Rick's 3.4 Stroker IS - Page 8 - Lexus IS Forum
post #106 of 170 (permalink) Old 06-23-2011, 09:04 PM
wow, im so sorry you've had so many internal engine issues :/ Good luck!
Doing a 2JZ-GTE swap into an IS300? Click here for the Swap Manual: http://my.is/forums/f114/2jz-gte-swa...rd-doc-431423/
-To be fair to everyone- This is the internet, and we are all different sources, so each source will probably have different answers, and I do know that there are some people out there who are complete idiots....
www.undergroundstreetcar.com
indirocz28 is offline
post #107 of 170 (permalink) Old 06-24-2011, 06:31 AM Thread Starter
Yeah, what really hurts is that, with all the new, I think innovative, stuff that went into the engine, the thing that hosed it was the FPR. I have to look at the dust covered car every day at the shop without time to spend on it.
Kaldes, you will see me and the car at the Orlando meets later this year. will be good to see you guys again. I work 3rd shift (for 28 more days) and it was always a hassle getting there.
Rick Bowers
"Speed Costs - How fast do you want to spend?"
'02 GGP L-Tuned IS300
3.4 GE Stroker/BW EFR9180/MS3Pro/J&S/V160/Tilton/Supra 3:13/Tein/HRE
speeder is offline
post #108 of 170 (permalink) Old 12-15-2011, 09:38 PM Thread Starter
Finally back to work on the car - I'm now unemployed/retired and have gotten enough control over my schedule to make some IS time. Many non - car related crises happening in the last 6 months or so.
I've pulled off the front of the car to make the engine removal easier and have disconnected everything - motor lifts out tomorrow.
Before disconnecting everything I took time to fit a V-band flange on my header so I can mount my new Tial 60 mm gate. I just didn't trust the Chinese cheapie 50mm that was on there to reliably go the long run. And I just love V-bands for easy installation and alignment. This thing has a 2-1/2" dump port!
I'll report progress as it occurs - I really miss my IS.
Rick Bowers
speeder is offline
post #109 of 170 (permalink) Old 12-15-2011, 09:51 PM
Glad you're still around! Keep us updated
Kaldes is offline
post #110 of 170 (permalink) Old 12-15-2011, 09:58 PM Thread Starter
I'm finally back working on the car now and will soon have the engine re-ringed and running. I will report progress on my other build thread.
Rob, aka LexISpooled, the man who sold me the worn-out Tilton clutch pack (See post 21 this thread) and never made good, as promised, Here is a cameo role in my engine thread. I fart in your general direction. I wave my private parts at you. Feeling the love?
Rick Bowers
speeder is offline
post #111 of 170 (permalink) Old 12-16-2011, 06:05 AM
Bezik777's Avatar
Quoted: 36 Post(s)
Glad you back at it .......keep us updated , more pics when you can..
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #112 of 170 (permalink) Old 12-16-2011, 06:57 AM
baadhabit's Avatar
baadhabit is offline
post #113 of 170 (permalink) Old 12-16-2011, 07:18 AM
very nice setup. good thing that cheap WG is out of there. TiAL is always a good way to go.
Jerm__ is offline
post #114 of 170 (permalink) Old 12-16-2011, 09:38 AM
I am in love with your ignition coil setup! And since I am running an AEM series 2 I think I can get away with running this style ignition.
Im your local smarta$$
leonard_is300 is offline
post #115 of 170 (permalink) Old 12-16-2011, 12:13 PM
Lol. I'll remember not to buy from that guy too, I just got screwed on some "new pistons" so i know how you feel.
NazTBoIs300 is offline
post #116 of 170 (permalink) Old 12-16-2011, 09:26 PM Thread Starter
Any ems that outputs a logic level (0-5Volt) or 0-12volt square wave ignition signal can use the GM coils. Again, they have built in igniters so any existing igniters between the ECU and coils are eliminated with this setup.
Rick Bowers
speeder is offline
post #117 of 170 (permalink) Old 12-20-2011, 07:59 AM Thread Starter
Got the engine out and disassembled - The first bad sign was that the oil pan had over 1 quart extra liquid in it and that stuff smelled like gasoline.
As I feared, all the bearings are shot and the crankshaft was lightly scored, - rods and pistons OK. I'll give the block a light hone (The piston to wall clearance was set on the tight side for my forged pistons), send the crank out to be reconditioned (the guys at Paeco reassured me that the alloy layer on the journals would be OK with up to a .020" regrind), and replace rings and bearings.
Incredible how this damage could have happened in probably less than 100 miles with raw gas shooting into the intake. I'm still pretty upset with myself that it took so long to realize what was going on with the FPR.
Rick Bowers
speeder is offline
post #118 of 170 (permalink) Old 12-20-2011, 08:16 AM
Thats some bad luck there Rick, I know how that goes, I went through so many motor rebuilds before figuring our there was a blockage in my shortblock that was causing me to spin bearings every 800 miles or so. I will be out your way on Thursday night for dinner, I can swing by and drop your scanner at that time if thats ok with you, also I plan on hitting the track Friday, the Lexus is pulling much better now with the coil on plug setup and I want to see how it does before getting my nitrous kit and drag radials next week.
2001 GS300, 2JZGTE-VVT-i, TRD LSD, PTE 6667, SP400 Stage Gear Vendors 6 Speed, Titan 264 VVTI Cams, Motec M800
2001 Lexus GS300 / GTE / Motec / Daily Driver / 10.2 @ 137 MPH
1997 TT 6 Speed Supra Precision 76mm / AEM 800+ RWHP
2006 Viper Coupe, Black, 1800 miles
adamgamz is offline
post #119 of 170 (permalink) Old 12-22-2011, 03:42 AM
Guru of Supercharged ISs
i am praying that the gods of IS builds havent shat on this project and that you find little permanent damage from the dilution issue...
building a stroker 2j has always intrigued me ... i am dying to hear how it sounds on start up idling & pulling away ... then a nice acceleration run/drive by would be sweet.
best of luck man. looking forward to hearing the news whatever you decide
edgy is offline
post #120 of 170 (permalink) Old 12-22-2011, 04:17 AM
So sorry to hear the news, I was hoping the crank was ok at least. Sounds like it can be saved at least... happy holidays eh?
look forward to hearing more, u cant quit now....
Gamz, what did u do to fix it.?
I had the same thing,, I ended up with a brand new TT block in 2006 after my built GE motor started develping the same problem, I could only get 2 weeks or about 400-500 miles before the new bearing was toast..
and the knocking started...
After the 3rd spun bearing in 2 months, Carson toyota got a call...
edgy is offline
