Fuel Return Line? - Lexus IS Forum
post #1 of 73 (permalink) Old 04-07-2006, 04:14 PM Thread Starter
Sophie's Pimp
Seven's Avatar
Fuel Return Line?
Well, i went out and bought 14ft of fuel hose, as well as fittings, and now my only question is this: What do i need to modify in the pump housing to complete the return assembly?
I tapped the top of the housing and put the fittings in, but where do i need to run this line to? I've tried searching, but anytime i click search, or go to advanced search, i get the good ol "Server is too busy" message (webmaster, you gotta do something to fix that, its been killing me lately).
Any help you folks can give me would be greatly appreciated.
Also, i have a bit, i have a tap, now how do i get access to the damn drain hole in the motor? Drop the pan and do it that way? Lemme know folks.
Originally Posted by leonard_is300
i am loving the V9 swaps now!!!
2004 Black Onyx 6spd. GT4094R, Autronic SM4 5000rwhp / 4300rwtq (Most people on here make up their numbers anyways, so why not join the train)
2005 Dodge Ram 2500 Turbo Diesel. More HP and Torque from the factory than many of the modded cars here. 8)
Seven is offline
post #2 of 73 (permalink) Old 04-07-2006, 04:50 PM
Here's what you need to do to the fuel pump assembly.
1. Drill a hole in the plastic fuel pump assembly.
2. Get a bulk head fitting and install the fitting on that new hole.
3. Install the return line from the FPR to the end of the fitting that's exposed.
4. The other end of the fitting that will be in the tank needs to connect to the white ventricle.
5. Cut the line that's connected between the stock FPR and white ventricle.
6. Either pinch the nipple that is now exposed on the stock FPR closed and weld it shut or get 1/4" fuel line, 1/4" bolt that has no threads on the shoulder. Cut off the threated area of the bolt, insert the bolt in the 1/4" line and put a hose clamp on it. Put the other end of the rubber line on the stock FPR.
6. Run rubber line from the bulkhead fitting to the end of the white ventricle that the stock FPR was connected to.
lambchop11078 is offline
post #3 of 73 (permalink) Old 04-07-2006, 04:52 PM
Tap the top front of the rail and put in the fitting. Then from the rail the hose goes to the FPR. Then from the FPR the return hose goes back to the pump assembly
Third time around
2002 6spd IS300 w/ a whole lot of goodies
573whp and 510tq @ 19psi 93 pump
805whp and 695tq @ 32psi meth mix
*10.67 @ 144mph 1.66 60' on ET street drag radials
*11.33 @ 137mph 2.1 60' on street radials
Sold. No more boost for me. I'm done
goldaltezza808 is offline
post #4 of 73 (permalink) Old 04-07-2006, 04:55 PM
dual intank walbro pumps installed **lots of pics**
look how Henson did his...he has dual pumps...but still, GREAT pictures!
Master Certified Lexus VEHICLE TECHNOLOGY SPECIALIST and INTERNET SALES MANAGER @ LEXUS OF PALM BEACH
2015 NX200t F-SPORT ULTRASONIC BLUE
1993 Toyota Supra
SOLD 2002 IBP JDM NEO/RANDO TURBO
500rwhp+@ 17 psi
R.I.P. 2001 SBM L-TUNED Toyomoto Built TURBO
LEXOTIC CONCEPTS NE017
tsopranoMB is offline
post #5 of 73 (permalink) Old 04-07-2006, 04:57 PM
Haha thanks marc
Third time around
post #6 of 73 (permalink) Old 04-07-2006, 09:51 PM Thread Starter
Sophie's Pimp
Seven's Avatar
alright, what do i do to those? Im guessing 3 is the one i pinch shut and weld tight?
What about 1 and 2, which of those gets the return hose?
Thanks again for the help.
Seven is offline
post #7 of 73 (permalink) Old 04-07-2006, 09:57 PM
from the explanation, you simply 'take out' the stock fpr out of the equation - so your return lined needs to go to the rubber line that the stock (oem) fpr was connected to (#3 in ur pic)
TeckniX is offline
post #8 of 73 (permalink) Old 04-07-2006, 10:41 PM
And if I remember right the line coming from the passenger tank hooks up to #1
Third time around
post #9 of 73 (permalink) Old 04-08-2006, 07:34 AM
1. Connects to a rubber line that's in the tank already, leave that alone.
2. Connects to nothing, leave that alone.
3. Snip the black line, close off the end of the stock FPR. The return line should come through the hole near the Walbro pig tail then connect to where the stock FPR was connected to.
post #10 of 73 (permalink) Old 04-08-2006, 02:21 PM Thread Starter
Sophie's Pimp
Seven's Avatar
sounds good, thanks again folks.
Seven is offline
post #11 of 73 (permalink) Old 04-08-2006, 04:26 PM
TeCKis300's Avatar
I assume all of you who have done it this way don't have problems with getting fuel from the other side of the tank? TE's setup requires a few more tweaks (drilling out jet valve larger, and flipping the nozzle contraption that you guys are talking about) but it obviously didn't work well that way.
Car sold to a good new home!
TeCKis300 is offline
post #12 of 73 (permalink) Old 04-08-2006, 04:38 PM
I didn't drill the hole bigger, I don't believe I have any problems with getting fuel from the other side of the tank. I can look again later on during the spring.
post #13 of 73 (permalink) Old 04-08-2006, 10:56 PM
dont drill te hole, and dont flip no nozzle.
2011 ZCP Melbourne Red M3 Coupe. 6MT
Malekreza11 is offline
post #14 of 73 (permalink) Old 04-09-2006, 05:21 AM Thread Starter
Sophie's Pimp
Seven's Avatar
thanks again guys, got it all figured out. +repped everyone who lended a hand and info
Seven is offline
post #15 of 73 (permalink) Old 04-09-2006, 12:14 PM
or (-) rep'd some :\ HAHA
TeckniX is offline
