Car is smoking at idle and acceleration - Lexus IS Forum
post #1 of 14 (permalink) Old 03-20-2007, 03:58 PM Thread Starter
Ok recently Iíve been working on my car and it is starting to smoke. I installed a greddy catch can thinking it could maybe be blow by that was my problem. The car still continued to smoke and now it has gotten worse. I then thought maybe the turbo could be at fault so I got the turbo looked at and it checked out fine. I even added a bigger oil drain line thinking that would help it which didnít. The problem is that oil and fuel are mixing together and it is puddling in the exhaust. I checked my oil level and itís low. The car also misfires in all 6 cylinders. Iíve done a compression test and it came out 150 in all 6 cylinders. The FPR is at 45psi at idle. Iíve tried gapping the plugs to different gaps but it still misfires. Also fuel and oil are leaking from the wastgate. Any ideas of what could be wrong?
A video of the car at idle.
http://smg.photobucket.com/albums/v5...ent=Idling.flv
List of my mods.
PFS Custom Turbo Kit
Precision PT67 Turbo .68 a/r
PFS Tubular Manifold
PFS 3 Inch Turbo Back Exhaust
Tial 38mm Wastgate
GTE Rods and Pistons
AEM Standalone ECU
Turbo East pnp Harness
AEM 3.5 Bar Map Sensor
550cc Injectors
Walbro 255 Fuel Pump
Aeromotive FPR
Return Fuel System
GReddy Oil Catch Can
HKS DLI
HKS BOV
Boost Logic Turbo Blanket
W58 Transmission Swap
RPS Turbo Clutch
Innovate Wideband XD-16 Gauge
Innovate LC-1 Wideband
Turbosmart Boost Controller
AznTwins is offline
post #2 of 14 (permalink) Old 03-20-2007, 04:41 PM
whats the oil level at? drain it and refill 5.5 quarts....dont overfill it, i had similar issues one time, and it was due to overfilling it with like 6.5 quarts..
but the fuel mixing in? thats odd...
Master Certified Lexus VEHICLE TECHNOLOGY SPECIALIST and INTERNET SALES MANAGER @ LEXUS OF PALM BEACH
2015 NX200t F-SPORT ULTRASONIC BLUE
1993 Toyota Supra
SOLD 2002 IBP JDM NEO/RANDO TURBO
500rwhp+@ 17 psi
R.I.P. 2001 SBM L-TUNED Toyomoto Built TURBO
LEXOTIC CONCEPTS NE017
tsopranoMB is offline
post #3 of 14 (permalink) Old 03-20-2007, 04:52 PM
have you checked your coilpacks? maybe one of them went bad...
wwwdotZenMotorsLLCdotcom
wwwdotfacebookdotcom/zenmotors
instagram: zenmotors
Lexotic Concepts is offline
post #4 of 14 (permalink) Old 03-20-2007, 05:40 PM
Do you have oil in your intercooler piping? If your Turbo is good and compression is good you may need a restrictor for the oil feed into the turbo. I had an oil problem untill I had a restrictor made for my oil feed. Now my pipe is bone dry.
2004 SPORT DESIGN GTE TURBO 440cc HKS FCON PRO.
phonestar is offline
post #5 of 14 (permalink) Old 03-20-2007, 05:52 PM Thread Starter
I checked the resistance on all of the coil packs and they all tested good is there any other way to test them? I fill the oil to 5.7 quarts and I don't have any oil in my intercooler piping. Any other ideas?
AznTwins is offline
post #6 of 14 (permalink) Old 03-20-2007, 09:06 PM
I just had a big issue with smoking and it was all due to a combo of bolting up a GTE oil pump on the GE block and not having a restrictor.
I had an issue with Fuel mixing with the oil at one point as well. Now I never really looked into it further becuase I had few issues that all got fixed at once and the problem went away. I had to rebuild the motor because of ringlanding failure and had the car retuned. Other than the ringlanding being broken there was nothing else wrong with the car other than the fact the car was pig rich. but after the rod piston swap and retune the issue with fuel mixing with oil went away.
02 MSM
Microtech LT-8s
Electromotive XDI
SOLD :(
gasaholic is offline
post #7 of 14 (permalink) Old 03-20-2007, 09:47 PM
did you check the downpipe to make sure it wasn't a turbo seal going bad, or too much oil going through, blowing out one of the seal.
How big is your feed/return and where does your return line go on the oil pan?
Also what are your afr at idle and when you accelerate - maybe you're dumping too much fuel or maybe youre injectors aren't 'spraying/vaporising' the fuel correctly?
TeckniX is offline
post #8 of 14 (permalink) Old 03-21-2007, 03:18 PM Thread Starter
Ive had the turbo looked at and the seals are in perfect condition, My oil feed line is a -4 an and the drain line is 1/2". And the hole for the oil drain line is right on top of the oil pan where the boss is at. The oil feed line is coming off of the vvti sensor bandjo bolt. Afr is in the 10's at idle. I'm also running the stock GE oil pump.
Is there anything else you can think of?
AznTwins is offline
post #9 of 14 (permalink) Old 03-21-2007, 05:46 PM
Valves?
post #10 of 14 (permalink) Old 03-22-2007, 12:43 AM
phamous101's Avatar
For oil to make it to the wastegate, you have to be really dumping it into the cylinders. Did any of the spark plug(s) look way worse than the others? It may be possible that an oil pressure passage is some how spraying into the cylinders, through a failed head gasket or cracked head for example.
PT72GTQ
11.6 @ 124.5
phamous101 is offline
post #11 of 14 (permalink) Old 03-22-2007, 02:23 AM
i'm surprised no one has mentioned this, but check your coolant. you can either have a bad headgasket, or something in the block or head has cracked and you are leaking coolant into the combustion chamber. normally coolant would burn out as white smoke.
edit: sry, didn't see you did compression test, probably wouldn't be coolant leaking. i would suspect valves.
05' Absolutely Red 5 Speed
/Apexi N1 custom turboback/Tein Flex/Project Mu/and many more...
Boosted by Boost Logic/GTE shortblock/r154
SOLD!!!!
'11 Shelby Cobra GT500 - 554rwhp
wenger828 is offline
post #12 of 14 (permalink) Old 03-22-2007, 09:20 AM
I would start out with the easiest things first. You have already checked compression and done a leak down, rite? I would try putting a restrictor on the oil feed line, and then lean out your idle and see if that fixes the problem. Are you AFR's that rich in partial and WOT?
02 MSM
Microtech LT-8s
Electromotive XDI
SOLD :(
post #13 of 14 (permalink) Old 03-22-2007, 12:53 PM
I would preform a leak down test if you haven't.
post #14 of 14 (permalink) Old 03-22-2007, 02:57 PM
Did anyone else notice he said his AFR's are mid 10's at idle??? That's why you have fuel in your oil.
I'M FASTER THAN A ZR1!!!
SloRice is offline
