b
» Log in
Not a member yet?
Register Now!
» Featured Product
» Wheel & Tire Center
Sponsors
Sponsors
Old 03-25-2005, 05:02 PM   #316 (permalink)
superchargedIS200 is an elite community membersuperchargedIS200 is an elite community membersuperchargedIS200 is an elite community membersuperchargedIS200 is an elite community membersuperchargedIS200 is an elite community membersuperchargedIS200 is an elite community membersuperchargedIS200 is an elite community membersuperchargedIS200 is an elite community membersuperchargedIS200 is an elite community membersuperchargedIS200 is an elite community membersuperchargedIS200 is an elite community member
more wallpapers here, larger resolution backgrounds of mine can be found at the bottom
http://www.banzaimagazine.com/wallpapers.htm
superchargedIS200 is offline Reply With Quote
Old 03-25-2005, 05:08 PM   #317 (permalink)
2005 ToyDrive Participant 2006 ToyDrive Participant
GangusKhanh² is an elite community memberGangusKhanh² is an elite community memberGangusKhanh² is an elite community memberGangusKhanh² is an elite community memberGangusKhanh² is an elite community memberGangusKhanh² is an elite community memberGangusKhanh² is an elite community memberGangusKhanh² is an elite community memberGangusKhanh² is an elite community memberGangusKhanh² is an elite community memberGangusKhanh² is an elite community member
Sweet! +REP
My world is Flat.
GangusKhanh² is offline Reply With Quote
Old 03-25-2005, 05:24 PM   #318 (permalink)
Poker Tournament Player
DimSumInABox2GO is an elite community memberDimSumInABox2GO is an elite community memberDimSumInABox2GO is an elite community memberDimSumInABox2GO is an elite community memberDimSumInABox2GO is an elite community memberDimSumInABox2GO is an elite community memberDimSumInABox2GO is an elite community memberDimSumInABox2GO is an elite community memberDimSumInABox2GO is an elite community memberDimSumInABox2GO is an elite community memberDimSumInABox2GO is an elite community member
thats sick!!
Hac Gao..............$1.25
Shu Mai..............$1.25
Cha Shu Bao..........$1.00
Pie Goot...............$1.25
Dan Tat................$1.00
DimSumInABox2GO is offline Reply With Quote
Old 03-25-2005, 05:57 PM   #319 (permalink)
boosted_4door's Avatar
boosted_4door is an elite community memberboosted_4door is an elite community memberboosted_4door is an elite community memberboosted_4door is an elite community memberboosted_4door is an elite community memberboosted_4door is an elite community memberboosted_4door is an elite community memberboosted_4door is an elite community memberboosted_4door is an elite community memberboosted_4door is an elite community memberboosted_4door is an elite community member
[quote='03IntensaBlueBeast]Sick!!!!!! Simply sick!!! when is the vid coming? and dyno sheets? love to see footage of the beast in action!!![quote]
^agree
Current: '03 BMW M3
Recaro | VOLK TE37's | Stoptech | Rogue Engineering | SuperSprint | Meisterschaft | VF Supercharged | AST 4100's
Gone: '03 SRT Built IS300 (615rwhp @ 19psi pump gas)
boosted_4door is offline Reply With Quote
Old 04-04-2005, 03:46 PM   #320 (permalink)
Steve2255 is an unknown at this point
I just read through this for the first time..... im speechless. Amazing work.
Bone Stock Black Onyx 05 E-Shift
Steve2255 is offline Reply With Quote
Old 05-16-2005, 03:47 AM   #321 (permalink)
well after some issues with the rear subframe the first Dyno run has been done, this was mostly to sort out Engine mapping throughout the RPM range.
the Dyno print shows the readings taken in 6th gear(over driven) with Catalytic converter fitted.
it is currently estimated that without cat, and true readings taken (1:1 ratio, in 5th gear) that the RWHP will be 480-500 rwhp, which equates to approx 600 hp at the Flywheel, this is on Pump gas
Old 05-16-2005, 04:35 AM   #322 (permalink)
Wxman is an upstanding community memberWxman is an upstanding community memberWxman is an upstanding community memberWxman is an upstanding community memberWxman is an upstanding community memberWxman is an upstanding community memberWxman is an upstanding community memberWxman is an upstanding community memberWxman is an upstanding community memberWxman is an upstanding community memberWxman is an upstanding community member
With all the time and money you put into the car, isn't the 409 rwhp very disappointing. Thought you would make more than that.
Wxman is offline Reply With Quote
Old 05-16-2005, 04:58 AM   #323 (permalink)
that reading is a 6th gear reading, this run was mapping the engine, iand ensuring that all the bits hold together,
Already the rear control arms had to be modified to spherical bearings as the Eccentric adjusters bent due to Torque.
and now its been found that the Subframe is moving around on the TRD bushes, so Solid mounts are being Machined.
i must point out the car is still running its Original IS200 Torsen diff, so the gearing is set very low at the moment, and its this low gearing which is breaking things.....amazingly the diff is Holding up, and the plan is to see, How long it holds up.
the readings are also Metric HP, there is a difference, i think its a very respectable reading for a first run....in 6th, with Cat fitted, for engine set up purposes, i didnt have to post the Print out, but as this topic is a Log of events, i thought it Usefull to show where the car is at.
everyone talks HP, its Torque that you need....
i think the Torque figures are very reasonable, as i said in the post above.
"This run was done with cat and in 6th gear for mapping purposes, it is currently estimated that without cat, and true readings taken (1:1 ratio, in 5th gear) that the RWHP will be 480-500 rwhp, which equates to approx 600 hp at the Flywheel, this is on Pump gas......."
the run at Full throttle will soon be done, dont worry, its not finished yet
Old 05-16-2005, 05:54 AM   #324 (permalink)
Mr. Negative
IS_Dude's Avatar
Roundtable Panelist 2005 ToyDrive Participant
IS_Dude is an elite community memberIS_Dude is an elite community memberIS_Dude is an elite community memberIS_Dude is an elite community memberIS_Dude is an elite community memberIS_Dude is an elite community memberIS_Dude is an elite community memberIS_Dude is an elite community memberIS_Dude is an elite community memberIS_Dude is an elite community memberIS_Dude is an elite community member
that is indeed very nice man. as you go forward you are definately putting all problems behind you like the arm issue. In the end you will have a truley spectacular car. Congrats on the dyno and on the future tuning. 500whp on pump is nothing to sneeze at, and to think that is where you are starting off at is even that much more impressive.
Keep us updated.
Selling 19" Iforged wheels
2003 IS300T 23k miles
AEM, Meth, Tein, 6spd
02 IS300 MT
TRD Sways, HKS Dragger, Eibach
Sold-
97 JZA80
2001 IS300T
IS_Dude@is300.net
IS_Dude is offline Reply With Quote
Old 05-16-2005, 06:14 AM   #325 (permalink)
thanks.
Theres still a long way to go....but everyone involved is being Methodical and cutting no corners.
When TDI's Rototest is upgraded shortly, The car will go back on the Dyno
The only way to get a true power and torque figure is by testing in a direct gear ratio....as this wasnt
To get an idea of the true performance of this car (at the hubs), you can add at leat 15% to the figures shown in the above Certificate of Performance.
Old 05-16-2005, 08:47 AM   #326 (permalink)
toyotaownsyou is famous around these partstoyotaownsyou is famous around these partstoyotaownsyou is famous around these partstoyotaownsyou is famous around these partstoyotaownsyou is famous around these partstoyotaownsyou is famous around these parts
i have been following this topic for sometime now.........i think you have created one of the greatest IS's i have ever seen.........all around you have done everything and haven't cut a single corner..........this topic is full of great information and i would like to say thanks for shareing it all with us..........and i would have to disagree with some of the people that don't like your front bumper..........i think that creating a one of a kind bumper like this is great........it is really agressive and it adds to this car well........good luck on the goal at hand here.........
toyotaownsyou is offline Reply With Quote
Old 05-16-2005, 11:10 PM   #327 (permalink)
Fig
THE MAKER
Fig's Avatar
my.IS Supporter
Fig is an elite community memberFig is an elite community memberFig is an elite community memberFig is an elite community memberFig is an elite community memberFig is an elite community memberFig is an elite community memberFig is an elite community memberFig is an elite community memberFig is an elite community memberFig is an elite community member
Hell yeah Mat, nice work. I think the mods to the subframe are probably expected as with the eccentrics, those damn things barely hold stock. I would love to swap notes on the rear end mods sometime, hit me up on PM or AIM.
I think for the first pop, those numbers are respectable, nowhere to go but up with an extensive focus on tuning now. Great job.
Fig
VISIT MY.IS.VENDOR area
FB is the best UPDATE BOARD:
REAR FUZOR proto 2 parts on order.
Full Front control arms in the works! Caster arm spacers in, now I gotta build the rest.
Solid steering rack bushings
ISF Ti exhaust first Proto complete
CDD DELETE parts shipping
ISF CF Engine cover
HEATSHIELD: bare is SOLD out, anodized available.
RCA Hysteer: contact me for pre release parts a few left.!!!
PRODUCTS_: go to www.figsengineering.com
Fig is online now Reply With Quote
Old 05-16-2005, 11:40 PM   #328 (permalink)
yesitisYELLOW is a continually helpful memberyesitisYELLOW is a continually helpful member
just to clear this up, this was at partial throttle and in the wrong gear?
just wow
yesitisYELLOW is offline Reply With Quote
Old 05-16-2005, 11:47 PM   #329 (permalink)
UnVme is an elite community memberUnVme is an elite community memberUnVme is an elite community memberUnVme is an elite community memberUnVme is an elite community memberUnVme is an elite community memberUnVme is an elite community memberUnVme is an elite community memberUnVme is an elite community memberUnVme is an elite community memberUnVme is an elite community member
Matt- You have truely built an incredible machine. I have nothing but the upmost respect for you and commend you on getting this far. Not only getting this far but setting new trends, TWINS in an IS haha..INSANE...I love every bit of it.. A new diff, and some tunning and this car will be more than you can handle. UNVME ENVYS U! COngrats again!
-MAtt
UnVme is offline Reply With Quote
Old 05-20-2005, 04:04 PM   #330 (permalink)
tsopranoMB is an elite community membertsopranoMB is an elite community membertsopranoMB is an elite community membertsopranoMB is an elite community membertsopranoMB is an elite community membertsopranoMB is an elite community membertsopranoMB is an elite community membertsopranoMB is an elite community membertsopranoMB is an elite community membertsopranoMB is an elite community membertsopranoMB is an elite community member
orignally posted here: http://www.clublexus.com/forums/showthread.php?t=163547
congrats dude!!!
tsopranoMB is offline Reply With Quote
You may not post new threads
You may not post replies
vB code is On
