Aristo 2JZ-GTE VVTi Swap Doc - Page 5 - Lexus IS Forum
 2Likes
post #61 of 795 (permalink) Old 01-18-2008, 01:37 PM
I'm going to stop neg. contributing to this thread....you cant believe every thing you read online. I'll make a better contribution when I have this bad boy apart in my garage next week!
mikkellucci is offline
post #62 of 795 (permalink) Old 01-18-2008, 01:50 PM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
Shame on you!!! LOL JK
Looking to do an Aristo swap?
Aristo Swap with IS ECU
Aristo Swap with Aristo ECU
wingzero is offline
post #63 of 795 (permalink) Old 01-18-2008, 02:42 PM
TeCKis300's Avatar
At least now you'll have a jump start. Best of luck.
Car sold to a good new home!
TeCKis300 is offline
post #64 of 795 (permalink) Old 01-18-2008, 03:06 PM
Quoted: 24 Post(s)
1:1 OE FPR and a standalone should be a nice working combo. No need for rising rate unless your using winky little injectors. Plus there is a cap off to how much a rising rate helps, its not a linear graph line, fuel pressure increase = more fuel, it starts to taper off to the point of no increase at all.
Sequential is overrated, get more from your injectors JK
I like your wide band teck, I went with the DB series, gets the job done, but yours is teh nice. Shoulda done my homework haha.
BlackSportD is offline
post #65 of 795 (permalink) Old 01-19-2008, 12:46 PM
I have a couple questions if I were to get the entire front clip from an Aristo.
- Is there a "best" year to get? Or are all of them pretty much equal?
- Can the Aristo motor, wiring, and ECU be put into the IS300 without too much hassle? Or should I just put in the motor and run a standalone ECU?
- Should the 4speed transmission be put in or should I leave my stock 5 speed manual? I'm not planning on getting more power than what the stock Aristo outputs.
db84drteg is offline
post #66 of 795 (permalink) Old 01-19-2008, 11:54 PM
Rising rate regulators main purpose is to offest the boost pressure in the intake tract not to increase the amount of fuel injected at higher boost pressures. If you are running 40psi of boost and have 40psi fuel pressure in your fuel rail even when the injector open there is no pressure differential therefore no way for the fuel to "flow" out of the rail.
Almost Stock TSi is offline
post #67 of 795 (permalink) Old 01-20-2008, 01:17 PM
IS_BoostByPsi's Avatar
teck, what flywheel are you running? Sc300? Supra?
I want to run a stock flywheel on mine bc I am going to run the w55 untill I get my w58.
Stock is300 flywheel with w55
Stock sc300 flywheel with w58? stock sc300 clutch with w58?
IS_BoostByPsi is offline
post #68 of 795 (permalink) Old 01-20-2008, 04:02 PM
TeCKis300's Avatar
I'm running a supra NA flywheel for the weight savings without going a super lightweight AL one.
W55 or W58 really has no bearing on the flywheel u can use.
It's more about the clutch/PP that you choose as that has to be matched to the sprung/unsprung flywheel.
post #69 of 795 (permalink) Old 01-20-2008, 09:16 PM
Quoted: 24 Post(s)
I guess I should have been more specific. 1:1 is a "rising rate" fpr, and I had just noted its a good item for boost.
What I meant by then countering in the next sentance that a rising rate is not necessary, is what I meant is the types of regulators mentioned on these boards that are more than a 1:1, for the application of getting enough fuel out of OE injectors with the OE ECU's n/a tune to actually run rich in boost. I beleive they are have a "gain" setting, and can raise fuel presssure in a lon-linear way.
Note to self, use proper terminology to avoid basic auto 101 leasons. Sorry if I come off pissed sounding, but I had recently just did a bunch of re-plumbing of my TRD S/C setup to utilize the FPR setup properly, and so getting a lecture on how it works was a smack to the face, not to mention my post (#53) clearly demonstrates I have a grasp of what these devices do, and how it is in relation to tuning/injector characteristics.
post #70 of 795 (permalink) Old 01-24-2008, 07:40 PM
Hey guys, did you use your IS300 powersteering and a/c compressor or the GTEs'? All the lines on the gte's are cut . I think it would work just to unbolt them from the GE while still on the car, and leave them hang out of the way and rebolt them to the gte?
post #71 of 795 (permalink) Old 01-24-2008, 09:39 PM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
Use the parts from the GE, they fit exactly the same.
wingzero is offline
post #72 of 795 (permalink) Old 01-24-2008, 10:06 PM
ok sweet. How in the hell did you get your crank damper pulley off! I gave up on the breaker bar and i am going to toyota to see if i can coax them to let me have the Specialty tool they use.
For reference for the sticky:
Part # 09213-70010 is the crankshaft pulley holding tool
Part # 09330-00021 Companion Flange holding tool (includes pin)
post #73 of 795 (permalink) Old 01-24-2008, 10:08 PM
do I have to have a powersteering cooler like tecks? or can i just re-route it around/infront/ behind the intercooler?
Edit: I am also pulling the crank pulley to replace the front main seal, and going to replace the rear main seal also. I also have to take it off to reach the tensioner for the timing belt to replace the timing belt.
post #74 of 795 (permalink) Old 01-24-2008, 10:25 PM
TeCKis300's Avatar
You can do whatever u like...just make sure you have some sort of PS cooler.
post #75 of 795 (permalink) Old 01-24-2008, 10:51 PM
K cool, rep you both again when I can.
