is an elite community memberTyler Cruz is an elite community memberTyler Cruz is an elite community memberTyler Cruz is an elite community memberTyler Cruz is an elite community memberTyler Cruz is an elite community memberTyler Cruz is an elite community memberTyler Cruz is an elite community member
It's believed the GE head flows better so I don't think anyone would have done that
02 Onyx IS300
Tyler Cruz is offline   Reply With Quote
Old 02-09-2010, 07:41 PM   #9 (permalink)
MikeNice is an elite community memberMikeNice is an elite community memberMikeNice is an elite community memberMikeNice is an elite community memberMikeNice is an elite community memberMikeNice is an elite community memberMikeNice is an elite community memberMikeNice is an elite community memberMikeNice is an elite community memberMikeNice is an elite community memberMikeNice is an elite community member
sorry to thread jack, but a local guy is selling a 2jzge with tt pistons/rods brand new never driven.however the hg was left stock. he said tops of the pistons were CNC machined a little to lower compression more so the stock hg could be used. This was all done by a prof. engine builder.should i be concerned about the na hg still or just have a tt hg installed to be safe?
"THATS NOT OIL LEAKING FROM THE ENGINE. THATS SWEAT FROM ALL THE HORSEPOWER!!"
02 MSM/gte/ PTE 6265
MikeNice is offline   Reply With Quote
Old 02-09-2010, 08:45 PM   #10 (permalink)
qphoton is an elite community memberqphoton is an elite community memberqphoton is an elite community memberqphoton is an elite community memberqphoton is an elite community memberqphoton is an elite community memberqphoton is an elite community memberqphoton is an elite community memberqphoton is an elite community memberqphoton is an elite community memberqphoton is an elite community member
YOU ARE WRONG!
1) The stock GTE head gasket compressed thickness is = 1.35 mm
2) for TT pistons and 2mm hg CR = 8.37:1
I don't known what mean "recessed combustion chamber" term, but you can calc CR youself using real numbers from:
1) http://my.is/forums/attachments/f114...xusis300-1.pdf
2) http://my.is/forums/attachments/f114...supraturbo.pdf
My results here
Please find any mistakes?
Lexus GS300 '98 w/ 2JZ-GET ... coming soon!
qphoton is offline   Reply With Quote
Old 02-09-2010, 10:33 PM   #11 (permalink)
Patriot
here are 2 quotes from supraforums.
(quote 1
If the head is cut should the gasket thickness increase by the amount that is removed from the head over the .2mm of the stock NA gasket?
If you cut 1mm from the cylinder head, would that require use of the TT gasket(1.2mm) to maintain the correct quench/squish?
My head has been cut around .75 of a MM and I am using a TT gasket with TT pistons/shortblock. So in theory this brings my CR up to around 8.6-8.7 and the quench/squish a good bit closer to what it should be... quote)
(quote 2
In fact,I am thinking of milling my head so the combustion chamber is similar to a TT and use a TT gasket. The reason for this, is if I ever need to resurface my CR's won't change as much as if it was recessed like it is.
Although, not milling it will allow the head to live longer since there will be more material there for future removal quote)
thats why i asked the question..
NELOC LEADERSHIP
Old 02-09-2010, 10:40 PM   #12 (permalink)
Tony the Tiger is an elite community memberTony the Tiger is an elite community memberTony the Tiger is an elite community memberTony the Tiger is an elite community memberTony the Tiger is an elite community memberTony the Tiger is an elite community memberTony the Tiger is an elite community memberTony the Tiger is an elite community memberTony the Tiger is an elite community memberTony the Tiger is an elite community memberTony the Tiger is an elite community member
I've milled my GE head by 0.025" just so it removes the step between the gasket and the bowl of the combustion chamber.. It was merely to achieve something similar to the GTE's pentroof style chamber.
Besides that, unless you are shooting for huge amounts of power (800+ WHP) and always restricted by the fuel you are using, I won't worry too much about issues with quench or whatnot. As long as the compression ratio is still in the 8's, there is negligable difference as far as compression goes, and I would recommend the TT headgasket over the GE gasket anyway. The GE gasket is pretty thin and weak actually, and it not as forgiving as the TT headgasket.
440 WHP @ 14.5 PSI GT3076R Lexus IS300
1207 WHP @ 33.5 PSI GTX45R '94 Supra TT
728 WHP @ 38 PSI HKS T51R SPL '94 Camry V6
485 WHP @ 30 PSI ATP GTX3076R Lancer Evo IX
Dynamotorsports Tuning
Tony the Tiger is offline   Reply With Quote
Old 02-10-2010, 12:38 AM   #13 (permalink)
Patriot
Swift Racing Technologies is an elite community memberSwift Racing Technologies is an elite community memberSwift Racing Technologies is an elite community memberSwift Racing Technologies is an elite community memberSwift Racing Technologies is an elite community memberSwift Racing Technologies is an elite community memberSwift Racing Technologies is an elite community memberSwift Racing Technologies is an elite community memberSwift Racing Technologies is an elite community memberSwift Racing Technologies is an elite community memberSwift Racing Technologies is an elite community member
Here is my setup:
IS300 GE VVT-i Head,
IS300 GE Block,
3.4L GTE Stroker kit (pistons, rods, crank),
OEM TT HG.
Makes ~1300RWHP @ 39 PSI boost Turbo Only and over 1600with N20.
Nuff said.
TT internals + TT HG = GOOD! FOR THE GE LONG BLOCK, THIS WAS ESTABLISHED YEARS AGO!
Swift Racing Technologies is offline   Reply With Quote
Old 02-10-2010, 04:59 AM   #14 (permalink)
KR4P11 is an elite community memberKR4P11 is an elite community memberKR4P11 is an elite community memberKR4P11 is an elite community memberKR4P11 is an elite community memberKR4P11 is an elite community memberKR4P11 is an elite community memberKR4P11 is an elite community memberKR4P11 is an elite community memberKR4P11 is an elite community memberKR4P11 is an elite community member
Originally Posted by Swift Racing Technologies View Post
Here is my setup:
IS300 GE Block,
OEM TT HG.
Nuff said.
TRUUF.
o3' Graphite Grey Turbo IS300 w/ 6spd swap
Going to throw a Supra tranny (V160) into your IS? Got questions? Feel free to ask me.
* * *TX2K9 & TX2K10* * *
KR4P11 is offline   Reply With Quote
Old 02-10-2010, 08:40 AM   #15 (permalink)
Boostin in the 505
Tyler Cruz's Avatar
my.IS Supporter
Here is my setup:
IS300 GE Block,
OEM TT HG.
Nuff said.
Well that's all you need to know right there!
02 Onyx IS300
You may not post new threads
You may not post replies
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
