ok, back for the weekend..........been away working ....again
Wiring nearly finished, or should i say the factory wiring that had to be redone due to the slight oversight of the roll cage manufacturer, to actually leave space for the fuseboxes in the footwells...............hmmm
the drivers side fuse box is now located behind the passenger seat
the centre console needs redoing, the cabin heater controls are now in the glovebox ..
need to fasten all the cables down now....final hurdle was getting the dam lights working, after about 4 hours of faffing about finally got my "daytime running light" modification working (however as the lights are normally high beam, so very bright...i need to see how you guys DRLs look.....is there a resistor pack, to lower output, or is there dirfferent bulbs...any help please)
also finally got the IS300 factory HID working on the car....
DRL
DRL & HID
still need to drop the factory fuel tank, mount the fuel cell, run the rest of the fuel lines, and plumb them in.....then redo centre console and the final bits.....blah...........blah...........blah....whe n will i get it sorted...., Dunno!
