Swap Guide: JZX110/JZS171 1JZGTE VVTi into 02-05 IS300 - Lexus IS Forum
post #1 of 26 (permalink) Old 01-28-2016, 08:15 PM Thread Starter
It has been brought to my attention that a ton of misinformation is out there in regards to this swap. I am here to change that. I have successfully performed this swap to my own IS300 and it has been running great and taking a beating for the last year Some of you may recognize me from the 3SGE BEAMS swap that I did to this car a few years back. Well that engine blew up and I decided to go down this route. It took a ton of time and effort to figure this stuff out, so I hope I can help a few of you out and make your lives easier.
**Place marker. This is not finished.**
c1L likes this.
Lucas@AirLift is offline
post #2 of 26 (permalink) Old 01-28-2016, 08:36 PM Thread Starter
The end result
https://youtu.be/Rlth4Tt_Yzw
https://youtu.be/E8ThI2HKiEo
**Also a place marker for later**
**EDIT: Car is now running an AR5 trans and a Megasquirt MS3X for engine management. It has been going strong for 2 drift seasons with zero issues. I am in process of installing a GTX3076R and welding in a roll cage.
post #3 of 26 (permalink) Old 01-29-2016, 08:22 AM
Ive thought about doing this swap for way too long... Im subscribing to this one. did you make a thread with the install?
GGP01IS300 is offline
post #4 of 26 (permalink) Old 01-29-2016, 03:20 PM
Quoted: 15 Post(s)
Awesome resource so far, I just received my JZX100 1J yesterday. Looking forward to whatever else you have coming, by the looks of it it should be a pretty thorough documentation.
Thanks for taking the time to get this going!
Mzs14 is offline
post #5 of 26 (permalink) Old 01-31-2016, 11:30 AM
Thank you for taking the time to share your research.. i just posted a question the 1jz wiring thread before i stumbled upon this one.. im looking to use the 110ecu with my factory 5spd.. im wondering if they are going to be any issues using an auto ecu without the auto trans present.
Money_pit is offline
post #6 of 26 (permalink) Old 02-01-2016, 06:03 PM
Quoted: 37 Post(s)
Correct me if im wrong but i spoke with him and hes using the auto ECU with a 5 speed trans. the only issues he has using this is that there is a CEL on and the cruise control does not work. So in theory a x110 manual ecu could fix these issues.
2002 MSM Sportcross
TEIN//Gita//Blitz//Pioneer//FIGS//Work
instagram - ellis300
ellis300 is offline
post #7 of 26 (permalink) Old 02-01-2016, 06:05 PM
Quoted: 37 Post(s)
i myself plan on using this info, this is awesome since it makes the engine run on the FACTORY settings, making it as reliable as an JZX110/JZS171 in Japan!
all i need to do is figure out what drive shaft will work with the a340 and fit the IS
2002 MSM Sportcross
ellis300 is offline
post #8 of 26 (permalink) Old 02-03-2016, 03:05 PM
Quoted: 15 Post(s)
So I know there is more to come, but my curiosity is killing me on where to mount the JZX ECU in the engine bay given the length of the harness extensions that are available (Boomslang, Dezod, etc.)
Any pics or specifics on this part would be most helpful.
Mzs14 is offline
post #9 of 26 (permalink) Old 02-09-2016, 11:16 AM Thread Starter
This is going to be that thread. I had only documented it on my personal facebook account up to this point
This is correct. I am using an A/T ecu. The CEL is on solid as it is throwing codes for the auto trans parts that are no longer installed. Since the auto ecu converts tail shaft speed to use as vehicle speed, cruise control is rendered INOP. In theory, a JZX110 manual ECU would make the swap 100% functional, but I have never found a manual JZX110 swap.
The ECU slides right in to where the ECU goes. This is a JZX110 swap, not JZX100 which mounts the ECU in the interior.
Guys I have not forgotten about this. Been super busy with work and getting my car ready for this years drift season. I am going to spend some time on this tonight.
BTW, how can I upload larger files? I have a full engine wiring schematic that I translated from russian, but it is too large to upload.
post #10 of 26 (permalink) Old 02-22-2016, 03:16 PM
Quoted: 11 Post(s)
That is the downside of forums. If it is a PDF file, just upload it on Photobucket or something. If it is an Excel sheet, post a google doc that only you can edit.
Pete the Russian had a wiring diagram he translated I believe.
Can't wait to see an actual build DIY on this :D
'05 IS300 - Daily Driven
Instagram
IS_aLEX is offline
post #11 of 26 (permalink) Old 02-22-2016, 05:33 PM
wingzero's Avatar
Quoted: 17 Post(s)
I'd imagine the process is pretty similar to the Aristo swap but curious nonetheless...
Looking to do an Aristo swap?
Aristo Swap with IS ECU
Aristo Swap with Aristo ECU
wingzero is offline
post #12 of 26 (permalink) Old 02-23-2016, 06:50 AM
1JZ Vvti With ETCS-i Have S3 And S4 Solenoid In Auto Transmission
Only ETC Have S2 And S1
Btw Some Members Of Sxe10Crew With 1JZ Vvti (Altezzas Not Is300/200)
ID:	93082   Click image for larger version
ID:	93090   Click image for larger version
Sxe10Crew Member (Dominican Republic)
Altezza RS200Z 2003 (Sold) (RHD)
Lexus IS300 2JZGE-T 2005 (Sold) (LHD)
Altezza RS200L 1999 (Sold) (LHD)
Altezza RS430 (3UZ) (Sold) (RHD)
Lexus IS350
Quimicax is offline
post #13 of 26 (permalink) Old 02-23-2016, 07:12 PM
I pretty sue Pete the Russian used a 1jzgte vvti from a jzx100 which is the more common one that people do as there's more info on them, but saying that the Russian diagram I've got for the jzx110 1jzgte vvti that I've got isn't too hard to work out the tricky bit is locating an IS200 1gfe wiring diagram
Sent from my SM-G900F using Tapatalk
Mountaindewing is offline
post #14 of 26 (permalink) Old 03-14-2016, 06:54 PM
Quoted: 44 Post(s)
Anymore updates on this Lucas? I've located a JZX110 manual ecu that I'm thinking about buying since I want my swap to be as plug-n-play as possible.
Piggity is offline
post #15 of 26 (permalink) Old 03-14-2016, 08:53 PM
is the AFC Neo your only fuel management source? or do u have a Fuel Pressure Regulator (that I am not seeing in the engine bay lol) somewhere.. and a Fuel Return line?
and if you dont mine me asking, what intercooler piping kit is that? cx racing? or is it custom made?
Black Onyx '01 IS300 | 1JZ-GTE VVTi x JZS171 | LSD | Running 100% off the 1JZ ECU | CX Racing Coilovers | FutureFab DP to Custom 3" Straight Pipe to Yonaka Exhaust | Custom Intake x K&N Filter | 2.5" Piping x FMIC | Walbro 255 | Pioneer/JL Audio | OEM Altezza Interior
Next: Wheels or Manual Swap
#JZMob | Check Us Out @ www.Facebook.com/JZMobAruba
TNCMAviator is offline
Current users viewing this Thread: 3 (0 members and 3 guests)
