Aristo 2JZ-GTE VVTi Swap Doc - Page 2 - Lexus IS Forum
 2Likes
post #16 of 795 (permalink) Old 12-28-2007, 07:23 AM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
I maybe a little lost here, all my exhaust flappers have been wired open. And if memory serves there are no vacuum plugs near the manifold only above it near the turbos. The only thing that was connected to the flappers were the solenoids and those have been removed. Guys, did I miss something here? However, yes I am using regular plugs and they have held up just fine so far. And even if they have to be replaced...i've got LOTS of them.
Looking to do an Aristo swap?
Aristo Swap with IS ECU
Aristo Swap with Aristo ECU
wingzero is offline
post #17 of 795 (permalink) Old 12-28-2007, 08:13 AM
I will try to get some pictures up in a little while of what I'm talking about.
Almost Stock TSi is offline
post #18 of 795 (permalink) Old 12-28-2007, 11:52 AM
These are what I am talking about.
Name:	FRONT ACTUATOR.JPG
ID:	14791   Click image for larger version
Name:	REAR ACTUATOR.JPG
post #19 of 795 (permalink) Old 12-31-2007, 05:16 AM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
yeah that's what i was talking about too....those valves work with the stock vacuum lines on top of the turbos to regulate the wastegates. I have completely removed them and just wired the gates open so the exhaust is flowing without any restrictions. In other words the objects you are pointing to...are no longer there on my engine. On a positive note, considering how cramped the space is on the motor, any thing you can get rid of is a blessing
wingzero is offline
post #20 of 795 (permalink) Old 12-31-2007, 08:25 AM
So what are you using to regulate boost?
post #21 of 795 (permalink) Old 12-31-2007, 09:05 AM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
no boost controller as of yet, but I will be adding one soon
wingzero is offline
post #22 of 795 (permalink) Old 12-31-2007, 09:58 AM
What kind of boost levels are you seeing with the wastegates wired open?
post #23 of 795 (permalink) Old 12-31-2007, 10:02 AM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
right now im having a o2 sensor problem so i haven't seen full boost yet, but i do know that at 3K i have 5.5psi
wingzero is offline
post #24 of 795 (permalink) Old 01-02-2008, 09:30 AM
IS_BoostByPsi's Avatar
Did you still run your coolant lines from the upper radiator hose to the turbos? Or did you run them souly on the oil feed lines?
How many o2' ports does the gte have? We have like 3 right? How many ports will we have to create on the dp or w/e?
IS_BoostByPsi is offline
post #25 of 795 (permalink) Old 01-02-2008, 10:31 AM
I only have one o2 sensor/port on mine.
post #26 of 795 (permalink) Old 01-02-2008, 01:40 PM
Nice writeup but I still don't understand why you would remove the wastegate actuators and wire the gates open...
If you want to eliminate the turbos coming on sequentially, can't you just use a T on the actuator vacuum lines and attach them to the same source so they both come into boost at the same time with a boost controller? Or are the stock actuators set at different boost levels?
Wiring the gates open will cause the turbos to spin to ungodly speeds to reach desired boost levels instead of spooling up to the desired boost and letting the gates relieve exhaust pressure to control boost pressure.
Nate
Formerly 01' Onyx IS300 - Custom modified intake, HKS Drager II, Tokico Illuminas, Swift springs, TSW Trackstar 5 with Hankook Ventus V12 tires.
NateIS300 is offline
post #27 of 795 (permalink) Old 01-02-2008, 07:39 PM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
I ran mine on the oil lines alone.
As for the wastegates, from what I understand that is one of the TTC mod methods that the supra guys use. I got it on MKIV.com As for overboost, I believe a boost controller will remedy that....again correct me if I am wrong guys. Cuz if I am, I'm gonna have a GREAT time pulling that motor again...
wingzero is offline
post #28 of 795 (permalink) Old 01-02-2008, 08:36 PM
To properly control boost you will have to put those 2 actuators back on. Those aren't the exhaust valve you remove for the TTC. You have to remove the exhaust valve on the bottom of the exhaust setup below the o2 sensor location. I had to take mine to a machine shop to have it removed.
post #29 of 795 (permalink) Old 01-02-2008, 08:39 PM
Originally Posted by NateIS300 View Post
. . . Wiring the gates open will cause the turbos to spin to ungodly speeds to reach desired boost levels instead of spooling up to the desired boost and letting the gates relieve exhaust pressure to control boost pressure.
Nate
Wiring the waste gate flappers open will not cause the turbos to spin faster to reach the same boost levels. It will just take them much much longer to reach their operational rpm. Now if there was a giant intake leak that would cause the turbos to spin a lot faster to make the same boost level.
post #30 of 795 (permalink) Old 01-03-2008, 05:11 AM Thread Starter
wingzero's Avatar
Quoted: 17 Post(s)
MKIV.COM
That is where I got the information. However instead of keeping the actuators on, I simply removed them since after you wire the gates open, they aren't doing a damn thing. On top of that, the stock vacuum lines are not being use on my motor.
wingzero is offline
