Aristo 2JZ-GTE VVTi Swap Doc - Page 7 - Lexus IS Forum
 2Likes
post #91 of 795 (permalink) Old 01-26-2008, 06:47 PM
Originally Posted by IS_BoostByPsi View Post
Edit: did you guys keep the pressure tank or w/e on the intake side under the intake manifold? seems useless but i dont want to get rid of it if i keep twins.
Same question...I believe it can be removed with no ill CEL's but to the guys that have been there done that - Y or N ?
PS: Did you guys have a lot of oil residue within the twins piping and or comp sides themselves? Mine were rather oily with the first one almost having a puddle....but no shaft play and wheels spin freely...Not sure what to make of it.
Edit- GTE coilpack sitting and plugged in on the Aristo GTE. Will work much easier then on the GE head...
mikkellucci is offline
post #92 of 795 (permalink) Old 01-27-2008, 02:55 PM
IS_BoostByPsi's Avatar
I had some oil residue, only on the intake side where the valve breather connects into the intake mani. I did have a little oil in the turbo pipes, but nothing to fret over. Let me know about those twins mike, I am not sure what to do about the iintake pipe.
I was thinking of gettin a stock supra flex pipe (the black one) that goes right onto the intake manifold and sing if I can manipulate it to where I want.
Second was to buy the Intercooler pipes from Samco, as their version seems to point it down at least in the direction we want.
IS_BoostByPsi is offline
post #93 of 795 (permalink) Old 01-28-2008, 10:35 AM
GTE Oil Pump
Did you guys buy a new GTE Oil Pump or take a chance with the Aristo one?
Also, what your thoughts on the prevelant issue(s) around the oem GTE oil pump, high boost and the front main seal failing? I recall a few threads on supraforums discussing the cause for concern even at 17psi:
The OEM oil pump is prone to front main seal failure under high boost conditions. We modify the oil pump to reduce pressure at the front main seal, increase internal flow, and balance and clearance the rotor assembly. All pumps are hand-modified and ported to ensure the highest quality.
post #94 of 795 (permalink) Old 01-28-2008, 10:41 AM
TeCKis300's Avatar
There's nothing inherently flawed in the Aristo (GTE) pump and should be good for many many miles to come.
Car sold to a good new home!
TeCKis300 is offline
post #95 of 795 (permalink) Old 01-28-2008, 10:56 AM
Ok, I'll save $167.28. Thanks, Paul!
Another question if you can help me out: The Aristo Coolant Temp sensor vs GE: Does the GTE pickup/report temp differantly then the GE sensor or is this all a function in the ecu? I dont know what to do about my Haltech coolant temp sensor....what few Supra guys use Haltechs it was tough to form a concensus on coolant temp feedback for oem ecu and haltech. It would be far too easy if the GTE temp sensor could feed both the GE ecu and the Haltech.
post #96 of 795 (permalink) Old 01-28-2008, 11:27 AM
I kept my oil pump. It looks perfectly fine. I am though replacing the front and rear main seals as I did see the posts on SF.
post #97 of 795 (permalink) Old 01-29-2008, 08:14 AM
Great info. Keep it coming!
GT40R powered Mazda RX7 R1 FD3S
TheDecon is offline
post #98 of 795 (permalink) Old 01-29-2008, 08:47 PM
Yes, excellent info! Can't wait to see it when its finished.
TurboIS_DJ is offline
post #99 of 795 (permalink) Old 02-10-2008, 04:06 PM
Hey when replacing the water pump, you used an IS300 one right? cause they are hydrolic and supra's are clutch fan.
Cant I use a mkiv supra pump if I am not going to be pushing over 18 lbs of boost?
Where did you connect your fuel return lines on the rail?
post #100 of 795 (permalink) Old 02-10-2008, 04:30 PM
TeCKis300's Avatar
You can't use the IS300 pump...it's configured differently. You need the Supra GTE water pump.
post #101 of 795 (permalink) Old 02-10-2008, 05:30 PM
Yes, get the usdm GTE water pump.
For fuel return you have a few options where to tap into. Remove the hardline and do it at the reg., or use the end of the hardline OR end of the rubber line into hardline.
(Not my motor)
(Not my motor)
post #102 of 795 (permalink) Old 02-10-2008, 10:30 PM
wow mike, your intake runner have quite a bit of oil residue, nothing major its just noticeable.
post #103 of 795 (permalink) Old 02-11-2008, 06:43 AM
Zac, it pains me that you'd think that! Hell no, thats not my motor..its been sitting untouched since I pulled the twins, coilpacks/plugs and valvecovers.
post #104 of 795 (permalink) Old 02-11-2008, 07:29 AM
While we're playing w/ pics - Can one of you swap vets (or anyone else) tell me what the busted lines in red are? Why are there what appear to be two small coolant lines coming off of a wider fitting or sensor? I believe these are ripped on my motor just as they appear in this pic:
post #105 of 795 (permalink) Old 02-11-2008, 08:00 AM
^^ one goes to the reservoir...the other goes to the cooler....
Master Certified Lexus VEHICLE TECHNOLOGY SPECIALIST and INTERNET SALES MANAGER @ LEXUS OF PALM BEACH
2015 NX200t F-SPORT ULTRASONIC BLUE
1993 Toyota Supra
SOLD 2002 IBP JDM NEO/RANDO TURBO
500rwhp+@ 17 psi
R.I.P. 2001 SBM L-TUNED Toyomoto Built TURBO
LEXOTIC CONCEPTS NE017
tsopranoMB is offline
