Stock Radio + Ipod connection + Amp/Sub wiring help! - Lexus IS Forum
post #1 of 11 (permalink) Old 07-26-2009, 12:28 AM Thread Starter
So I recently got an IS300, and really want to make a hookup for my Ipod, and connect my massive amp/sub in the simplest fashion possible. I would like to keep the stock head unit because I feel it really makes the car look good, so this was what i was thinking; Do the Ipod installation, and then split the RCA wires that are going from the Ipod to the head unit, and send it back to the amp in the trunk. Will this work? and if so, what should i use for a remote trigger? I would like it to be able to be flipped on and off with a switch of some kind, because sometimes I'd rather not have the subwoofer on(such as at the drive in), because it drains the batter very fast. Maybe the cruise button?
I was also thinking that it may be possible to split the wires from the back speakers that are already in the trunk, but am totally unsure how to go about that.
I've seen a few other posts similar to this, but would really like some feedback on this exact situation. If this has already been answered, please forgive my retardedness and leave me a link, rather than a flame , thanks!
Gunlex is offline
post #2 of 11 (permalink) Old 07-26-2009, 01:38 AM
ok here is what i did. i have the exact setup you were asking about.
parts needed:
Vais Technology ipod/aux adapter(ebay <$100)
Modified oem amp with sub output(my.is member <$65)
Ipod
Subwoofer and amp setup(cap optional)
4gauge rockford amp kit
piece of wood or plastic to make vanity cover for ipod
modified amp with rca output
you hook the vais unit to the cd changer port on the back of the stock radio. at that point your stock headunit acts the same, but if you hit Disc and extra time it flips to your ipod and you can either go simple mode(you control your ipod menu) or you go into advanced mode(your deck controlls yours ipod)
the next part is getting a good solid subwoofer output to your amp and sub combo. there are many who swear by the line converter that you hook to the low end side of your rear speakers. for me, i wanted a cleaner signal so i did some research and found a member that ads rca full frequency outputs to the stock amp. at that point i ran my 4gauge power wire and amp turn on lead down the drivers side. and i ran my rca signal line down the passenger side. my amp has a bass controll knob. so i ran the wires from the sub amp up the passenger side and into the area of the center console. i mounted the control onder my Trac Off button for easy control of the subwoofer level.
the last part is upto you. but i removed the center console top (where the ash tray is) i removed the ash tray area and under there was a 1/4" hole. i enlarged that hole just enough to fit the ipod dock connector through. i hooked up the ipod to it, and the ipod sits nicely down in that ash tray spot without blocking any heated seat buttons. i created a temporary vanity cover for the ipod to cover the gap left in the top of the console where the ask tray door would have been.
i get very clean sound out of this configuration.
2002 IS300 IntensaBluePearl LSD | Megan Racing Ypipe | Vais Tech. Ipod Adapter | SRT Intake and aafc | Luminics krypton 9005 yellow highbeam | Alpine SWR-10d2 x2 | RF 1000w Amp w/bass control | RF 4 Gauge Pwr/Gnd | RF 1 Farad Cap | Drag dr19 wheels | Falken Tires | SD Grill | Injen Header Shield | Painted Headlights and Fogs |
3rdelement is offline
post #3 of 11 (permalink) Old 07-26-2009, 01:55 AM Thread Starter
Ah sweet, that amp thing would be exactly what I need. Can you refer me to who it is that sells it? Do you think he would bring the price down if I sent him my own deck amp?
Also, I can't seem to find the ipod aux thingy on ebay, the only one I found was this:
2001/2002/2003/2004 Lexus IS300 iPod/iPhone Adapter :eBay Motors (item 140320008614 end time Aug-08-09 15:49:13 PDT)
And will this still allow me to use the 6 disk CD changer functionality?
Gunlex is offline
post #4 of 11 (permalink) Old 07-26-2009, 09:17 PM
keep checking ebay, craigslist, for sale section....or just buy directly from them for $200-$250.
the amp price is the price if you ship them theirs.
and yes you keep all the same funtionality of the 6 disc changer. the only difference is that if you hit disc again you get the aux in option, and if you hit it again you get the ipod control from the deck, and hit it once more and you are back to the stock 6 cd changer.
post #5 of 11 (permalink) Old 07-27-2009, 04:28 PM Thread Starter
Are there any similar products that I could use that are cheaper?
Gunlex is offline
post #6 of 11 (permalink) Old 07-27-2009, 10:08 PM
you get what you pay for. you could get the grom unit that is mentioned in this section. but it seems like more and more people keep having issues with it. just keep checking the forums and ebay for a used one. thats what i did. and i saved a bundle.
i guess if you want a cheaper option you might find a deal on an aftermarket deck and also a metra harness, but then you loose the oem look of the dash.
post #7 of 11 (permalink) Old 07-30-2009, 04:25 PM Thread Starter
The only issue I'm seeing is the remote on/off line, where will that connect?
Gunlex is offline
post #8 of 11 (permalink) Old 08-03-2009, 11:02 AM
for the amp? or for the vais?
the sub amp i found a remote turn on with a voltmeter on the wire harness that goes from the stock head unit to the stock amp.
post #9 of 11 (permalink) Old 08-14-2009, 02:18 PM
parts needed:
Ipod
I am planning to do the same as you, but I am having the hardest time finding the easiest way to get the stock amp out to mod it. I have searched and searched on here, and have also pulled off the kick panel and opened the glove box to see the amp, but need some help with what to remove and how. Pulling apart the entire passenger side of the console and glove box seems overrated. lol. Got any tips or instructions?
Thanks
02 GGP IS300 E-Shift
GROM
235/40 KDW
-FS:Driver side chrome tail light-
-WTB:Locking Diff-
2thou2is.300 is offline
post #10 of 11 (permalink) Old 08-14-2009, 03:56 PM
the brown (i believe) on the radio wiring harness is the one i used for remote. Take a test light and turn the car on. whichever has power when the car is turned on is your power wire.
thatoneguy is offline
post #11 of 11 (permalink) Old 11-19-2009, 03:09 AM
Can anyone tell me how to get a hold of the modified oem amp with sub output?
KJJIS is offline
