Natural Progression of an LS swap - Lexus IS Forum
 8Likes
post #1 of 31 (permalink) Old 09-03-2015, 06:41 AM Thread Starter
I figured I'd just leave this here.
I did the LS swap 2 years ago, made my own mounts, pan, and wiring harness. Matt did us all a favor by making quality swap headers.
Engine:
LS2 Bottom End
Eagle Rods
Wiseco pistons
LS3 Heads
BTR Valve Springs
Trunion Upgrade
TickPerformance Custom spec'd cam from Martin
The car makes 425hp+150shot of nitrous as it currently sits, but naturally more is on the way.
I'll let the pictures do the talking.
Video:
Video:
This is currently in the works. Hood shuts no issue. This is going to be fun.
whatthe, juicij36, blkdout and 3 others like this.
hockyplyer18 is offline
post #2 of 31 (permalink) Old 09-03-2015, 07:25 AM
Quoted: 30 Post(s)
veady-veady gUd. That bi**h is clean!
I've owned my IS3 since '03 (12 YRS). Been on this forum for since '04. Why have I never heard of an LS swap? Lexus LS engine swap? Some1 help me out here..
'03 IS3: http://my.is/forums/f87/juicij36s-la...3/#post7846401
suspension:TeinSS/JICMagictower/CuscoAarm/CuscoTypeOS/Hotchkisanti/FIGStoe/FIGStraction/SRTsubframe/TRDlowerarm; engine/exhaust:BrianCrower264/HKSslidecam/SRTHFIw/AAFC/UnorthodoxRacingUltraSS/Dezodredhead/HKSCarbonTi; wheels/tires:WORKVS-XX/BridgestonePotenza; brakes:Rotora355X32; body:LSportline/TRD; lighting:AAC/Xetronic
juicij36 is offline
post #3 of 31 (permalink) Old 09-03-2015, 08:48 AM Thread Starter
LS Swap is a GM ls1, ls2, ls3, Ls7 etc.
post #4 of 31 (permalink) Old 09-03-2015, 09:16 AM
Quoted: 27 Post(s)
Looks really clean sir! I like the way it sounds too, could you share a pic of your exhaust too? Mine seems to be a little louder than that hahaha.
That's a CTSV supercharger correct? Are you going to be able to use your LS1 accessories or will you have to change it out for a different set?
My IS300 - 5.3 LSx swap and Turbo, KWv3's, bushings, sways, wheels, flares, scoops, lots of tire smoke and 620 whp and 650 torque - tons of parts and so much time.
Check out Page 3 of my "build thread" for my car currently- http://my.is/forums/f219/mitchs-ls6-...y-land-522370/
isthreehun is offline
post #5 of 31 (permalink) Old 09-03-2015, 01:53 PM
Quoted: 474 Post(s)
Yeah, this is hot.
post #6 of 31 (permalink) Old 09-03-2015, 05:23 PM
Cherisher
blkdout's Avatar
Quoted: 580 Post(s)
2 years ago. What took you so long to post this?
Sick, man. Hoping for more updates!
-Hiral
blkdout is offline
post #7 of 31 (permalink) Old 09-07-2015, 02:27 PM
I can't even. That's just amazing.
Sent from my Nexus 6 using Tapatalk
bastafari is offline
post #8 of 31 (permalink) Old 09-08-2015, 09:15 AM Thread Starter
The dark video is open headers, dyno run is just one magnaflow muffler.
its the ctsv/zl1 blower. Ill be using the fbody spacing, I was able to find someone selling an adapter bracket.
post #9 of 31 (permalink) Old 09-09-2015, 10:51 AM
Quoted: 26 Post(s)
Good stuff, clean looking work. I spy a Supra in the background. How do you like the LS versus the 2j?
<--- Doesn't believe in stock vehicles
2002 IS300 VVTi GTE v161 Built single - TeCKis300's old car
1995 240sx - NASA PTD trim
Hardrvin is offline
post #10 of 31 (permalink) Old 09-20-2015, 01:32 PM
Quoted: 11 Post(s)
I am considering a V8 swap... I have a few questions...
1- Did you remove the entire stock ECU and harness? I am considering deleting ABS, traction and all that stuff.
2 - How does your fuel gauge work now being that the ECU makes calculations to adjust the needle.
3- Were you automatic or 5spd before the swap?
BigDaddyRich is offline
post #11 of 31 (permalink) Old 09-21-2015, 07:07 AM Thread Starter
Modified the upper rad hose this weekend so I don't have any interference with the throttle body. Hood still closes with the nitrous plate. I might have to trim alittle bit of the hood bracing once i build the intake.
I'll be building the Heat exchanger coolant tank this week.
post #12 of 31 (permalink) Old 09-21-2015, 07:26 AM Thread Starter
Two completely different motors, the 2j feels more refined.
There is no stock lexus ecu in the car. I pinned the GM ecu to the corresponding Lexus circuit. ABS is controlled by the factory is300 abs ecu.
Fuel gauge still works its just not as accurate as it was before.
Factory 5 speed car prior to the swap. The t56 fits almost as if it belongs in the car. I had to trim maybe a 1/2" in the front of the shifter opening.
post #13 of 31 (permalink) Old 09-21-2015, 12:07 PM
Quoted: 10 Post(s)
Very clean swap. What's in the Supra?
2J_Rob is offline
post #14 of 31 (permalink) Old 10-13-2015, 04:02 PM
Quoted: 14 Post(s)
Awesome, Subscribed!!
REME is offline
post #15 of 31 (permalink) Old 10-19-2015, 04:21 PM
My new favorite thread! What a clean swap.
Steve Theodore is offline
