Below is a list of different engine management systems, and their features. After listing the engine management systems I found, i'll include a price list at the bottom of the page.
Links to engine management systems:
Megasquirt
Autronic
Motec
Haltech
AEM
Tec 3
Microtech EFI
E-Manage Ultimate
E-Manage (Blue)
MAP ECU
Pro EFI
Engine Management Systems and their Features
Autronic SM4
HARDWARE:
Main Connector 42 way sealed with protective cover.
PC serial data link connector 3 way 3.5 dia.
Case, silver extruded aluminium, 130 x 124 x 48 MM (overall).
Processor speed 25% faster & overall performance > 2.OX previous generation.
OK to 13,000 rpm on 16 cylinder engine. 1 to 12 cylinders to > 16000rpm.
ECU to PC data link operates at up to 115k baud for fast cal down load & Log file upload (19sec typ for 112k bytes). 112k logging memory.
Internal Diagnostic light & optional remote light.
High efficiency power supply & output drivers for reduced power consumption and reduced self-heating.
Four ignition outputs. (With external multiplexer up to eight) Rating Push-Pull +/-1 amp max. Up to 3 useable for alternate functions.
Software selectable mappable dwell or O/P pulse duration modes possible.
Four coil dwell, software selectable. (With external multiplexer up to eight)
Eight injector outputs. Rating selectable software 4/1 amp 2/0.5 amp peak/hold type for high & low current injector types or parallel operation of injector pairs. Rating may be specified independently for 2 groups of 4 O/Ps. Sequential, single or double shot 1 or 2 group fire possible for up to 16 injectors. Up to 7 useable for alternate functions.
10 General purpose (GP) outputs, 3 PWM (dedicated), 5 Pull-down @ 3.5 amp max, 1 Pull-down @ 1 amp max, 4 Push-Pull @ +/- 1 amp max (also suitable for stepper motor control).
15 PWM using GP outputs, spare Injector or Ignition O/Ps. All have 1 OHz min, 3 have upper limit of 50OHz, 2 have upper limit of 1.2KHz.
In-built dual reluctor interface / hall effect interface. Camshaft & crankshaft sensor inputs individually software configurable for hall effect & reluctor sensor types. Response speed is also software configurable for improved noise immunity.
Three general purpose digital Inputs with logic level sensitivity & pullup to +5volts. Useable for speed measurement. Switch I/Ps. Two are useable for Camshaft position measurement.
Knock control with individual cylinder retard (requires installation of additional internal module).
Variable Camshaft control for up to two camshafts. VANOS and other VVT and VVT-i supported.
Autronic or NTC air temp sensors, software selectable.
Internal or external map sensor, software selectable.
High and low injector driver software selectable.
Stepper motor idle control.
Support for most idle valve type including 2 wire, 3 wire & stepper possible. Stepper pins can be used for spare outputs if not used for idle control.
Support for air flow meters.
Internal Pressure sensor useable for MAP &/or barometric sensing.
Tacho & Diagnostic outputs.
3 x Spare Analog inputs (EGT, EBP, 02, etc...) Spare analog Inputs may be used as additional low speed digital inputs (eg:- switch inputs). Two have dual logic levels (two switch levels per input)
Analog inputs can be set for predefined calibrations or user defined calibrations.
SOFTWARE:
Autotune (self tuning software).
Launch Control (two step rev limiter based on vehicle speed).
Flatshift (change gears without clutch at WOT using standard gearbox).
Antilag (keep turbocharger on boost during gear changes) with turbo cooldown function.
Selectable ignition tables. Output tables can be based on any X and Y axis parmentier.
Fuel and ignition tables have 32 rpm and 16 load site axis.
Many correction tables for precision fuel & ignition adaption.
Table axis values totally user selectable.
Multi tooth, missing tooth, Subaru, Mitsubishi, Ford TFI and Gen3 triggers. Software selectable trigger angle.
Support for two and three rotor engines with ignition split.
Dedicated idle control with additional settings for better adaption to changing operating condition and a more stable idle.
Dedicated Closed loop boost control, and other settings for stable boost pressures. Dedicated A/C compressor control.
Dedicated twin cooling fan control.
Dedicated NOS injection control, coordinates fuel & ignition.
13 General purpose control modules for O/P control. (use for variable fuel pump, power steering, inlet manifold air valves, extra temperature control devices etc) 4 of these are capable of PID feedback control (typical application for PIDs are variable camshaft positioning or inlet manifold length).
Mapping via manifold pressure, throttle position, manifold and throttle or manifold, throttle and exhaust backpressure.
Autronic SM2
Features:
1. a. Eight injector drivers for full sequential operation on engines up to eight cylinders. May be set for 'semi-sequential' operation on engines having more than 8 cylinders. e.g:- 12 cylinder engine using 6 groups of 2 two cylinders.
b. All injector types catered for (0.9 ohm to 16 ohm coil resistance). Specify unit fitted with optional high current injector drivers for 0.9 ohm or twin injector applications.
2. User choice of manifold absolute pressure or throttle position as engine load input. Internal absolute
pressure sensor for simplified installation 0 to 200 kpa (0 to 29.4 PSI) and 0 to 300 kpa (0 to 44.1 PSI) available from stock. 0 to 450 kpa (0 to 66.1 PSI) available on request.
3. Single coil distributor, twin coil distributor or muilticoil distributor-less ignition configurations are possible on most engines.
4. Closed loop (feedback) boost pressure control for turbocharged engines with multiple calibration curves selectable by switch input or road speed (eg:- lower boost curve for use in low gear).
5. Closed loop (feedback) idle speed control.
6. Exhaust oxygen sensor input for sensing air/fuel ratio. Connect either a Bosch narrow band O2 sensor or for more demanding applications a Bosch wide band O2 sensor and Autronic Analyzer. The low cost narrow band sensor requires no interface adapters or expensive air/fuel ratio meters, and offers moderate accuracy and tolerance to leaded fuels. This function can be used to monitor air/fuel ratio during engine tuning or can be used for feedback control of air/fuel ratio for applications requiring exhaust catalytic conversion (feature available on request).
7. Diagnostic/Error indicator of sensor or ECU fault conditions with memory for detection of intermittent fault conditions.
8. Measurement of end correction for exhaust back pressure (applicable to turbocharged engines).
9. Control of engine cooling fans and coordination with air conditioner operation.
10. Programmable on/off output for solenoid or relay driving that operates according to engine speed and load (eg:- can be used for gear shift control or light, over rev indicator, inlet camshaft timing selection or control of a supplementary electric fuel pump that augments mechanical fuel pump delivery at low engine rpm only).
11. Precise spark advance control strategy for both static and dynamic operating conditions.
12. Unique calibration strategy allows accurate control of fuel delivery under both acceleration and deceleration.
13. User selectable spark and fuel delivery strategy for abnormal engine operation conditions to minimize possibility of engine damage whilst still maintaining engine operation.. (eg:- over heated or over boosted).
14. Comprehensive limp-home functions with user selectable default settings that ensure engine operation can continue after sensor failure has occurred.
15. User defined proportional output function that can be used for additional functions as outlined in 10 above or for a more sophisticated control function such as servo control of auxiliary butterfly for turbocharged applications requiring precise throttle control and minimum turbo lag.
16. Full compensation of engine control parameters for engine operation at any altitude (fuel delivery, ignition timing and boost pressure).
17. Adaptive learning (with memory) to minimize the number of user setups required and to provide optimal control of air/fuel ratio, boost pressure and idle stability.
18. Rev limiter with soft characteristic that uses a combination of fuel delivery and spark control.
19. Fuel pump safety shutoff. Pump stops 3 to 4 seconds after the engine stops.
20. Bi-directional input/output line for simultaneous connection of remote adjusting unit.
21. Standard unit is ultra light weight/compact yet has sufficient drive capacity for high power continuous duty applications. (one unit OK for all applications from motor cycle to large capacity twin turbo engines).
22. User configurable data logging of up to 17 channels with the selected channels being sampled as fast as 50 times a second. With 32k bytes of non volatile memory.
23. Optional interface unit to allow sequential operation without the need for separate crank/camshaft sensors or special multi-sensor distributor.
24. Fuel used pulse output to electronic or electromechanical counter with resolution of 0.1 liter (or use with trip computer).
25. Remote monitoring of all functions using telemetry adapter, ECU can perform simultaneous logging and telemetry.
26. Water injection/intercooler cooling for intake charge temperature control in turbo/super charged applications.
INPUTS
Sensors:
Main:
1. Ignition input Hall effect, (Also available for direct connection to magnetic reluctor type pickups).
2. No. 1 cylinder reference. (Also available for direct connection to magnetic reluctor type pickups).
3. Road speed input. Hall effect (Also available for direct connection to magnetic reluctor type pickups).
4. Turbo speed input. Magnetic Reluctor (must use optional interface adapter).
5. Barometric pressure. (Internal to ECU).
6. Manifold pressure. (Internal to ECU).
7. Throttle position.
8. Intake air temperature.
9. Engine coolant temperature.
10. Exhaust back pressure (optional).
11. Exhaust oxygen. (or optional Wide Range Air/Fuel Ratio Sensor).
Auxiliary:
1. Air conditioner request.
2. Boost curve select.
Adjustments Idle mixture trim. (Internal to ECU and screwdriver adjustable from outside).
OUTPUTS
Main:
1. 8 off injector driver. (Optional 2 injectors per driver).
2. 4 Ignition output.
Open collector output to any of the following:
1. Single coil high energy ignitions: Bosch 7 pin, Mitsubishi 3 pin.
2. Autronic Capacitor Discharge Ignition.
3. MSD 6A etc..
(4 outputs are available allowing multi coil distrubtor-less ignition for applications on engines up to 8 cylinders).
Auxiliary:
1. Fuel pump/injector fuel shut off safety relay.
2. Air conditioner clutch relay.
3. Engine/Air conditioner cooling fan relay.
4. Engine cooling fan relay.
5. Idle speed actuator. (Variable duty cycle single pole type, eg:- Bosch).
6. Turbocharger wastegate control valve. (SEM, most OEM types or Autronic low or high capacity).
7. Turbocharger auxiliary butterfly control motor.
8. Spare duty cycle output with user define characteristic.
9. Fuel used pulse output. (for trip computer function).
Haltech E6X
Features:
Up to 4 fuel and 4 ignition channels (internal toggle)
4 dedicated PWM outputs
1 auxiliary input
1 auxiliary output (tacho output)
Dedicated closed loop idle control
Dedicated closed loop O2 correction
8 injector drivers as standard equipment
An internal barometric pressure sensor
New RA8 reluctor adaptor
Rev Limiter
Deceleration fuel cut
Datalogging to laptop
Flatshift
Dual Mapping
High boost software (up to 65 pounds with optional MAP sensor)
The E6X is capable of controlling up to 8 low impedance or
16 high impedance injectors. If necessary an additional driver
box can be added for more injector outputs. The E6X System
optimizes engine performance by giving full control over fuel,
ignition and auxiliary outputs.
PWM outputs:
*electronic boost control *thermofan *anti-lag *VTEC
*engine control relay *NOS enable *BAC valve *shiftlight
*intercooler fan *turbo timer *stall saver *air con
*aux. fuel pump *staging signal *dual intake valve
*torque convertor
(not all functions are available at the same time)
System Features:
Fuel Correction Maps:
Coolant Temperature, Air Temperature, Battery Voltage, Cold Prime, Zero Throttle, Full Throttle, Injector Phasing (Seq. only), Throttle Pump, Injector Trim (Seq. only), Barometric Pressure, Ignition Correction
Maps:
Ignition Crank, Air Temperature, Coolant Temperature
Trigger Signal Type:
Inductive Magnetic-(Internal Signal Conditioning), Hall Effect Sensor, Optical Sensor
Trigger Pattern:
Twin Trigger, Multi-Tooth, Subaru, Single Pulse per Cycle, Bosch Motronic (60t-2), Nissan, Mazda, Diahatsu
Ignition Configuration:
Twin Distributor, Twin Rotor (Dist. or DF), Single Distributor, Direct Fire: 1-4 Cylinder, Waste Spark: 4, 6, 8 cylinder
Injector Firing Mode:
Throttle Body (Batch), Sequential (up to 4 banks), Multi-Point, Staged
ECU inputs:
MAP Sensor, Coolant Temperature, Air Temperature, Throttle Position, Internal Barometric Sensor, Primary Trigger, Secondary Trigger, Oxygen Sensor, Spec Purpose Digital, 2x Gen. Purpose Analog, Road speed
ECU Outputs:
Injector Drivers: 8, Fuel Pump Relay Control, Dedicated PWM Outputs (4), Idle Air Control (IAC), Ignition Output, Spec. Purpose Digital (2)
Haltech F10X
System Features:
Maps:
Coolant Temperature, Air Temperature, Battery Voltage, Cold Prime, Zero Throttle, Full Throttle, Throttle Pump, Auto Barometric Comp.
Hall Effect Sensor, Coil Negative, Optical Sensor
Trigger Pattern:
Multi-Point, Throttle Body (Batch), Staged
ECU Inputs:
Primary Trigger, Air Temperature, Throttle Position, MAP Sensor, Coolant Temperature
ECU Outputs:
Injector Drivers F10X (4), Fuel Pump Relay Control, PWM outputs (x4)*, Special pupose digital (1)*, Idle air control (IAC)*, Closed loop O2 correction*
Accessories:
Fuel / Boost Trim Module, Boost Control Solenoid, Idle Air Control Motor, O2 Sensor
Engine Data:
Map Storage and Retrieval, Data Logging
Tec 3
Standard features:
PC programmable and configurable for 1, 2, 3, 4, 6, 8, cyl. engines and Rotories with a 12 cyl.and 6 cyl dual plug option
Operate in Open or Closed loop
Run True Sequential, Phased Sequential or Simultaneous Injection with individual cylinder trim
Configurable for TBI, MPI, TPI and individual throttle bodies
Additional Injector Output Drivers built-in.. Run Low or High impedance injectors
Full 150 mJ of Spark Energy directly to the plugs without misfire
New Dual Rev Limiters with ‘Triple Smooth Technology’.. 1st step retards timing to a negative -12º degrees.. 2nd step cuts coil current in half.. 3rd step coil current and fuel are cut-off.. all three steps occurring within milliseconds!
Waste Gate (Boost Control), Nitrous Control with up to 4 stage retard available
Four Programmable GPO’s (General Purpose Outputs) to control or activate VTEC, Shift Lights, Water Pumps and Fans, A/C Compressor, Torque Converter and more.
New Programmable Adjustable Electronic Tachometer Output
Uses primarily GM type sensors
Diagnostic monitoring with codes issued through Check Engine Light
Easy to install bolt-on Trigger Wheel and Mag Sensor Kits available for many applications
New On-Board Data Acquistion:
Adjustable Sample Rates up to 100 samples per second Simultaneously record data from up to 25 inputs including: Air/fuel Ratios, Injector Duty Cycle and Pulse Width, RPM and Throttle Position, Gear Position, MPH, Boost (manifold pressure) and much more!
Additional configurable Digital and Analog Input Channels View Multiple Data Graphs side by side or Graphs may be overlayed for comparison Graphic Screen Displays may be Printed
Data may also be exported to a Spreadsheet program for further analysis Data Logging can be started and stopped manually using a switch, or the system can be configured to automatically start and stop via values pre-set by the user
The TEC³ Engine Management System will run the following configurations:
4 Cylinder, 6 Cylinder, 8 Cylinder, 4 Cylinder (Dual Plug), Staged Injection, Sequential Injection
(From Lambchop)
Installation
In theory, the TEC3 only needs 2 sensors to get a motor up and running...the crank trigger and MAP sensor. The TEC3 uses a 60-2 trigger wheel, the wheel has 60 teeth with 2 of them missing, each tooth represents 6 degrees of advance allowing the TEC3 to have very accurate timing. A crank trigger sensor reads the wheel, the wheel needs to be installed in a specific orientation relative to piston 1 TDC, this tells the TEC3 engine speed and piston location/stroke. The MAP sensor is needed to tell the TEC3 engine load.
Pros: Very easy installation, accurate timing with high resolution.
Cons: Trigger wheel wobbles a little bit, cannot use stock crank wheel/sensor.
Tuning
The TEC3 has 2 main tables for tuning, VE and Ignition Timing. Once you install the TEC3, you can use the Tuning Wizard software to create a base map for you. You enter the injector size, MAP sensor size, horsepower level, and a few other injector parameters. From these inputs a raw fuel curve is created. You alter the VE table by either adding or removing up to 50% of fuel from it. Altering the Ignition Timing map is pretty straight forward, set the timing angle to ignite the air/fuel mixture.
Pros: Tuning software isn't too difficult to use, pretty straight forward.
Cons: The VE table allows a max of 50% of fuel modification. If you find yourself needing more than 50%, you'll need to alter the pulsewidth offset. If you change the pulsewidth offset, you'll need to go back and redo the rest of the VE table. Since the VE table is just a raw fuel curve, if you have an inconsistent MAP reading, you'll see your injector pulsewidth constantly change. This makes it a little difficult to get a very smooth idle. There's a way to work around this though and that's to use the TPS blend feature. The TPS blend feature allows you to use the TPS sensor voltage as a percentage of your MAP reading.
Inputs/Outputs
The TEC3 has 4 GPOs (general purpose outputs) and 4 GPIs (general purpose inputs). Two of the GPOs can be used as a PWM output. One of the GPIs can be used for auto-tuning another fuel map called the EGO table. There are some nice features of the GPIs like using a toggle switch that triggers a "Valet Mode" that will activate a RPM limit. Another feature is enabling a onboard data logger.
Fuel Enrichment/Cut off
The TEC3 has fuel enrichment for acceleration, intake air temperature correction, coolant temperature correction, battery voltage correction, deceleration fuel cut off, and over boost fuel cut off.
Knock Control
The TEC3 has a knock control feature that will retard timing and slowly add it back.
Pros: You can splice your stock knock sensor to it.
Cons: Reads only 1 knock sensor, the 2JZ has 2 knock sensors. There's no way to calibrate the knock sensor voltage.
Sensor Calibration
The TEC3 has a calibration option for TPS, knock, MAP, coolant, intake air temperature, and EGO.
Pros: Stock sensors can be used for most of the sensors.
Cons: The calibration is very limited, you can enter a min and max voltage value as well as a default error value.
Overall Opinion
Pros: The TEC3 has an unbelievable ignition system. It's very powerful and works well in the IS300s wasted spark setup. It's very easy to tune, easy to setup, is pretty complete (no need for an ignition amplifier or knock retard system), and works pretty well.
Cons: The tuning software is pretty buggy and the firmware has quite a few bugs. Granted all software in the world has their share of bugs but it comes down to how severe the bug is. Upgrading the firmware can cause the TEC3 to lock up, it's documented about 5% of the units will lock up...pretty scary statistic. Can't retrieve the cal file once it's downloaded on the unit.
E-Manage Blue
GReddy’s e-Manage is a cost effective programmable engine management system that allows you to properly tune your factory engine control without having to change the entire factory ECU system to an expensive "stand-alone" unit or the inconvenience of sending it out for a full ECU reprogram. The e-Manage system is a true universal "piggy-back" type unit that taps into most Japanese factory ECU wiring, by utilizing the vehicle’s existing sensors (or optional upgraded sensors if factory sensors are maxed out). The major benefit is the factory ECU settings become your "Base-MAP" for tuning. There is no need for extensive tuning for normal driving conditions, but does allow the tuner to fine tune, adjust for injector changes, and add new MAP(s) for situations the factory ECU is not capable of (like on-boost conditions). And as technological breakthroughs are achieved, we offer FREE updates via our greddy.com website’s Tech page. Basic functions will allow the tuner to slightly alter factory injector duty-cycle (± 20% at 5 preset RPM points) by intercepting and altering airflow or MAP sensor signals. An option for Honda VTEC cars will allow you to even adjust the VTEC shift point. Additional features are built into the system but are only accessible through the use of the e0-1, PRofec e-01 programmer or our PC-Windows based "e-Manage Support Tool" communication software (sold separately). There is a 16x16 airflow adjustment map, a maximum 50% larger main injector correction adjustment, upgrade air flow meter adjustment, boost limiter cut, anti-engine stall, VTEC-fuel adjustment, real-time map trace, real-time display, real-time communication and basic Data-logging. With the use of our "Optional Injector Harness" and the software, the unit has the ability to control an additional 16x16 injector duty cycle map and the controls for adding up to 2 additional sub-injectors. If the "Optional Ignition Harness" and the software are used the unit has the ability to control a 16x16 ignition timing map. All of the above maps can also be map-traced in real-time as well. If the factory range of map or airflow meter is surpassed, you can incorporate a larger airflow meter or our "Optional GReddy Pressure Sensor and Pressure Harness" to set larger scales of adjustment. All installation and tuning should only be made by a trained technician with proper air/fuel monitoring tools. (Some or all functions may not be compatible with some applications.)
(injector and ignition harnesses are separate from what i see here on their page, along with an array of other options. They dont come standard.)
E-Manage Ultimate
The GReddy e-manage Ultimate is as close to a stand-alone management system as you can get while maintaining the best features of a "piggy-back" engine management; an economical price, the usage of existing sensors, the ability to easily alter factory settings and not having to tune from scratch. But unlike the original e-manage, the Ultimate is more refined, requiring specific application usage (which we are constantly adding application updates that you can download FREE via greddy.com, Tech WebPages.) The benefit of this is, the included PC-based USB "Ultimate Support Tool" allows for even finer tuning capabilities, improved flexibility in fuel & ignition control and adds impressive data-logging qualities to make tuning quicker and easier. The increased number of input and output ports of the Ultimate, along with new built-in adapters add many new options to the unit. In addition to standard e-manage airflow-based adjustments, the Ultimate version includes new and upgraded features. The Parameter Set-up, tab menu format of the Ultimate has improved direct Map control for adding and subtracting Fuel and Ignition. The ability to switch between 2 preset tuning Maps (i.e. Street or Race program) via externally mounted toggle switches. There are Maps for Individual cylinder adjustment for both Fuel and Ignition. There are also options to convert injection and ignition systems (i.e. group or sequential injection and group or individual fire ignition.) An Airflow Output Map option even allows for airflow meter elimination. And when used with a wideband A/F Meter, the Air Fuel Target Map can self-tune an Injector base tuning Map, to speed up initial tuning. There are also built-in Boost, Rev and Speed Limiter-Cut features. To create super smooth operation, there are various fine tuning Correction Maps to adjust for Throttle Acceleration, Vehicle Speed, Water Temp, Intake Temp, Auto Trans Shift, Anti Engine Stall, and Idle. To further aid in tuning, e-manage Ultimate’s improved integrated Monitoring, Map Tracing and Datalogging features far exceed any other piggyback controller on the market. Even when not connected to the software, 8 channels of datalogging (at 20msec intervals) can be recorded and stored to be reviewed later. With the Support Tool connected, over 30 channels can be covered. Other new features include: Improved RPM recognition, Warning Settings, Password Protection for individual tuning Maps, NVCS (Nissan), VTEC (Honda), O2 Feed-back, Clean Fouled Plugs, and numerous others in future updates. Ideal for optimizing and fine-tuning for performance products like Exhaust, Air Intake, Intercoolers, Boost Controllers, and Turbochargers, the e-manage Ultimate fills the gaps between conventional piggyback and expensive stand-alone engine managements. All installation and tuning should only be made by a trained technician with proper air/fuel monitoring tools. (Some or all functions may not be compatible with some applications.)
(same thing about harnesses from the blue apply here, along with an array of different sensors.)
Map ECU
The MAP-ECU replaces voltage and frequency based air flow meters with Manifold Absolute Pressure (MAP) based load sensing. Voltage types include the spring door flap and hot wire types used by numerous manufactures. Frequency based units are commonly known as Von Karmen Vortex Frequency air flow meter as used by Mitsubishi™ or DSM vehicles and some other manufacturers.
This MAP-ECU combines the functionality of other manufacturers Air Flow Converters and Vane to Pressure Converters into the one unit, plus more. It is supplied with a blank table for professional engine tuners who have the experience to customise the configuration. Pre-programmed units will follow for popular vehicles with starter tables, depending on demand. The MAP-ECU is programmed using a 2D Table Mode or the 3D Graph Mode. Both views allow real-time editing of the MAP-ECU configuration.
The MAP-ECU has a built in serial port which is connected to an Industry Standard PC running Microsoft(™) Windows2000(™) or WindowsXP(™).
Configuration and monitoring is accomplished using our proprietary graphical user interface. The graphical user interface allows real-time configuration and monitoring of the MAP-ECU, even while running the vehicle on a Dyno, etc.
The output data is computed from a 374 Zone table at over 100 times per second based on Manifold Absolute Pressure (-10 to +30 PSI) and RPM (0-8000).
Map ECU V2
The MAP-ECU2 replaces voltage and frequency based air flow meters with Manifold Absolute Pressure (MAP) based load sensing (Speed Density). Voltage types include the spring door flap and hot wire types used by numerous manufactures. Frequency based units are commonly known as Karman Vortex Frequency air flow meter as used by Mitsubishi™ or DSM vehicles and some other manufacturers.
This MAP-ECU2 combines the functionality of other manufacturers Air Flow Converters and Vane to Pressure Converters into the one unit, plus more. It is supplied with a blank table for professional engine tuners who have the experience to customise the configuration. Many base tables are available for popular vehicles. The MAP-ECU2 tables are programmed using a 2D Table Mode or the 3D Graph Mode. Both views allow real-time editing of the MAP-ECU2 Fuel, Timing, Auxiliary Injector and O2 Adjust configuration.
The MAP-ECU2 combines the functionality of the MAP-ECU with full Timing control, OEM Air/Fuel Ratio Adjust, Auxiliary Injector control and Electronic Boost Control. It also has many on-board functions that usually require the purchase of secondary piggyback controllers such as:
* Launch Control
* Fuel Cut Defender
* Speed Cut Defender
* Speed Adjust
* NOS Control
* RPM Switch
* Pressure Switch
The MAP-ECU2 has a built in serial port which is connected to an Industry Standard PC running Microsoft(™) Windows2000(™) or WindowsXP(™).
AEM EMS
Installs in minutes using Plug & Play technology—no wiring necessary!
Start-up calibrations included
Live help window eases tuning process
Set-up Wizard creates a custom base map for your car
System is fully enabled—Never pay for upgrades!
Free software updates on aempower.com
Uses all the factory sensors
Runs on Windows™ compatible software
Fuel table automapping
Programmable traction control
Onboard 512kb datalogger
Up to 10 cylinder sequential fuel injection
16 general-purpose outputs
7 definable switch inputs
Electronic boost control
Soft cut rev limiters
Two step launch control
Wet or dry nitrous control
Definable knock control
Full idle control
4 EGT inputs with fuel control
16/32 hybrid high speed processor
(From Turbo97se)
· 10 Injector outputs
· 5 Ignition outputs
· 1 Fuel pump output
· 4 +12v User defined drivers (VTEC, EGR, etc) outputs
· 2 O2 Heater ground controls
· 2 Temperature controlled outputs (radiator fan etc.)
· 6 user defined (-) switched outputs (NOS, a/c, purge, etc..)
· 1 Check engine / shift light
· 1 Tachometer output
· 2 PWM outputs (may also be run as switched outputs) boost control,
· Double VANOS/VVTi support
IAC motor, staged nitrous, etc)
· 2 Stepper motor drives (may also drive 4 wire antagonistic pair outputs). Can be configured to run any IAC drive system available (except drive by wire)
Inputs:
· 2 Knock channels with control
· 2 O2 channels with control
· 4 Thermo couple inputs (RTD Type Only)
· 4 Speed sensor inputs
· 1 Spare temperature input
· Throttle position
· Manifold pressure / Mass air input
· Barometric pressure sensor
· 2 Spare 0-5v input (pressure sensor, or position sensor)
· Battery voltage sensing
· Clutch or neutral input (may be used for 2-step rev control)
· Crank position (timed)
· Cam position (timed)
· Extra TDC or air flow (Vortex) input
· Speed sensor input (for gear selection, traction control, etc)
· Filtered sensor ground
Software
·traditional or boost comp tuning
· user definable 17 Load sites, 21 rpm sites
· user definable Coolant sensor
· user definable Air inlet temperature
· user definable injector parameters (inj adv, voltage compensation, staged injection etc..)
· Primary and secondary fuel/ignition maps with on the fly switching
Memory:
· 512 Kilobyte internal logging memory - logs upto 250 sample/sec on 7 channels and 31 samples per second on 8 channels simultaneously. Loop/switched logging possible
PC logging lso available (lower sample rates)
· Flash ROM
· Fault logging
Communication:
· RS-232 pc com link
· High read/write duty
Some other comments would be try to download the software for each of these engine management systems and play around with them a little to see if you like the feel of the set up. I found the user interfaces for some of these engine management systems rather clunky and non-intuitive. I felt that way about the AEM at first until I started using other emses. If you don't tune yourself, this is a don't care if you like to tinker, defiitely look into this.
Advantages of AEM:
1. Most things are user definable which is why you can use all stock sensors. a. If you have non-plug and play then you can wire into almost any car since cam/crank parameters can be set up to sync correctly.
b. You can tweak almost any parameter to get things running better.
2. Lot's of tuners around and forums with info.
3. Good bang for the buck
Disadvantages:
1. Because everything is configurable, setting it up for initial use for any car is a big task. Once the base map is done though, it's good to go
2. Questionable reliability. Some people have complained of poor reliability. I have not had this issue myself. My only complaint is that AEM cheaped out on some stuff such as high and low impedance injector drivers, and direct ignition coil drivers. Arguably this should make it more reliable since those things can produce more heat inside the box, but still!
3. Lack of ability to lock calibrations. Most EMSes can lock parts or all of calibrations, the AEM cannot easily be done especially by a regular end user. Some would argue why do you want to lock a cal anyway? Well, I would like to have the choice myself. The AEM was architected with this function but it was disabled.
Now, i said i would post pricing, so here it is, folks:
Autronic SM2: 2000
Autronic SM4: 2200
AEM EMS: 1800 - 2500
E-Manage Ultimate: 500 - 1100, depending on options
E-Manage Blue: 300 - 900, depending on options
Haltech E6x: 1170
Haltech F10x: 910
Tec3: 2295
MapECU: 400
MapECU V2: 700
If there are any other engine managements you would like to see, let me know, and I'll look up their specs and post them up here.
Megasquirt
Autronic
Motec
Haltech
AEM
Tec 3
Microtech EFI
E-Manage Ultimate
E-Manage (Blue)
MAP ECU
Pro EFI
Autronic SM4
HARDWARE:
SOFTWARE:
Autronic SM2
Features:
INPUTS
Sensors:
Main:
Auxiliary:
OUTPUTS
Main:
3. MSD 6A etc..
Auxiliary:
Haltech E6X
Features:
1 auxiliary input
Rev Limiter
Flatshift
Dual Mapping
PWM outputs:
*torque convertor
System Features:
Maps:
Trigger Pattern:
ECU inputs:
ECU Outputs:
Haltech F10X
System Features:
Maps:
Trigger Pattern:
ECU Inputs:
ECU Outputs:
Accessories:
Engine Data:
Tec 3
Standard features:
(From Lambchop)
Installation
Tuning
Inputs/Outputs
Knock Control
Sensor Calibration
Overall Opinion
E-Manage Blue
E-Manage Ultimate
Map ECU
Map ECU V2
* Launch Control
* Fuel Cut Defender
* Speed Adjust
* NOS Control
* RPM Switch
* Pressure Switch
AEM EMS
Full idle control
(From Turbo97se)
Inputs:
· Throttle position
Software
Memory:
· Flash ROM
· Fault logging
Communication:
Advantages of AEM:
Disadvantages:
Autronic SM2: 2000
Autronic SM4: 2200
Haltech E6x: 1170
Haltech F10x: 910
Tec3: 2295
MapECU: 400
MapECU V2: 700
