b
» Log in
Not a member yet?
Register Now!
» Wheel & Tire Center
Sponsors
Sponsors
Old 01-13-2009, 12:36 AM   #1 (permalink)
LO 21 is an elite community memberLO 21 is an elite community memberLO 21 is an elite community memberLO 21 is an elite community memberLO 21 is an elite community memberLO 21 is an elite community memberLO 21 is an elite community memberLO 21 is an elite community memberLO 21 is an elite community memberLO 21 is an elite community memberLO 21 is an elite community member
R154 – THE Ultimate Auto to Manual Swap Info Thread
(Please do not send us any PMs about parts or the process unless you must. It's better to post any questions or comments on here so anyone who reads this thread can benefit from them.)
Well, I FINALLY finished my R154 swap on my auto. The swap itself only took us 3 days (Friday, Saturday, and today Monday). And we only needed to wait until today to finish because I overlooked a few parts and needed to wait until today to get those so we could finish up. Otherwise, this swap can easily be done in a day-and-a-half, two days with the correct planning and research to avoid all surprises.
It was mainly the planning process that took so long. I guess a combination of me choosing to go boost first, which I did back in July. And between work and travel and saving up, etc., I didn't finish gathering everything until this month.
I definitely must give credit to all those who posted R154 swap threads on this forum, because that's basically how I got almost all of my info.
A few months ago another local member and I were both gathering parts for this swap. We both have '01 automatics (now i guess i can say i HAD an '01 auto ;-)), so we basically ended up planning this whole thing together. This really helped because he knew a hell of a lot more about many specifics than I did, and on Saturday when I realized how much crap I was missing, I was lucky enough to have him lend me a few last parts since he already had them. In other words, I would have been F*CKED without the extra planning and info he gathered that I had overlooked.
Another reason it took so long was because there was never just one place where we found all of our info. We found a ton of extremely helpful threads, but never one place will ALL the info. I guess it was because everyone's swap can be unique given all the different things you can choose from (trannies, clutch setups, driveshafts). So since we ended up having to look in a hundred places to gather all the info we needed, we decided to make this thread which will include EVERYTHING you will need to swap an R154 manual into your automatic IS. (most of this info should be useful for ANY auto to manual swap. i guess just a little research will help you separate what you need from this list and what you dont if you're going with a different manual tranny (V160, W58, etc.))
1) To start, you obviously need an R154. There's a few different one's out there, we have two different ones. (can range from $400 to $1300, NOT including 1JZ bellhousing).
LO 21 - '94+ Soarer/Chaser with remote shifter assembly
(what a damn GORGEOUS tranny)
DC5ROY - same as '86-'92 mkIII supra turbo, but directly from Japan already with 1J bellhousing. '92 SC300 shifter recommended (part # below).
2) You need to choose a clutch setup. We each went with something different.
LO 21 - ACT TS2-HDG6 6 puck sprung, rated to about 522 ft-lb of torque (retail $750. can easily be found for about $600 shipped. a bit of a heavier clutch pedal feel, but not even close to as bad as i thought it would be, no chatter whatsoever, decent engagement considering clutch hasn't been broken in yet. after a few drives it was engaging smooth as stock :-))
DC5ROY - OS Giken Twin Disc with Pull-to-Push assembly (will update with a review once installed)
3) We both chose a 1-piece aluminum driveshaft from The Driveshaft Shop (Great! Definitely worth it. No noise or rattle. Extremely more responsive than stock). You could also choose a 1-piece steel one, or have one custom made and balanced either 1-piece or have the front part of your stock one custom extended.
4) You will need tranny fluid. We both went with Redline MTL (you will need 4 quarts, about $50) which is the one that we concluded works best with the R154s (whereas Royal Purple has been known to work well with V160s?)
5) For performance IS's, it is recommended to remove the Clutch Dampening Device (CDD) to reduce that "soft", "slipping" feeling of the clutch. It's the rather hefty hexagonally shaped line union just off of the master cylinder. It should probably be replaced with a regular line union. At a parts store that sells brake line unions, the that fits is the Brass Tite Part #: 43512, 3/16" tube, M10-1.0 thread. Should cost about $2.50.
6) The R154s will sit a bit lower than your stock tranny, so the crossmember wont bolt up flush with the frame of the car. Some people have reported to have had to add spacers and drill new holes in the frame. I guess I got lucky on how my tranny lined up. All I had to do was add some steel washers (5 for each bolt) and found some of the same 12mm bolts but about 1" longer laying around the shop and bolted the crossmember to the existing holes.
7) We HIGHLY recommend making sure you have absolutely everything you need before you start this project to minimize the downtime your car will have. That way you also wont have to run around your city for a few days looking for the rest of the parts or waiting for things to show up in the mail.
8) And the rest of the stuff you need is all Lexus/Toyota Stuff.
Below is each part # you will need with an estimated RETAIL-ish price. Actual retail prices might be a bit more, wholesale price if you have a local dealer that will sell you at those prices might be a bit less. Or, you could also contact Jeff at Champion Toyota in Houston, Texas or Carson Toyota in California for decent prices.
BRAKE PEDAL & BRACKET
Break Pedal Sub-Assy 47106-53010 $108.75
Break Pedal Pad 31321-53010 $26.12
CONSOLE BOX & BRACKET
Shifting Hole Cover Sub-Assy 58808-53020-c0 $117.96
Console Upper Panel Sub-Assy 58804-53011-c0 $115.51
CLUTCH PEDAL & FLEXIBLE HOSE
Clutch Pedal Sub-Assy 31301-53050 $52.10
Spring (For clutch pedal) 90949-03119 $2.26
Cushion No. 1 90541-06036 $2.91
Bush (For clutch Pedal) 90386-13015 $4.38
Nut (For clutch pedal stopper) 94130-01001 $0.89
Bush (For clutch Pedal turnover) 90389-06055 $2.03
Compression Spring 90949-03111 $14.76
Clutch Pedal Pad 31321-53010 $26.12
Clutch Pedal Shaft 90101-10015 $1.08
Clutch Pedal Shaft Collar 90387-10003 $4.73
Clutch Pedal Spring Holder 31353-35010 $11.52
Pin (for Clutch master cylinder push rod) 90240-08006 $1.80
Bush (for Clutch master cylinder push rod) 90386-08036 $2.31
Clutch Master cylinder to flexible hose tube 31481-53060 $9.61
Clutch No.1 Hose 90947-02c83 $41.05
Clutch Master cylinder to 2 way tube 31481-53051 $15.26
Clutch Release cylinder to flexible hose tube 31482-53030 $7.47
Flexible Hose Bracket 31484-53040 $9.28
Clutch Pedal Support Sub-Assy 55107-53030 $55.18
Ring 90082-61005 $1.62
Washer 90206-08001 $0.98
Bush 90386-08036 $2.31
Clip 90468-16142 $0.95
Washer 94622-11000 $1.42
Bolt 90080-11497 $0.77
CLUTCH MASTER CYLINDER
Clutch Master Cylinder Assy 31410-53020 $87.60
(the following is a breakdown of the
individual parts, the above assembly will
come with all of these already assembled)
Clutch Master Cylinder Kit 04311-12110 $26.93
Clutch Master Cylinder Reservoir Sub-Assy 31402-22020 $36.61
Clutch Reservoir Grommet 31417-35010 $2.18
Clutch Master Cyl Reservoir Float 31426-22020 $3.80
Clutch Master Cyl Reservoir Filler Cap Assy 47230-20040 $10.43
TRANSMISSION STUFF
1JZ-GTE R154 Bell Housing 31111-14110 $350.00
Flywheel Inspection Cover - L 31101-14010 $64.68
Flywheel Inspection Cover - R 31102-14010 $64.68
Flywheel Inspection Cover Gasket - L 31122-14010 $4.78
Flywheel Inspection Cover Gasket - R 31124-14010 $4.78
Flywheel Inspection Cover Bolts - L 90080-11228 $1.66 (qty. 2)
Flywheel Inspection Cover Bolts - R 91661-40814 $2.46 (qty. 2)
Bellhousing bolts 91611-61045 $11.07 (qty. 9)
Transmission Shift Fork 31204-14031 $55.72
Transmission Shift Fork Hook ??? ???
Lexus 1992 SC300 Shifter 33530-24040 $136.04
Supra mkIII Slave Cylinder 31470-14050 $51.71
Rear Tailshaft Oil Seal 90311-40001 $9.54
CLUTCH STUFF
1JZ-GTE Flywheel 13405-46030 $248.91
Flywheel Bolts 90910-02103 $52.56 (qty. 8)
Clutch-to-Flywheel Bolts ??? ??? (qty. 6)
Clutch Hub Release Bearing 90363-45012 $26.81
Throw Out (Pilot Bearing) 90363-12002-77 $5.42
BIG Bearing ??? ???
Snap Ring 96152-00450 $2.15
Plate Washer 90201-71001 $1.24
Wave Washer 90206-72001 $1.01
Shaft Snap Ring 90520-67001 $2.75
Washer 90201-45023 $1.96
Clutch Spring Pin 31264-14040 $14.09
LABOR
(this is an estimate. obviously you may just do this yourself. or have a buddy do it. or have a shop quote you something less. this is totally up to you.)
Labor $1,500.00
GRAND TOTAL: ABOUT $5,950. I personally did it for about $4,500 including EVERYTHING. Depending on which R154 you choose, what clutch setup you go with, whether you go with all new parts or (somehow) find used parts, and what you get charged for install, these numbers can VASTLY vary.
We hold absolutely no responsibility if you buy parts that you didn't end up needing or if you mess something up following our guidelines. This is basically just a compilation of all the info we ended up gathering over the past few months either from past members who did similar swaps or from personal research.
WIRING
this is for '01's. I'm almost certain that this is not the same for '02+ IS's (mainly since our '01 IS's draw a speed signal from the ABS, so nothing needed to be wired for that :-)).
There will be 3 plugs that you unplug from the auto tranny. One of them will have 9 wires coming out of it. THIS IS THE ONLY ONE YOU NEED TO MESS WITH. If I remember correctly, the wires come out of some little circles, some are smaller circles (yellow ones), some are larger circles(red ones).
:::For the starter, take the two wires coming out of the 2 larger red circles (its a solid black wire and a black/white wire), cut them and splice them TO EACH OTHER.
:::For the reverse lights to work, my tranny had two wires coming out of the side, a red one and a white one. on the SAME plug where you spliced the two black wired, there will be two red wires. splice these two red wires to the two wires coming out of the tranny (this may be different depending on which R154 you get and what condition its in. unfortunately i can only contribute how my specific wire setup was.)
*if for any reason your wires are different colors or your IS is a different year, all we did was hook up a multimeter to the battery and stuck the little probe into each hole until the reverse lights came on.
AND YES, WHEN I PUT THE CAR IN REVERSE, THE LITTLE "R" IN MY DASH LIGHTS UP ORANGE LIKE IT USED TO, WHICH IS SWEEEET!!
'01SpectraBlueMica
| SRT 2.75 | BBK | LSD | Hotchkis | R 1 5 4 |
| CWest | Eibach | DefiBF | AlpineNav | AAC |
©2006 my.IS
SWTEA LIONHEART
LO 21 is offline Reply With Quote
Old 01-13-2009, 12:39 AM   #2 (permalink)
oh CRAP! i didn't mean to click "Submit" yet. meant to click "Preview". didn't want to post without PICTURES, but i guess i now have to have them up by tomorrow now! (today, that is.. after i sleep some)
EDIT: i haven't finished cleaning out the interior, installing some sort of dynomat product for sound insulation, and putting in my new shift boot, so i wasn't gunna post pictures yet. but because of my idiot accidental post last night, i guess i had to get the pics posted up today ;-)
my WAREHOUSE of a car before heading to the shop (mind you, my car was like this for WEEKS, couldn't stand driving around like that anymore)
Taking center console and auto shifter assembly apart
Tranny OUT!
Trunk and backseat getting emptier :-)
stock 1JZ flywheel in. beautiful. (didn't want to go with any lightweight one)
Driveshaft in
here's one of the only damn reasons why this swap took longer than it ever should have. God damn plethora of wires from Clifford alarm system, then add to that all the boost-related gauge wiring, AND the actual Haltech. All shoved under there sloppier than a drunken ho on a saturday night street corner. so we unziptied EVERYTHING and reorganized it all. we actually ended up with A LOT more room under there than there was before, even WITH the whole clutch pedal assembly installed.
a simple plate i cut out of sheet metal to cover up the hole. bolted into the holes that the auto shifter assembly used to be bolted into
BEFORE
AFTER!!
BEFORE
AFTER (that's in neutral. about a half an inch farther back than i would have liked but better than it being half an inch forward!)
like i mentioned, this is NOT how it'll look once i get a few free hours to reorganize the interior. i just put that stock shiftboot there in the meantime for reference, and to show you guys.
this is something that i investigated for a LONG time and never found a straight answer. from the engine (where the bellhousing starts) to where our shifter would did DEAD CENTER in our center console is 29 1/4 inches. i hope that really helps someone when choosing the tranny or shifter or just to make sure things will line up before doing the actual swap.
'01SpectraBlueMica
©2006 my.IS
SWTEA LIONHEART
Old 01-13-2009, 01:10 AM   #3 (permalink)
vroomRollLEX is an elite community membervroomRollLEX is an elite community membervroomRollLEX is an elite community membervroomRollLEX is an elite community membervroomRollLEX is an elite community membervroomRollLEX is an elite community membervroomRollLEX is an elite community membervroomRollLEX is an elite community membervroomRollLEX is an elite community membervroomRollLEX is an elite community membervroomRollLEX is an elite community member
i salute you, you are now a man, lol
great write up sir!!
+rep is coming your way!!
2002 IS300 BO, 6-Speed
2002 IS300 CW
DIY King
vroomRollLEX is offline Reply With Quote
Old 01-13-2009, 01:27 AM   #4 (permalink)
RIALTO MIKE is an elite community memberRIALTO MIKE is an elite community memberRIALTO MIKE is an elite community memberRIALTO MIKE is an elite community memberRIALTO MIKE is an elite community memberRIALTO MIKE is an elite community memberRIALTO MIKE is an elite community memberRIALTO MIKE is an elite community memberRIALTO MIKE is an elite community memberRIALTO MIKE is an elite community memberRIALTO MIKE is an elite community member
geeeeezzzz. i thought i wrote small books, but thats a novel. good stuff, i like the heavy amount of research you obviously did. props and plus rep
I NOW OFFICIALLY HAVE TOO MUCH TO LIST ON MY CAR.
RIALTO MIKE is offline Reply With Quote
Old 01-13-2009, 07:57 AM   #5 (permalink)
Squareback's Avatar
Squareback is an elite community memberSquareback is an elite community memberSquareback is an elite community memberSquareback is an elite community memberSquareback is an elite community memberSquareback is an elite community memberSquareback is an elite community memberSquareback is an elite community memberSquareback is an elite community memberSquareback is an elite community memberSquareback is an elite community member
Nice post Leon. I true +rep.
Got more funky styles that my laser jet got font.
Squareback is offline Reply With Quote
Old 01-13-2009, 08:43 AM   #6 (permalink)
DC5ROY is an elite community memberDC5ROY is an elite community memberDC5ROY is an elite community memberDC5ROY is an elite community memberDC5ROY is an elite community memberDC5ROY is an elite community memberDC5ROY is an elite community memberDC5ROY is an elite community memberDC5ROY is an elite community memberDC5ROY is an elite community memberDC5ROY is an elite community member
Good stuff Leon! I didn't know you were going to post the info so soon. +rep to you my man. Can't wait to have mine in!
R.I.P. 2002 Acura RSX Type-S 362WHP
2001 Lexus IS300 R154 w/LSD-2JZGTE VVTI single turbo (eventually)
DC5ROY is offline Reply With Quote
Old 01-13-2009, 11:07 AM   #7 (permalink)
Monkey Style
coolmonk's Avatar
my.IS Supporter
coolmonk is an elite community membercoolmonk is an elite community membercoolmonk is an elite community membercoolmonk is an elite community membercoolmonk is an elite community membercoolmonk is an elite community membercoolmonk is an elite community membercoolmonk is an elite community membercoolmonk is an elite community membercoolmonk is an elite community membercoolmonk is an elite community member
Does it "feel" more powerful? lol
©2006 my.IS
Why is pump gas never enough?
600rwhp 608rwtq - 110 octane
513rwhp 480rwtq - 92 octane
coolmonk is offline Reply With Quote
Old 01-13-2009, 02:28 PM   #8 (permalink)
ZhiuPei is an elite community memberZhiuPei is an elite community memberZhiuPei is an elite community memberZhiuPei is an elite community memberZhiuPei is an elite community memberZhiuPei is an elite community memberZhiuPei is an elite community memberZhiuPei is an elite community memberZhiuPei is an elite community memberZhiuPei is an elite community memberZhiuPei is an elite community member
Leon,
For the wiring part. in case im using a w58 do u think the tranny should also have two wires coming out for the reverse lights?
Stan
ZhiuPei is offline Reply With Quote
Old 01-13-2009, 03:21 PM   #9 (permalink)
Originally Posted by ZhiuPei View Post
Leon,
Stan
Not 100% sure, but there is plenty of info on the W58 on the board. Try a search and I am sure you will find what you are looking for.
Old 01-13-2009, 03:56 PM   #10 (permalink)
pictures up!!
a few things i didn't mention in the first post.
this swap can be EASILY done on a weekend, IF you have planned it all out, don't end up needing to run around or wait till a business day to get parts, and know what you're doing (or do it with someone that knows what they're doing).
it's not AT ALL difficult, but you've gotta have the right tools.
if i remember this all correctly, our weekend went something like this:
Friday:
around 5pm, took center console apart while letting the car cool down from having driven to the shop.
put car up on the lift, took out the stock driveshaft, disconnected the auto tranny from everything underneath, and dropped it.
Saturday:
bolted flywheel up to the engine.
put pressure plate and clutch disc onto the tranny.
bolted tranny up (it didn't seem like we would have needed to, but we banged out the tunnel a bit where the starter is just to make sure the tranny wouldn't be banging up against anything down there.)
installed the driveshaft. (after we were done and ended up taking it for a drive, something was making some grinding noise. sounded like maybe from the driveshaft. so we put it back on the lift and saw that the driveshaft was hitting the gas tank heat shield. so we banged that in a little bit too with a crow bar.)
cut hole in firewall and installed master cylinder and the hard lines.
began pedal installation but got fed up after a while of being upside down under the dash for so long trying to organzie sh*t under there, and just called it a day around 7pm.
(we hadn't started till about noon, at which point i realized i was missing the big bearing for the clutch. took me an hour to go get it from my friend and bring it back to the shop. THEN we realized i didn't have nor ever knew about the clutch-to-flywheel bolts. they're kind of purplish in color, stronger than normal bolts. so had to locate 6 of those on the spot. luckily another local shop had some.)
Sunday:
just finished pedal assemblies.
Monday:
had to get a new slave cylinder since the used one i had was leaking. put that in. waited for the flexible hose to come in the mail (we used a stainless steel braided flexible hose for an '86-'92 mkIII supra. if you that or something similar to it, then you wont heed the flexible hose from the parts list. and if anyone can chime in on this, we couldn't figure out where the hell the flexible hose bracket goes. there was nothing under there where it seemed it would bolt up to. if any stock manual guys have their car up on a lift any time soon, PLEASE snap a picture for me of that little silver bracket and the slave clyinder, etc.).
put tranny fluid in.
bled the clutch lines.
and we were DONE!
and since we did the swap this weekend at my friend's shop and it was just to two of us, we took a bit of time to install my new intercooler that i had been wanting to put in to replace the SRT one. (its about the same volume, just wider and not as tall. looks more like it "belongs" there in my opinion).
BEFORE
AFTER
'01SpectraBlueMica
©2006 my.IS
SWTEA LIONHEART
Old 01-13-2009, 04:07 PM   #11 (permalink)
awesome, just awesome!!
2002 IS300 CW
DIY King
Old 01-13-2009, 06:48 PM   #12 (permalink)
Installer88 is an elite community memberInstaller88 is an elite community memberInstaller88 is an elite community memberInstaller88 is an elite community memberInstaller88 is an elite community memberInstaller88 is an elite community memberInstaller88 is an elite community memberInstaller88 is an elite community memberInstaller88 is an elite community memberInstaller88 is an elite community memberInstaller88 is an elite community member
+ rep
wish this was around 6 months ago
The only thing I did differently was run a 3 foot stainless steel clutch line instead of messing with the cdd, and the hard line.
Also does your cruise control work? mine does not and I think it is related to a "speed sensor" code but my speedometer works fine
Installer88 is offline Reply With Quote
Old 01-13-2009, 07:06 PM   #13 (permalink)
Bgadidas10 is an elite community memberBgadidas10 is an elite community memberBgadidas10 is an elite community memberBgadidas10 is an elite community memberBgadidas10 is an elite community memberBgadidas10 is an elite community memberBgadidas10 is an elite community memberBgadidas10 is an elite community memberBgadidas10 is an elite community memberBgadidas10 is an elite community memberBgadidas10 is an elite community member
Are you still running the AuTo cluster?
Either way, awesome write up! I bet it makes the car 10 times more fun to drive!! super jealous
Oh and I love how you make an OEM grille work with the C-West Bumper, it looks much better than the mesh that was there before.
+RAPE
2001 MSM E-Shift : Hailie
AAC - Akebono - Alpine - Axis - A'Pexi - CWest - Fidanza - HKS - JIC - K&N - Kaminari - Kenwood - OBX - StopTech - Tein - TRD - Wald
I ain't gotta act hard, I'm under 21 with a SILVER car!
Bgadidas10 is offline Reply With Quote
Old 01-13-2009, 09:40 PM   #14 (permalink)
haha. thanks man. i always appreciate all the comments and stuff you provide. keep em coming! +rep right back ;-)
yep. thanks! DC5ROY and i spoke about this all the time the past few months just trying to not overlook anything.
and thank you as well! +rep to you
YOU'RE NEXT............
haha. how about we make another round craaaaaaaaaaaaaaaaaaaaaazy ass long road trips back to SRT and we trade rides for a day (or three). i LOOOOOVE your car. at some point i'd like to chat with you and compare some details of our SRT setups now that we've had them a few months and are quite a bit more familiar with the ins and outs of our setups.
Leon,
Stan
hey stan. sorry i can't help you there bud. like DC5ROY mentioned, its been mentioned before. and my guess is you can easily find a W58 off another IS that already has the plugs or wires you'll need. good luck!
Originally Posted by Installer88 View Post
+ rep
hey thanks. +rep back
yea, that's probably what i should have done. i ended up ordering a few of the hard lines by accident, so just decided to go that route.
and good question!! i haven't tried the cruise control yet. my guess is no but i'll give it a shot tomorrow.
if not, is there a way to wire it back up??
+RAPE
hey thanks dude. +rep right back.
yep, same cluster i've always had. i wanna keep my true miles, but i kinda like how nothing is lit up until i go into reverse.
definitely fun to drive, and yea, i think that grill looks way better. it has a broken tab so i took a few minutes to sloppily cut it with some metal cutters to kind of just fit it in there to see what it would look like. i haven't taken the time to do a non-broken one neatly, but it seems like lately the exterior of my car has taken waaaaaaaaaay a back seat to my boost project from last summer and now my tranny swap project. so maybe now i'll have the motivation to fix up the exterior again..
'01SpectraBlueMica
©2006 my.IS
SWTEA LIONHEART
Old 01-14-2009, 02:18 PM   #15 (permalink)
Should be starting mine within the next 2 weeks! Just waiting on OS GIKEN to exhange a part for me. I will also be putting up pictures of my swap.
You may not post new threads
You may not post replies
vB code is On
