NA-t vs gte - Page 3 - Lexus IS Forum
 4Likes
post #31 of 63 (permalink) Old 02-06-2017, 12:07 PM
Quoted: 132 Post(s)
Originally Posted by somguy2u View Post
you'll have to do a lot of work to make stock ecu happy with a different motor.
I have passed emissions with a standalone and a piggyback, and it's hard.
if you want simple, just boost it to 7psi sock everything except and a fuel return and an adjustable rising rate fuel pressure regulator with a big fuel pump. i've seen 350 hp out of it and it will pass emissions with easy driving for a while. passing emissions in a highly modified car is just flat out difficult. You have to know how to drive, you have to monitor all the fuel trims, cats, evap constantly.
it's a bear
Not as hard for OBD2 only.
No check engine light = pass. Assuming they don't catch on and decide to sniff.
cleansleeper is offline
post #32 of 63 (permalink) Old 02-06-2017, 12:15 PM
Virgin Magnet
somguy2u's Avatar
Quoted: 44 Post(s)
getting all the readiness checks to be ok is the hard part. you can't wipe it and test. you have to drive clean for 1k miles or so. in GA it's one readiness can be not ready and the rest have to pass and no CEL, and i have heard people get failed for pending codes.
TUI
Motorsports
Own the dream
LC SSI 006
SWTEA Talon
somguy2u is offline
post #33 of 63 (permalink) Old 02-06-2017, 12:35 PM
Quoted: 41 Post(s)
I haven't lived in a single place where I haven't had to pass sniffer and I find it difficult to believe that it would be that easy.
IS3TT
FRaCTioNaL is offline
post #34 of 63 (permalink) Old 02-06-2017, 01:17 PM
Quoted: 57 Post(s)
In Nevada they just plug it in. If no check engine you're good. That's assuming you are OBDII
jesuspuppy is offline
post #35 of 63 (permalink) Old 02-06-2017, 01:30 PM
Quoted: 132 Post(s)
Same in Maryland. No check engine, pass emissions.
With a full standalone like ProEFI and O2 simulators you can easily trick your factory ECU into not showing anything.
No station I've gone to has ever smelled the exhaust or looked under the hood or anything.
post #36 of 63 (permalink) Old 02-06-2017, 03:11 PM
Quoted: 53 Post(s)
it's a bear
Simple as in what exactly with the computer. What will only 7psi help with the ECU? Wouldn't you need to have at least a piggyback or some sort of control no matter what you do if you install a turbo kit on a GE motor?
allturbo98 is offline
post #37 of 63 (permalink) Old 02-06-2017, 04:03 PM
Virgin Magnet
somguy2u's Avatar
Quoted: 44 Post(s)
no computer needed... no piggyback, no standalone, just stock injectors, big fuel pump and a rising rate regulator. i have heard that a static 12:1 will work just fine, maybe a bit rich but if your on stock compression that won't be an issue. Adjustable rate would be ideal though. you'll throw codes for MAF being maxed out and maybe some misfires but it'll run like stock - just faster.... thats why i said you have to drive careful to pass. the ecu reset relay is this set-ups best friend for fun driving
TUI
Motorsports
Own the dream
LC SSI 006
SWTEA Talon
somguy2u is offline
post #38 of 63 (permalink) Old 02-06-2017, 04:05 PM
Virgin Magnet
somguy2u's Avatar
Quoted: 44 Post(s)
have you ever tried?
TUI
Motorsports
Own the dream
LC SSI 006
SWTEA Talon
somguy2u is offline
post #39 of 63 (permalink) Old 02-06-2017, 04:09 PM
Quoted: 132 Post(s)
Personally? No. After my build is done and I go through emissions I can update.
I know people around me on other platforms that have using the same principals and it's been done in this car before too.
post #40 of 63 (permalink) Old 02-07-2017, 03:32 PM
Quoted: 53 Post(s)
Will ECUMasters be a good computer setup for turboing the car?
post #41 of 63 (permalink) Old 02-07-2017, 03:44 PM
Quoted: 41 Post(s)
Someone's been browsing SF!
ECUM is good. They do not provide a plug and play solution for the IS3, so you'll have to wire it in. Always a good idea to contact the seller with questions though.
IS3TT
post #42 of 63 (permalink) Old 03-08-2017, 03:00 PM
Quoted: 53 Post(s)
Well, if I am only going for 350hp will a AEM FIC or Greddy EMU be good to use or will I need to use something else? Not trying to get a lot of power, just enough to be fun here and there like my last turbo car and it only had 380hp and I was definitely fine with that.
post #43 of 63 (permalink) Old 03-08-2017, 03:40 PM
Quoted: 57 Post(s)
It will work... But certainly not ideal. Reliability won't be all there with either. Do it right or do it twice. I'm currently doing it for my second time. You think it's easier and cheaper... But it's not.
post #44 of 63 (permalink) Old 03-08-2017, 06:08 PM
Quoted: 41 Post(s)
+1, it will work.
But that's about it.
IS3TT
post #45 of 63 (permalink) Old 03-09-2017, 10:34 AM
Quoted: 53 Post(s)
What would be a good alternative to these? I know a standalone would be the best, but which one because AEM infinity sounds good, what about a MegaSquirt. For the Megasquirt, don't you have to put it together? Im still new to the engine managements. Most cars ive had just required upgraded turbo parts and a SAFC to get it to run good. Just trying not to spend too much money for only a little power.
